Myford ML7 countershaft hard rubber bushings source?
Hopper13/01/2017 12:34:24
7881 forum posts
397 photos
Does anyone know a source or alternative for the hard rubber bushings used on the Myford ML7 countershaft? As far as I can tell from the grunge encased remains of of the ones I have, all they do is support the belt cover so I suppose one could turn up something from Delrin etc if need be. But just wondering if something is available off the shelf as workshop time is severely limited these days. Myford don't list them (and I don't want to take out another mortgage).
John Flack13/01/2017 13:18:13
171 forum posts
Know nothing about Myfords, but hard rubber suggests ebonite! The same material that my clarinet is made of. A musical instrument maker/repairer tinkers with the material making bespoke barrels a small section below the mouthpiece..............just a thought that may help??????????? John
John Flack13/01/2017 13:18:14
171 forum posts
Martin Kyte13/01/2017 13:56:37
3445 forum posts
62 photos
Do you mean like this.
They are admittedly under the Super 7 Headstock section. I'm sure they will tell you if they are the same as the ML7 if you give them a bell. £3.60 each is quite cheap for a mortgage.
regards Martin
MW13/01/2017 14:26:00
2052 forum posts
56 photos
Hi Hopper,
PM sent.
Michael W
Rick Kirkland 113/01/2017 14:53:35
175 forum posts
They're not hard rubber or delrin and particularly not ebonite. They are pliable rubber used to prevent vibration of the belt guard. The super 7 does not have them.
mark smith 2013/01/2017 15:04:18
682 forum posts
337 photos
Well they are called hard rubber bushes in the exploded view diagram ,part no. F12 A1227
Edited By mark smith 20 on 13/01/2017 15:05:40
Mike Crossfield13/01/2017 15:40:01
286 forum posts
36 photos
When I was rebuilding an ML7 about 20 years ago I ordered up a pair of these bushes from Myford. When they arrived I was surprised to find they were soft rubber. I also discovered that they didn't appear to fit. After dialogue with Myford I learned that they were not fitted to very early models, and that they were a later mod. to reduce rattles. I may still have them, and if so you can have them for a modest donation if you can't source elsewhere.
Michael Gilligan13/01/2017 15:49:56
23121 forum posts
1360 photos
For the record ... Popular Spare Parts: **LINK**
http://www.usinages.com/attachments/ml7-spare-parts-myford-2010-pdf.43036/
Myford [Beeston] January 2010
Georgineer13/01/2017 16:56:42
652 forum posts
33 photos
I have a pair of unused ones which only cost me half a mortgage. I can post dimensions if you wish. They could be cut out of a thick rubber disc using the techniques in Sparey's The Amateur Lathe. The only other possibilities are to wait for a pair to come up on epay, as I did, or get some made. They are described as flanged rubber bushes (or top-hat bushes) but I couldn't find a standard part of the right dimensions. I'm sure somebody could get a batch made by such as grommets.co.uk and sell them on at a profit.
George
Edited By Georgineer on 13/01/2017 16:57:24
Gordon A13/01/2017 17:29:12
157 forum posts
4 photos
I take it that the bushes mentioned are to hold the belt cover in the raised position when changing speeds.
My solution was to wrap thin string around the shaft between the bearing housing and what was left of the flange on the rubber bush in order to press the flange against the cover.
Worked ok for me.
Gordon.
Rick Kirkland 113/01/2017 17:37:34
175 forum posts
They are anti rattle bushes. Nothing more , nothing less.
Hopper13/01/2017 20:23:06
7881 forum posts
397 photos
Thanks for the good input guys and the several kind offers. It looks like I have the problem sorted. I shall post pics of the lathe later today when have time. Pretty sad state. In fact, the most abused lathe I have ever seen. If I give it a name it should be the Hesperus , as in The Wreck of. But the bed is virtually unworn, under all the hacksaw marks, chuck drop marks, job drop marks and ball peen hammer marks. Yes, ball peen hammer marks. It's hand tools should be licensed not guns. So the son and I should be able to tidy it up and maybe find something useful under all the grunge.
Edited By Hopper on 13/01/2017 20:24:22
Edited By Hopper on 13/01/2017 20:25:25
Chris Evans 614/01/2017 10:34:23
2156 forum posts
I tend to look up Polybushes for this sort of thing. May be of use when looking for rubbery stuff.
Clive Hartland14/01/2017 11:02:31
2929 forum posts
41 photos
I have used those grey felt self adhesive pads.easily replaced and cheap. Pound shop stuff!
