soldering stainless steel to copper
Roger Hart31/03/2017 13:29:22
157 forum posts
31 photos
I want to soft solder (tin electrical solder) copper pipe into a stainless steel fitting for a vacuum system.
I don't know the SS grade - it came from a refrigeration supplier. I read that a phosphoric acid flux is needed but it is not obvious from looking at fleabay which if any is suitable. So, if possible a product and a source please, not too expensive either.
JasonB31/03/2017 13:36:38
Harris's "Stayclean" you can get it from CuP
Speedy Builder531/03/2017 14:52:08
2878 forum posts
248 photos
Get the flux from most hardware outlets i.e. JENOLITE rust killing liquid. It is mainly phosphoric acid which is what you need as a flux for SS. Also look up phosphoric on this site.
BobH
Nick Hulme31/03/2017 15:24:01
750 forum posts
37 photos
Hydrochloric Acid with as much Zinc as will dissolve into it (AKA Killed Spirits) is the ideal flux for soft soldering to all grades of Stainless Steel, my first batch was made for me in the laboratory at Firth Vickers Stainless Steels in Sheffield when I asked what to use for soft soldering to stainless bar.
Don't breathe the fumes as you're soldering though, use extraction, full face protection or do it in a large space/outdoors ,
- Nick
Edited By Nick Hulme on 31/03/2017 15:24:31
MW31/03/2017 15:35:54
2052 forum posts
56 photos
I'm not sure if this is true but might you need a special kind of flux to get any metallurgical bond on stainless steel, a bit in the same way aluminium can't be soldered without a very aggressive type of flux (and the appropriate solder ofc)?
Always smells like pine resin when you burn flux.
Michael W
Edited By Michael-w on 31/03/2017 15:37:07
JasonB31/03/2017 15:42:00
Posted by Michael-w on 31/03/2017 15:35:54:
Michael W
What is being suggested IS a more aggresive flux which IS suitable for stainless, from the Harris site:
"Harris Stay Brite® and Stay Brite® #8. Stay Clean is an active soldering flux. It works well on copper and brass but is more frequently used on base metals that require a more aggressive flux, such as steel, nickel, and stainless steel, (it is not suitable for aluminum or magnesium)."
The other two home brews will do the same thing.
Edited By JasonB on 31/03/2017 15:43:04
Neil Wyatt31/03/2017 15:47:59
19226 forum posts
749 photos
86 articles
That's because it's Rosin, which is made from pine resin
As for flux, bring the Fluxite Quinns back to ME!
MW31/03/2017 15:51:16
2052 forum posts
56 photos
Ah I see, you learn something new everyday, it's great to know theres a lot of fellow pyromaniacs on here who know a lot about burning (in a controlled fashion).
Michael W
julian atkins31/03/2017 22:37:34
1285 forum posts
353 photos
Hi Roger,
I would suggest silver soldering the parts.
There are specific grades of silver solder used for stainless to copper particularly for radiant superheater elements to copper tails, though I think J-M silverflo 55 would do especially in your application.
All my vacuum pipe runs have been silver soldered on miniature locos.
Cheers,
Julian
Nick_G31/03/2017 22:47:37
1808 forum posts
744 photos
Posted by Michael-w on 31/03/2017 15:51:16:
Michael W
Where id the photo of that boiler you 'constructed' Michael. ............ That was an educational masterpiece for anyone wishing to know anything about soldering. yes
Nick
MW31/03/2017 23:00:30
2052 forum posts
56 photos
Posted by Nick_G on 31/03/2017 22:47:37:
Michael W
Nick
Cheers, it's good to know you haven't forgotten me yet kiss
Michael W
Keith Hale01/04/2017 08:02:11
334 forum posts
Hello Roger
If you require only a small quantity use a suitably flux cored wire e.g. 2207.
A flux specifically for soldering stainless steel can be sent in the post.
2207 is a silver tin alloy with excellent flow characteristics to produce strong leak-tight joint with small neat fillets
It will also give a good colour match on your stainless.
It is readily available
For more info **LINK**
Keith
Clive India01/04/2017 10:21:35
277 forum posts
Posted by julian atkins on 31/03/2017 22:37:34:
Hi Roger, I would suggest silver soldering the parts.There are specific grades of silver solder used for stainless to copper particularly for radiant superheater elements to copper tails, though I think J-M silverflo 55 would do especially in your application.All my vacuum pipe runs have been silver soldered on miniature locos. Cheers, Julian
Very much agree.
Nick Hulme01/04/2017 11:13:32
750 forum posts
37 photos
If the joint needs to be more structural than can be achieved with soft solder then a hard solder would be advisable, if not then the max it can be subjected to is 14.5psi so anything with greater tensile strength than that of used chewing gum would suffice
Roger Hart02/04/2017 07:05:14
157 forum posts
31 photos
Thanks for the advice all. I have some Jenolite and also a tin of Fry's is lurking somewhere. Will give it a try.
colin hawes02/04/2017 09:52:16
570 forum posts
18 photos
I have soft soldered copper wire to stainless steel by "tinning" the stainless with silver solder first. Colin
