Newby machine help please
Marc Jonah10/02/2017 21:51:20
15 forum posts
6 photos
Hi all, I'm a bit new to this lathe lark but being a farmer I need one every now and again for repairs etc.. I bought a cheap Mitchell lathe from eBay and want to do some threading on it but I can't make out how to set the gears, I'll attach some pic and probably some of you may be able to point me in the obvious (but not to me) direction please. I'm not sure if I'm missing some more gears or whatever but I've trawled the Internet and looked for a manual etc for the machine but to no avail... Any help will be great fully received.
Marc
Marc Jonah10/02/2017 21:51:56
15 forum posts
6 photos
pics in album
Edited By Marc Jonah on 10/02/2017 22:04:07
David George 110/02/2017 21:55:26
2110 forum posts
565 photos
Post the pictures in an album and then anyone can see them if you like.
David
Marc Jonah10/02/2017 21:58:02
15 forum posts
6 photos
Many thanks David, I've just done that. I think.
Nick_G10/02/2017 22:07:30
1808 forum posts
744 photos
Hello Marc,
Where in the country are you.? Somebody may be able to show you.
Edit :- Just looked at your previous posts. I see you are in south Wales.
Nick
Edited By Nick_G on 10/02/2017 22:08:45
David George 110/02/2017 22:49:58
2110 forum posts
565 photos
Hi Marc You can look up Woodhouse Mitchell lathes on Lathes.co.uk web site ( Tony's lathes)
David
Marc Jonah10/02/2017 22:52:17
15 forum posts
6 photos
Cheers David, I have emailed to you about it and he sent me what he had but wasn't the same as my lathe, I sent him some pictures back but didn't hear anything further.
Hopper10/02/2017 23:34:25
7881 forum posts
397 photos
It looks like to cut imperial threads (Threads per Inch) you can just use the levers set as per the chart next to them.. Then to cut metric threads, you have to position the levers and the extra change gears as per the extra metric square chart attached to the machine. The abbreviations on that chart mean "Driver" being the first gear in a meshing pair, the one on the lathe spindle that drives the next gear in the train and so on, and "Driven" meaning the gear that comes second in the pair and is driven by the other gear, eg the gear on teh leadscrew or the gearbox input shaft.
Confusing in writing I know. Would be nice if you could get someone over to show you the ropes in person.
Simon Williams 311/02/2017 00:11:26
728 forum posts
90 photos
Could you post a picture of the left hand of the headstock - end on so we can see the gear train please. You've took the cover off, and there is a picture of some of the gears but the rest are lost in the shadows.
Thx Simon
Marc Jonah11/02/2017 07:58:45
15 forum posts
6 photos
Many thanks, I've just added another picture side on in which you will see the only 4 gears I have which are 63-60-42-40.
Cheers
Marc
Marc Jonah11/02/2017 08:00:22
15 forum posts
6 photos
Posted by Marc Jonah on 10/02/2017 22:52:17:
Sorry David this was meant to say "I have emailed Tony about it"
Scrumpy11/02/2017 08:52:25
152 forum posts
Hi After looking at your pictures I think it's the same as mine it's a 8 1/2 X 10 or 12 lathe as per the gearing mine is set up for imperial screw cutting the gears on the end are 40 - 60 - 40 looking at the front panel the top 3 leavers are for speed the 1 next down is for travice
The 2 leavers on the angle are for feed and cutting imperial threads there are to figures one on top of each other top for threads bottom for feeds
3 leavers below are 2 on left feed and screw cutting 1 on the right to engage lead screw panel on the end is for metric you have got in my mind a very good lathe
Bazyle11/02/2017 09:34:15
6956 forum posts
229 photos
The label seems to suggest different gears on the end for imperial so with a 63 on the banjo it is probably set for metric. Can't see on the label what it says. Try cleaning the labels and posting new pictures.
The first thing would be to set for say 1mm and put a piece of plastic water pipe in the chuck. Use this to scratch a thread, no need even to cut, and see if it measures up to the setting to prove the end gears are right.
Edited By Bazyle on 11/02/2017 09:38:23
Bazyle11/02/2017 10:00:03
6956 forum posts
229 photos
When setting the two top levers 13N57 etc make sure the other lever is in N or the gearbox will jam.
The lower levers AB, CD are each power of two ie doubling the mitch which can work together to give a power of 4.
When looking at the metric table as said above the gears go spindle/banjo/banjo/gearbox or as written Driver/driven/driver/driven with the two middle ones on the same axle so you are getting two stages of reduction.
Did you get any loose gears? like another 40 and a 48?
Neil Wyatt11/02/2017 10:06:05
19226 forum posts
749 photos
86 articles
You can put album pictures into a post using the black camera icon in the 'post a reply' box.
Marc Jonah11/02/2017 10:06:56
15 forum posts
6 photos
This is what I presumed but, I didn't get any other gears with it so it wasn't making any sense to me. I'll set the gears I have to match one of the metric threads and give it a go. Thanks for your help all, I really appreciate it. Do you have any pictures of yours scrumpy?
Scrumpy11/02/2017 10:47:50
152 forum posts
Hi I have just been to the workshop and checked to make sure you are given the correct information
The 2 middle levers feed and screw cutting are numbered LH 5-1-N -3-7 RH 6-2-N-4- blank the bottom leavers are marked LH- B - A RH -D-C with the other lead screw
To cut a thread of 30 tpi the gearbox should be set to 3-BD on levers 40 driving intermediate 60 driven
40 tpi gearbox 3-BD with 30 driving intermediate 60 driven
10 MM Pitch 3-AC on gearbox with 45 driven to a 60 intermediate 63 second intermediate to 48 driven
A full set of gears are 30 40xtwo 42 44 45 46 48 57 60 63 80
hope this helps
Russell Eberhardt11/02/2017 11:25:08
2785 forum posts
87 photos
With that combination of gears it looks as if it's set up for 1¾, 3½, 7, and 14 mm pitch. Not very usefulsad
Russell.
Bazyle11/02/2017 11:27:18
6956 forum posts
229 photos
Scrumpy, next time you are out there best measure the DP of the gears and hole/keyway details. Looks like Marc will have to get another 40 from Devall or somewhere for the imperial side.
Marc Jonah11/02/2017 12:12:16
15 forum posts
6 photos
Thanks guys, I suppose I'm now in search for a full set of gears, now possibly the silly questions bit.... are bit like this still available or are you suggesting having them made?
Thanks
Marc
