Foam parts storage
High density foam supplier.
RRMBK03/01/2017 16:09:28
159 forum posts
18 photos
Hi All.
can anyone point me in the direction of a cheap source of the sort of high density foam used in camera cases, airline transport cases etc . I want to create some small ( 1/2" X1"x 1 " up to about 3 x 3 x6 inch cut outs to safely store some wooden patterns for the long term . I would like to get the foam first and then make the boxes from plywood at a size to suit each batch of patterns.
Also what is the generic or trade name of this stuff. I have managed to successfully cut a few storage cutouts in Kingspan type expanded polystyrene stuff but the surface finish is poor because the composition is such that it doesn't come away cleanly.
Thanks
BK.
Neil Wyatt03/01/2017 16:27:15
19226 forum posts
749 photos
86 articles
Hello BK,
I suggest this company, I've done a lot of research into foam over the last couple of months (don't ask!) and they have fair prices a custom cutting service and a huge range (although they don't stock one specialist foam I need!)
The pick and pluck looks expensive, until you realise that you get five cases worth...
www.easyfoam.co.uk/pick-n-pluck-foam.php
Michael Gilligan03/01/2017 16:42:15
23121 forum posts
1360 photos
Plastazote is the name you want, BK
http://www.zotefoams.com/product/azote/plastazote/
... available from Neil's suggested supplier, amongst others.
Edited By Michael Gilligan on 03/01/2017 16:45:29
David Jupp03/01/2017 17:16:40
978 forum posts
26 photos
Very interesting process for 'putting the bubbles' into Plastazote and its relatives, Lots of Engineering involved!
Bazyle03/01/2017 18:12:55
6956 forum posts
229 photos
You could check local upholsterers and cushion makers for offcuts perhaps. They don't just do the yellow inflammable stuff anymore.
Neil Wyatt03/01/2017 18:28:12
19226 forum posts
749 photos
86 articles
Posted by Bazyle on 03/01/2017 18:12:55:
That's where I started... but not where I ended up!
Michael Gilligan03/01/2017 18:40:54
23121 forum posts
1360 photos
Posted by RRMBK on 03/01/2017 16:09:28:
.... I want to create some small ( 1/2" X1"x 1 " up to about 3 x 3 x6 inch cut outs to safely store some wooden patterns for the long term . I would like to get the foam first and then make the boxes from plywood at a size to suit each batch of patterns.
Plastazote is perfect for this ^^^ sort of job ... it cuts cleanly and easily, and layers can be glued together with contact-adhesive ... it doesn't degrade to sticky mush like some other foams, and it's closed-cell [so doesn't take-in water].
If the patterns are worth keeping, they are worth the modest investment involved in using good material. ... It's used in a lot of military packages [and I've tested a fair few of those].
Vic03/01/2017 19:17:07
3453 forum posts
23 photos
There is Kaizen foam as well.
Roy M03/01/2017 20:28:49
104 forum posts
7 photos
Have you considered using expanding polyurethane foam? Donkey's years ago the toolroom I worked in used this for storing broaches. Finished off with a few coats of PVA glue. Roy M.
Neil Wyatt03/01/2017 21:15:24
19226 forum posts
749 photos
86 articles
Just for reference this is cheaper cell polyethylene foam like Plastazote.
www.easyfoam.co.uk/closed-cell-polyethylene-foam.php
They also do Plastazote:
www.easyfoam.co.uk/zotefoam-plastazote.php
Usual disclaimer, I'm just a satisfied customer
Geoff Theasby03/01/2017 21:20:36
615 forum posts
21 photos
David, one of the Green Ink brigade near my previous residence once claimed to have invented a rigid foam containing 'bubbles of vacuum', which would be lighter than air and so revolutionise transport. Word is that he sent a sample to the Patent Office, but it floated up to the top of the post box and the postman never found it!
Geoff
Neil Wyatt03/01/2017 22:21:19
19226 forum posts
749 photos
86 articles
Posted by Geoff Theasby on 03/01/2017 21:20:36:
Geoff
Isn't that what Amazon are using to make the flying warehouses for their delivery drones
N.
RRMBK04/01/2017 09:06:47
159 forum posts
18 photos
As always a great response from great people. . Thank you all very much - I can now plug on with this years project leaving behind all the others in their usual stages of incompleteness and disarray !!
Kind regards and have a successful 2017
Ian S C04/01/2017 09:28:57
7468 forum posts
230 photos
You might find closed cell foam at a boat yard, it's used in boat hulls, inbetween two layers of fiberglass or carbon fiber.
Ian S C
Brian Oldford04/01/2017 09:45:24
686 forum posts
18 photos
Posted by Ian S C on 04/01/2017 09:28:57:
Ian S C
Why not try Celotex Insulation Board? Several of the DIY sheds stock it and it's reasonably priced.
pgk pgk04/01/2017 17:43:14
2661 forum posts
294 photos
I recall seeing a youtube vid a while back where soemone wanted a quick way of making up some tool boxes and just sprayed expanding foam ito the raw box, put a layer of old t shirt on top. addd the tools and a board & weight over the lot while it foamed up and set. It looked suprisingly efficient and neat. Filed away in memory but never tried it myself
RRMBK25/02/2017 14:49:16
159 forum posts
18 photos
Thanks Everyone for your advice, the pick and pluck has done the job wonderfully and there is an added bonus for a tightwad like me, - if you take all the bits you have " plucked " out and stick them to the bottom of your box, or a baseboard; with spray-mount adhesive you get to use all those pieces as an extra new section of pick & pluck.
Thanks once again.
