Cyanoacrylate and Quicklime
Neil Wyatt13/05/2017 18:11:19
19226 forum posts
749 photos
86 articles
Has anyone come across 'Supa-Fix'? I picked up a box with two bottles of cyano and a bottle each of 'grey' and 'black' calcium oxide powder. The in-store demo was impressive, suggesting the combination produces a rock-hard, gritty textured substance that was able to joining wood to steel very effectively.
It would appear that the calcium oxide does more than catalyse a quick set, but presumably it undergoes some chemical change, perhaps creating a cyano-reinforced limestone?
I must admit, I haven't tried it yet, but it looks fun.
www.platinum-supplies.com/supa-fix-everbuild-adhesive-powder-kit-super-glue-apx4-ultra-strength-supafix.html
jason udall13/05/2017 18:26:31
2032 forum posts
41 photos
I use "standard" CA and sodium bicarbonate. ..baking powder...
Bill Davies 213/05/2017 18:37:31
357 forum posts
13 photos
...And the bicarb is said to provide the small amount of water to cause the CA to set. However, I would have expected the calcium oxide to be devoid of moisture as it would immediately react with any (i.e., quicklime converted to slaked lime). So perhaps it does act as a catalyst. But it sound like an unpleasant and very reactive ingredient in the adhesive or cement.
Bill
Neil Wyatt13/05/2017 19:52:45
19226 forum posts
749 photos
86 articles
Their blurb says 'like concrete' and it certainly is. I guess it could work very well to fill cracks in castings not exposed to temperatures above 180C.
mark smith 2013/05/2017 20:26:31
682 forum posts
337 photos
I found a patent for a bio-adhesive composition and it says calcium oxide can be added as a `heat dispersant`, so its any ones guess what happens, other than as a filler.
superglue can react with many things. Ever drop any on your cloths. I had a minor burn on my leg after spilling a load onto my jeans .
matt merchant13/05/2017 21:02:34
19 forum posts
sounds interesting, can think of a few unconventional uses depending on the cure time
jason udall13/05/2017 21:08:04
2032 forum posts
41 photos
Cure time for bicarb is truly rapid. .sensibly instant...
Works as filet
Can be filed..just very hard bonds well to steel
Wood plastics
Not great on ali ( way better than raw)..
Best effect .. wet both surfaces.. add sprinkle of powder...add further to build fillet as required
Georgineer13/05/2017 22:48:31
652 forum posts
33 photos
Posted by Neil Wyatt on 13/05/2017 18:11:19:
Has anyone come across 'Supa-Fix'? I picked up a box with two bottles of cyano and a bottle each of 'grey' and 'black' calcium oxide powder. ..
Since calcium oxide is white, there must be additives in these powders, possibly fillers of some sort.
Geo.
stevetee13/05/2017 23:30:35
145 forum posts
14 photos
It's been available in the motor trade for some years , but I expect the price will have come down somewhat now. I believe the filler powder may well contain a catalyst for the superglue. As other have said it forms a very hard and quick repair on may substrates.
Neil Lickfold14/05/2017 10:03:32
1025 forum posts
204 photos
Blasting soda is a free flowing baking soda, so it pours quite well. Makes for a very hard compound. Another we use as a wear strip is a combination of blasting soda and carborundum powder. I use it for a landing skid on my model planes.
Neil Wyatt15/05/2017 08:20:39
19226 forum posts
749 photos
86 articles
Posted by mark smith 20 on 13/05/2017 20:26:31:
I have heard that it can set cotton on fire.
Muzzer15/05/2017 08:38:36
2904 forum posts
448 photos
As well as excluding oxygen, moisture and metal salts help CAs to go off. Humid clothes contain both, as well as large surface area in a small volume. I believe the "activator" sprays basically provide the metallic salts.
Most of these reactions are exothermic and the rate of reaction increases with temperature. Same is true of epoxy (Araldite) and car filler (MEKP?). I can tell you that if you add the hardener (or whatever it's called) neat, you can get that to burst into flames, which is presumably why it is generally supplied in a diluted form. With Araldite, if you heat it up, the reaction is quicker which can be useful, although initially it becomes more fluid - which can also be helpful.
Murray
Muzzer15/05/2017 08:38:37
2904 forum posts
448 photos
Murray
Tim Stevens15/05/2017 10:08:06
1779 forum posts
I suggest that the 'calcium oxide' which is supplied is not actually quicklime, but slaked lime. I have three reasons:
1. Quicklime is fairly dangerous stuff, and is no doubt covered by all sorts of regulations. Slaked lime is much more friendly, even available at posh builder's merchants in lime mortar.
2. Quicklime is eager to absorb moisture, so has to be in a tightly sealed container, even in the factory where it is made. When this has occurred it turns into slaked lime (hydrated calcium oxide). So why not supply the non-noxious stuff?
3. If moisture helps c-a to polymerise, there is no advantage (in this respect) in adding a compound which absorbs moisture itself.
And it may be that the resulting set product with calcium is less soluble in water than with sodium (from bicarbonate) - thus extending the usefulness of the product.
But what do I know about it, anyway?
Cheers, Tim
KWIL15/05/2017 11:02:02
3681 forum posts
70 photos
Very good stuff Neil and useful too. Good filler for plastic parts when you have a hole to cover up. Cracked saucepan handles etc.
Gordon W15/05/2017 11:41:50
2011 forum posts
This may be off topic, but lots of people here seem to know about such things - My stainless steel hot water cylinder seems to have a very small leak, in the bottom. I am thinking of draining and cleaning out as best I can, then pouring some " stuff" in. Any suggestions ? Dia. is about 400 mm, max. temp about 70 C and will be wet all the time
Bill Davies 215/05/2017 19:32:58
357 forum posts
13 photos
Vehicle Radiator sealant? Sodium silicate aka water glass. Not sure how well it would adhere to stainless steel.
Bill
Neil Wyatt15/05/2017 20:52:28
19226 forum posts
749 photos
86 articles
Posted by Tim Stevens on 15/05/2017 10:08:06:
Cheers, Tim
It's calcium oxide, the box wouldn't be plastered in warnings if it was slaked lime, and why claim it's something dangerous if it isn't?
Tony Jeffree16/05/2017 21:28:31
569 forum posts
20 photos
Posted by Neil Wyatt on 15/05/2017 08:20:39:
It has an exothermic reaction with polyester fabrics too.
not done it yet16/05/2017 21:46:54
7517 forum posts
20 photos
Posted by Gordon W on 15/05/2017 11:41:50:
Your risk if you want your house flooded. The cylinder may be weak in that area and just waiting to fail in a big way! Is this a gravity system or at mains pressure?
As far as temperature is concerned, I've yet to see a hot water cylinder that is hot at the bottom. Water is a very good insulator.
