Possibly a watch or clockmaker's tool
ega | 01/05/2017 14:23:22 |
2805 forum posts 219 photos | Does anyone recognize this? It was given me by a (now deceased) friend with an interest in clocks. As an indication of size beyond the rule, the no 3 hole is about 0.040". I don't think it is a gauge for measuring pearls! |
Stuart Bridger | 01/05/2017 17:45:00 |
566 forum posts 31 photos | Hmm, goes against the usual convention of larger numbers representing smaller diameters. No ides |
V8Eng | 01/05/2017 18:08:43 |
1826 forum posts 1 photos | Looks a bit like a Wire Drawing Plate to me, used for pulling annealed wire through to gradually reduce its diameter. Unfotunately I cannot remember how the hole numbering system works on those (age thing). P.S. I think there is a power tool manufacturer called Perles. Edited By V8Eng on 01/05/2017 18:37:10 |
Brian H | 01/05/2017 18:32:21 |
![]() 2312 forum posts 112 photos | Looks like a gauge for measuring wire size using something like BWG (Birmingham Wire Gauge) |
Martin Connelly | 01/05/2017 18:34:32 |
![]() 2549 forum posts 235 photos | Bead, pearl, stone gauge. Martin C Edited By Martin Connelly on 01/05/2017 18:35:06 |
Michael Gilligan | 01/05/2017 19:13:29 |
![]() 23121 forum posts 1360 photos | Posted by ega on 01/05/2017 14:23:22:
I don't think it is a gauge for measuring pearls! . But of course, it is [ well done, Martin C ] MichaelG. |
Neil Wyatt | 01/05/2017 19:42:25 |
![]() 19226 forum posts 749 photos 86 articles | Wire drawing numbers always get bigger as the holes get smaller, because they are a count of how many times the wire has been through the die. Neil |
John Flack | 01/05/2017 20:07:39 |
171 forum posts | Perles being French for pearls may confirm info above 🤔🤔 |
Brian H | 01/05/2017 20:09:40 |
![]() 2312 forum posts 112 photos | Posted by Neil Wyatt on 01/05/2017 19:42:25:
Wire drawing numbers always get bigger as the holes get smaller, because they are a count of how many times the wire has been through the die. Neil Except of course, Whitworths Wire Gauge which goes from 1 (meaning 1 thou) up to 500 (meaning 500 thou or half an inch) Brian |
richardandtracy | 01/05/2017 20:18:48 |
![]() 943 forum posts 10 photos | Why couldn't they just specify the diameter in objective units? Makes life so much easier. Regards Richard |
Brian G | 01/05/2017 20:56:37 |
912 forum posts 40 photos | Posted by richardandtracy on 01/05/2017 20:18:48:
Why couldn't they just specify the diameter in objective units? Makes life so much easier. Regards Richard Because the last thing the jewellery trade want is objective buyers? Brian |
ega | 02/05/2017 09:23:58 |
2805 forum posts 219 photos | Pearls,etc it is! Thanks to those who identified my gauge; interesting that beads, pearls and stones (diamonds) are apparently measured in the same way and difficult to see what use or ornament a no 1 pearl would be. John Flack: I was aware of the French word which, on checking, I see also means bead and howler. The absence of a maker's name suggests that it may be shop-made.
V8Eng | 02/05/2017 09:58:46 |
1826 forum posts 1 photos | Posted by Neil Wyatt on 01/05/2017 19:42:25:
Wire drawing numbers always get bigger as the holes get smaller, because they are a count of how many times the wire has been through the die. Neil Thanks Neil. I have a couple of small size plates for circular wire and one for square, for various reasons accesss is not posssible at present and I could not remember the numbering system. Edited By V8Eng on 02/05/2017 09:59:25 Edited By V8Eng on 02/05/2017 10:00:19 |
Martin Connelly | 02/05/2017 10:10:52 |
![]() 2549 forum posts 235 photos | EGA, seed pearls in jewelry are going to be about size 1. If you want even sizes then a gauge is needed. Martin C |
ega | 02/05/2017 17:39:56 |
2805 forum posts 219 photos | Martin Connelly: Thanks. I see that according to winterson.co.uk: "The famous Baroda Pearl Carpet, sold at auction by Sotheby's in 2009 for $5.5m, was covered with around 1.4 million seed pearls, all drilled by hand and sewn decoratively onto the fabric." |
Neil Wyatt | 02/05/2017 21:48:41 |
![]() 19226 forum posts 749 photos 86 articles | Those holes are almost big enough to measure the pearls of wisdom in this forum Neil |
