Lathe advice please
Steve Williams 821/01/2017 10:06:20
5 forum posts
Good morning, I am new to the forum and look forward to reading all the posts and information you have. I am a blacksmith by trade and repair shotguns and rifles (legally) too. I am looking for a lathe which is capable of screw cutting and has a spindle diameter of at least 35mm. Would you mind advising me of the type of machine I should be looking for?
Kind regards
Steve
Neil Wyatt21/01/2017 18:49:00
19226 forum posts
749 photos
86 articles
Hi Steve is that internal or external diameter (I'm assuming internal, although that's quite big)?
What sort of between centres distance and are you likely to prefer new or secondhand?
MW21/01/2017 18:53:04
2052 forum posts
56 photos
Without the first question answered i'm taking a bit of a shot in the dark here but I think for a reasonably priced, import new lathe i'd try warco.
If you have experience buying from the far east then you could probably get one even cheaper by buying direct from china, unlabelled of course.
Michael W
Steve Williams 821/01/2017 19:17:07
5 forum posts
Hi Neil and Michael, I would like the internal shaft diameter to be around 35mm as that will cater for a rifle barrel at the chamber end if required. At least 30" between centres would be good. I would like a used British machine, I repair old British guns, they are the best in the world. I don't even eat Chinese food but thanks for your advice Michael.
Kind regards
Steve
David George 121/01/2017 19:27:36
2110 forum posts
565 photos
Hi Steve I don't know where you live but the local machine sales has some ex collage lathes, Colchester Students, in which would possibly do what you want. It is Premier Machine Tools Blidworth Nottinghamshire. I am not connected to the company in any way but its worth looking at.
David
Michael Gilligan21/01/2017 19:35:25
23121 forum posts
1360 photos
Steve,
I was going to suggest a Colchester Chipmaster ... but they're a mere 20" between centres sad
The Master 2500 long bed would meet your spec. **LINK**
http://www.lathes.co.uk/colchester/page17.html
... it's a big, expensive, machine though !!
[My Dad ordered one of the first few, when he set-up a workshop at Lancaster University]
Ajohnw21/01/2017 19:38:09
3631 forum posts
160 photos
I assume the OP means 35mm clear bore too. However ?
If so maybe a modern Boxford with a bed length to suit or even a TS if extreme alignment accuracy is needed.
Edited By Ajohnw on 21/01/2017 19:40:03
Andrew Johnston21/01/2017 19:48:18
7061 forum posts
719 photos
Or a Harrison M300 long bed, but they're not cheap. sad
Chris Evans 621/01/2017 19:49:25
2156 forum posts
I have a Taiwanese copy of a Harrison M300. 14" swing and 40" between centres with a 40mm spindle bore, over 20 years old now and still does all I ask of it. I ruled out some good British lathes like Colchester students as some I looked at only had 1" or 1 1/4" spindle bore. Good luck with the search, let us know how you get on.
Michael Gilligan21/01/2017 19:55:48
23121 forum posts
1360 photos
Posted by Ajohnw on 21/01/2017 19:38:09:
I assume the OP means 35mm clear bore too..
A reasonable assumption, John ... given that Steve pretty-much confirmed that ^^^
[quote]
... I would like the internal shaft diameter to be around 35mm as that will cater for a rifle barrel at the chamber end if required. At least 30" between centres would be good. I would like a used British machine, ...
[/quote]
Carl Wilson 421/01/2017 19:58:03
670 forum posts
53 photos
Harrison M250.
JasonB21/01/2017 20:15:05
Why go with the training lathe if more accuracy is required, its the TR toolroom one that is the better spec as I have said to you before
Phil S21/01/2017 20:27:48
29 forum posts
7 photos
I will be listing a 7" Drummond (14" swing) shortly in the classifieds. There was an article in the ME some time ago about a Bath gunsmith who used one of these. It is of course only a few years off being an antique so does not meet the machinery directive if you are a business !
Ajohnw21/01/2017 20:36:31
3631 forum posts
160 photos
I said TS if extreme alignment accuracy is needed Jason. There is a fair difference in price and several different specs of the other as well some of which would probably gobble up some of the differences. As I understand it TS means toolroom spec and the main difference apart from gearbox options that by the look of it can be applied to all of them is high precision bearings. On these models if screw cutting is needed it's best to note that there are options. Some need way more change wheels than others. I haven't seen an imperial version of this machine and that aspect might be important for easier screw cutting.
I think the cam lock VSL would meet the spindle bore needs as well. Lathe co uk should clear that up. The earlier one probably doesn't.
MG might note that the bore aspect was mentioned after I started to post. I went away for a while just after starting it. Not that an unusual thing for me to do.
blushPerhaps I have the TS wrong. I'd need to check.
JasonB21/01/2017 20:42:00
Just read what I wrote above, twerp
"its the TR toolroom one that is the better spec"
Ajohnw21/01/2017 21:26:55
3631 forum posts
160 photos
Posted by JasonB on 21/01/2017 20:42:00:
Bit of a waste of time posting that.
Actually I was being a bit tongue in the cheek when I posted that one, thinking new and added the VSL as an after thought.
Really with questions like this size of work, budget and use is needed, Given that there will be a number of machines that would suite including many that wont even get a mention in real terms generally condition and if the accessories that may be needed are likely to be obtainable are the most important aspects. Also the fact that some machines that are available might come with all of them.
In this case imperial based screw cutting might be a good idea as well.
smiley Having shot a number of different types and ages I'm curious about which guns?
Michael Gilligan21/01/2017 21:50:41
23121 forum posts
1360 photos
Posted by Ajohnw on 21/01/2017 20:36:31:
Happy to believe you, John ... but remember:
I can't see when you started to post; only when you posted.
Ajohnw21/01/2017 22:01:44
3631 forum posts
160 photos
Posted by Michael Gilligan on 21/01/2017 21:50:41:
winkI know Michael but it's something worth bearing in mind. Rather extreme but I have even gone out for a while mid post. Unlike some seem to think at times I don't spend all day sitting at this machine. There are certain times of the day when I have a look around but the time spent on here is extremely variable.
John Bromley21/01/2017 22:06:07
84 forum posts
My suggestion would be a Colchester Triumph 2000, a nice big chunky beast, lots of distance between centres and a comprehensive and easy to use threading gearbox. I use one most days at work. They are a nice machine capable of repeatable precision work, with capacity to do some larger work. I think the through bore is about 3" maybe just less.
I just checked it's 55.5mm bore. The short bed model is 30" and the long bed is 50" between centres.
Edited By John Bromley on 21/01/2017 22:06:35
Edited By John Bromley on 21/01/2017 22:15:18
Neil Wyatt21/01/2017 22:34:16
19226 forum posts
749 photos
86 articles
The Colchester Triumph is a BIG lathe, one would effectively fill my workshop, I think!
Once you are past 'bench lathe' size secondhand prices don't go up as much as you might expect, presumably because there's much less demand.
Prices seem to start at around £3k up to £7k, I imagine good cheap ones will go relatively fast.
Your probably talking about £3K for an imported lathe of slightly smaller overall size but the capacity you need (38mm bore, 910mm between centres). If the latter you would would be looking at what could be described better as 'small industrial' rather than 'large hobby' lathes so probably just Warco & Chester to look at from the 'usual suspects'.
