Aluminium cutting inserts for glanze parting tool
petro1head16/04/2017 15:11:22
984 forum posts
207 photos
can you get carbide inserts for parting Ali?
MW16/04/2017 15:54:05
2052 forum posts
56 photos
Hi, if you're talking about the MGMN 200 parting/grooving inserts then I might've been able to help you, but if not then sorry, i'm empty pockets on this one.
Michael W
Edited By Michael-w on 16/04/2017 15:55:39
petro1head16/04/2017 16:19:17
984 forum posts
207 photos
No, the blade type
John Reese16/04/2017 18:35:01
1071 forum posts
I have seen steel blades with brazed carbide inserts in some of industrial catalogs but only in sizes too large for the hobbyist lathes. You might consider grinding a notch in one of your cutoff blades and brazing in a piece of carbide.
I have seen some blades for self-grip inserts that have small shanks to retrofit the Aloris AXA and BXA parting tool holders. If Shars Tool serves the UK you could look there.
http://www.shars.com/catalogsearch/result/index/?cat=401&p=2&q=parting+blade
JasonB16/04/2017 18:39:50
There are some uncoated GTN-2 inserts about meant for Ali, think Iscar do one.
Muzzer16/04/2017 19:42:09
2904 forum posts
448 photos
I got some uncoated Korloy GTN inserts from Cutwel. These are H01 grade. It's not a very well documented grade but is described as "uncoated carbide for non-ferrous metal".
Murray
petro1head16/04/2017 21:19:59
984 forum posts
207 photos
Posted by Muzzer on 16/04/2017 19:42:09:
Murray
Cheers
Whats the most popular one, LH, RH or neutral
JasonB17/04/2017 09:06:34
I tend to use neutral
Jon18/04/2017 18:56:19
1001 forum posts
49 photos
All the major proper brand names do specific carbide inserts meant for aluminium, its what I buy 90% of the time.
Stick with neutral it will still leave a burr and can turn up to a shoulder with it and face off to length where critical measurements needed.
The Left and Right hand have always leave a burr on finished part, more so with tubular products. RH parting off generally leaves a better finish if it doesn't flex as it cuts and bows in or out.
Ian S C19/04/2017 09:47:13
7468 forum posts
230 photos
If you'r real stingy like me, you can find an old circular saw blade and cut a section out of that, ready made parting tool with carbide tip already brazed on. You may need to touch it on a green grit wheel to square off the tip. I'v got a number of blades from builder's skips.
Ian S C
Muzzer19/04/2017 10:09:57
2904 forum posts
448 photos
Posted by Jon on 18/04/2017 18:56:19:
I've not had much success finding them myself beyond the inserts I mentioned. Can you point us at some products?
Murray
petro1head19/04/2017 10:56:05
984 forum posts
207 photos
Well all I can find are the ones Muzzer pointed me to. I also found Cromwell tools sell the Iscar ones Jason mentioned **LINK** not cheap mind
Edited By petro1head on 19/04/2017 11:07:46
Roderick Jenkins19/04/2017 11:21:48
2376 forum posts
800 photos
If the OP can't find aluminium specific tips to suite may I point out the I use the general purpose coated tips in my Q-cut parting tool and these are fine with aluminium alloys provided I drip in my standard 50/50 straight cutting oil/paraffin mix. This prevents a build up on the edge, which does sometimes happen with certain alloys if I cut dry.
HTH,
Rod
petro1head19/04/2017 11:28:28
984 forum posts
207 photos
Posted by Roderick Jenkins on 19/04/2017 11:21:48:
HTH,
Rod
Thanks, found some
Jon20/04/2017 20:02:55
1001 forum posts
49 photos
Presume its the GTN ish style. does my head in manufacturers calling an industry standard insert by other labelling.
Iscar do them GFN-A looking at catalogue, got plenty of GFR plus other brand names but rarely use.
