Centec 2 drop arm dimensions or for sale
NICHOLAS TOLHURST11/05/2017 15:46:58
7 forum posts
Hi,
Does anyone out there have a Centec 2b horizontal drop arm/ plate and arbour for sale, or could anyone who has one sketch out some dimensions for me so I can make one ?
Any help much appreciated.
not done it yet12/05/2017 06:27:37
7517 forum posts
20 photos
Do you mean the arbor support from the overarm? Nothing special. A slide-way to fit the overarm, a gib to lock it in position, or a slit and pinch bolt to secure it. A hole on centre line at the height of the horizontal drive and a bearing to suit. An oilite bearing may well be adequate but something tougher may be needed for heavy radial loading. A means of lubrication can easily be devised, I would think.
Don't restrict to 2B. 2 and 2A will be the same, I would expect.
Mike E.12/05/2017 09:14:19
217 forum posts
24 photos
Have a look on the quillstar.co.uk used tools site, and scroll down to the very bottom of the page. Currently they show a pallet load of Centec parts which includes an overarm with an arbor support. You might want to give them a call to see if its compatible with your needs.
Gary Wooding12/05/2017 09:38:32
1074 forum posts
290 photos
These photos of my overarm might help...
overarm 4.jpgoverarm 3.jpgHere are some photos of my overarm that might help...
mark smith 2012/05/2017 10:07:49
682 forum posts
337 photos
Posted by Mike E. on 12/05/2017 09:14:19:
That ad has been up for 12 months or more .
NICHOLAS TOLHURST12/05/2017 12:15:45
7 forum posts
Many thanks for the replies so far, I've sent an enquiry to Quillstar.
Very many thanks for the pictures Gary, it does look like a dead easy piece to make.
I could knock out an identical copy on my little CNC mill easily.
What is the bearing size Gary ?
Scaling up from your drawing it looks like 3/4" O.D. 1/2" I.D. is that right ?
Also what is the thread on the end of the arbour for the lock nut out of interest, and is it L>H. or RH thread ?
Dave Halford12/05/2017 12:35:28
2536 forum posts
24 photos
Some mt2 arbors do not have a spigot, but are designed to run in a ball race and therefore run on one of the last spacers.
get your arbour first
The 2B arm will fit the smaller 2 and 2A but they are longer (you shove the excess out the back) The 2 arm won't cover the full table travel of the 2B the 2a arm might..
The arm from a 2C will not fit at all
Gary Wooding12/05/2017 13:51:25
1074 forum posts
290 photos
These are the dimension of my 2B arbour.
NICHOLAS TOLHURST12/05/2017 15:27:43
7 forum posts
That's absolutely terrific Gary, thank you so much.
I'll definitely go ahead now and make the parts.
Measured up my overarm and it looks like the correct one for my machine.
Got an accurate figure of 3.7/16" from the spindle centre to the arm mating face, so can go ahead now.
Very many thanks again I'm very grateful.
Watch this space !
Nick
duncan webster12/05/2017 19:30:08
5307 forum posts
83 photos
If you're in any doubt on the position of the bearing hole you could make up the drop arm thing, then bolt a toolmakers button on, fit to the overarm, clock the button true to the spindle and then set up off that to bore the hole
peak413/05/2017 11:12:03
2207 forum posts
210 photos
Nick, where in the country are you?
If it's within sensible travelling distance of Buxton Derbyshire, come and look at one in the flesh and drink coffee.
Bill
NICHOLAS TOLHURST13/05/2017 13:09:04
7 forum posts
Thanks for the offer Bill, but sadly I'm in Mid Wales !
However I do go motorcycle racing at Darley Moor Circuit occasionally...... well to watch the Classic 50cc racing club anyway !
If I'm up your way I'll give you a shout.
peak413/05/2017 16:12:15
2207 forum posts
210 photos
Posted by NICHOLAS TOLHURST on 13/05/2017 13:09:04:
Please do, you'll be most welcome. Not be to that circuit for years, but looking forward to a re-visit with a camera sometime this summer.
A friend of mine used to race them years ago, apparently peak power @ 16,000rpm but engine expired @ 16.600rpm
Bill
