Chris Evans 6 | 14/01/2017 16:09:59 |
![]() 2156 forum posts | I am making some rear wheel spindles for a motorcycle that have a 1/4" diameter tommy bar fitted about 2.5" long. The spindles are EN16T, I need a recommendation for something that will not easily bend and do not want to use silver steel as they will be brazed in situ. |
Michael Gilligan | 14/01/2017 17:32:27 |
![]() 23121 forum posts 1360 photos | Re-purpose a decent quality screwdriver blade MichaelG. . Edit: is brazing essential ? ... Loctite 638 is very effective. Edited By Michael Gilligan on 14/01/2017 17:34:31 |
duncan webster | 14/01/2017 18:19:32 |
5307 forum posts 83 photos | The carbon equivalent of EN16 is well above the 0.4% above which you've got to think carefully before doing any hight temperature processes. I'd stick with Michael's suggestion of loctite, or even a press fit (make one end of tommy bar a few thou small so you don't have to press it all the way) |
vintagengineer | 14/01/2017 18:38:11 |
![]() 469 forum posts 6 photos | You could use EN16t and put a straight knurl in the middle. |
Chris Evans 6 | 14/01/2017 20:40:28 |
![]() 2156 forum posts | Thanks for the responses. I do not want to use Loctite due to the item being nickle plated after finishing. What I did not mention is the tommy bar only sticks out one side by the two and a half inches, hence the concern about it bending. I can drill and tap the hole and bottom the thread to make secure and not braze. With six to make the screwdriver idea does not stack up but a good choice of steel. |
David George 1 | 14/01/2017 21:00:17 |
![]() 2110 forum posts 565 photos | Have you thought of using a 5/16 dia bar and turning the location down to suit the hole in the spindle. With a small chamfer in the hole you can peen the end of the pin and making it permanent and stronger. You can do with out any heating and Brazing. David |
Ian P | 14/01/2017 21:04:30 |
![]() 2747 forum posts 123 photos | Something does not sound right here. This Tommy bar is in the spindle or nut that holds the rear wheel in place? It could be described as being safety related. If its a full size roadgoing bike then the EN16T is going to be (say) 12mm diameter and you are looking to tighten the thread with a thin rod 'spanner' with minimal leverage. Even if you extend the Tommy bar with a length of tube I imagine the bar would bend when the correct torque is applied. I dont know how fine the thread pitch is, or I may have I misunderstood the requirements? Ian P
MW | 14/01/2017 21:22:38 |
![]() 2052 forum posts 56 photos | EN8?...n" case harden if need be? Edited By Michael-w on 14/01/2017 21:23:10 |
Ian P | 14/01/2017 21:32:59 |
![]() 2747 forum posts 123 photos | Just reread the OPs posts and see that the spindle is going to be Nickel plated. I thought plating (or electroplating anyway) was not used nowadays on highly stressed vehicle components because of Hydrogen embrittlement. I know for certain that some vehicle manufacturers will not use plated bolts at all. Ian P
MW | 14/01/2017 21:34:00 |
![]() 2052 forum posts 56 photos | Posted by Ian Phillips on 14/01/2017 21:32:59:
Yeah, I thought they mainly used blacking rather than plated material. |
David George 1 | 14/01/2017 21:46:17 |
![]() 2110 forum posts 565 photos | I was involved in frame manufacture for racing motorcycles and saw a frame that had been nickel plated fracture at the headstock, but all other frames which were plated with cadmium had no problems. And all the wheel spindles engine plates etc were cad plated similarly as there is no noticeable change in dimension where as the thickness to nickel has to be taken into account. David Edited By David George 1 on 14/01/2017 21:47:35 |
vintagengineer | 14/01/2017 22:13:49 |
![]() 469 forum posts 6 photos | Could use threaded cap head screws. You can get these in 14.8 grade and with long plain shanks. |
Mike Poole | 14/01/2017 22:14:14 |
![]() 3676 forum posts 82 photos | Chrome vanadium is an ideal steel for Tommy bars as used in socket sets etc. I used a surplus t bar from a socket set as the Tommy bar on the vice of my automatic hacksaw, it is not going to bend unless 3ft of scaffold pole is used on it. Might be difficult to adapt to you application though. Mike |
Michael Gilligan | 14/01/2017 22:14:55 |
![]() 23121 forum posts 1360 photos | Very interesting note, David ... Thanks It's a pity that Cadmium plating seems to be verboten these days. MichaelG. |
Ian P | 14/01/2017 22:29:30 |
![]() 2747 forum posts 123 photos | Posted by David George 1 on 14/01/2017 21:46:17:
I was involved in frame manufacture for racing motorcycles and saw a frame that had been nickel plated fracture at the headstock, but all other frames which were plated with cadmium had no problems. And all the wheel spindles engine plates etc were cad plated similarly as there is no noticeable change in dimension where as the thickness to nickel has to be taken into account. David Edited By David George 1 on 14/01/2017 21:47:35 Presumably if the frames were Cadmium plated, it was quite a long time ago. Cadmium plating is now used only in very special (military?) purposes. Ian P |
vintagengineer | 14/01/2017 23:00:23 |
![]() 469 forum posts 6 photos | Cadmium plating also causes titanium to develop titanium embrittlement which will cause failure. |
daveb | 14/01/2017 23:34:52 |
631 forum posts 14 photos | The wheel nuts on Vincent motorcycles had/have captive tommy bars, never had one fall off. |
Michael Briggs | 14/01/2017 23:51:15 |
221 forum posts 12 photos | Posted by Michael-w on 14/01/2017 21:34:00:
Yeah, I thought they mainly used blacking rather than plated material. Out of interest, which manufacturers use blacking. |
Chris Evans 6 | 15/01/2017 09:32:29 |
![]() 2156 forum posts | Right it is time for some more info on the job. I am making these for a mid 1920s machines and all I want to do is copy the original design. The reason I asked about material is the desire to fit something that will not easily bend, the main securing nut is released from the opposite end and the tommy bar used to twist and pull the spindle clear. As for plating we can always use chrome on a lightly vapour blasted surface. |
vintagengineer | 15/01/2017 10:56:56 |
![]() 469 forum posts 6 photos | If you screw the bar in you could lock them using solder paste, this was the method before Loctite. Clean both threads, coat with solder paste, assemble and the heat to melt the solder. Soft solder will take chrome or nickel plating. The solder paste will much stronger than any loctite available. |
