Airline connectors anyone?, - Biax grinder
capnahab11/05/2017 08:19:23
194 forum posts
17 photos
img_9983.jpgAnother ebay find. My workshop air (and knowledge) does not extend beyond a few PCL connected tools. My compressor has a line with a vertex PCL (female) connector and most of my tools have PCL male ends. I would like to get this grinder working in much the same way. I think a short 'flying' hose to the grinder would be good.
I don't know what sort of connector is currently on it ?, can anyone identify it?. I could then get a female end to connect onto the flying lead, PCL at the other end.
Also , I could do without all the added bulk of the steel exhaust at the other end. does anyone know Biax ?, is there an alternative that is a bit more user friendly ?img_9982.jpg
David George 111/05/2017 20:15:30
2110 forum posts
565 photos
Biax is a German air tool manufacturer who make high end air tooling. The connector isn't one I have seen before should unscrew to fit PCL fitting. Look up biax-Germany.com/eng
David
Jelly11/05/2017 20:34:28
474 forum posts
103 photos
BOSTICH use those connectors too, I've always just unscrewed them and installed a standard fitting (2.99 for a pair at toolstation last time I needed some).
Ian S C12/05/2017 09:41:56
7468 forum posts
230 photos
The last time I needed a male fitting, i ended up making my own, seems to work ok.
Ian S C
Chris Shelton12/05/2017 10:43:31
92 forum posts
46 photos
Hi, I think they are called euro connectors, ebay item No.
252780579939
HTH
