Vic | 11/12/2016 17:12:27 |
3453 forum posts 23 photos | This is an interesting concept for con rods that I've not heard of before. About six minutes in if you can't wait. |
mark costello 1 | 11/12/2016 18:00:42 |
![]() 800 forum posts 16 photos | EXCELLENT! |
Tim Stevens | 11/12/2016 18:32:51 |
![]() 1779 forum posts 1 photos | I remember reading about conrods made this way back in the 1970s. This was (from memory, never a reliable resource) for Mercury outboard engines made in the USA. These were two-stroke engines, needing roller big-ends, and the cracking idea allowed assembly onto a one-piece crankshaft rather than the traditional way which used built-up cranks. So, well done the Japanese, for re-discovering a technique and (I am guesssing) applying it to four-stroke engines too. In this application, the cracking technique should eliminate any tendency for the two halves of the rod to shuffle at high revs, and so extend the life of the bearings (etc). And of course, it prevents the village craftsman filing the ends of the rod to take up the, er, slack, when rebuilding an old engine. They didn't used to do that, did they grandad? Wasn't that a bit naughty? Regards, Tim |
Speedy Builder5 | 11/12/2016 18:38:26 |
2878 forum posts 248 photos | Did you see that big hammer press jump! We had some big presses at Weybridge and they sat on blocks of rubber about 2 feet thick to damp the shock waves from them as the wealthy, living across the road at St Georges Hills weren't best pleased when their china cups jumped about on their tables. |
Neil Wyatt | 11/12/2016 18:56:19 |
![]() 19226 forum posts 749 photos 86 articles | What happened to my post? They were patented in 1951 and have long eben used in performance cars, but apparently they are now becoming more common in ordinary ones. Neil |
HOWARDT | 11/12/2016 19:50:33 |
1081 forum posts 39 photos | I remember back in the 80's designing fixtures to the pre ops and finishing after breaking but can't remember who is was for other than it was in the UK. Have to look back in my diary. |
the artfull-codger | 11/12/2016 20:12:41 |
![]() 304 forum posts 28 photos | Well done Vic, really interesting, the company I worked for had a rolling mill in darlington [darlington & simpson rolling mills rise car darlington] when we did work there we used to watch the blacksmiths making tongs/tools for handling the rolled sections,I still have a couple of pairs that I use in my foundry. The roll turners had lathes that they knocked wedges in to feed the tool in to turn the rolls instead of handwheels. |
Howard Lewis | 11/12/2016 20:59:27 |
7227 forum posts 21 photos | Perkins were using fracture split con rods before I retired over 13 years ago. The process should ensure complete mating of cap to rod, before machining the parent bore for the bearings. Howard |
JA | 11/12/2016 22:59:07 |
![]() 1605 forum posts 83 photos | I thought Peugeot used such rods. JA |
clogs | 12/12/2016 19:05:52 |
630 forum posts 12 photos | Hi All, anyone know what the lumpy powder looking stuff is that was thrown into the hub center when forging..... Grahite for lube....? do we still make forgings in the UK? thanks Clogs |
Nick_G | 12/12/2016 19:47:10 |
![]() 1808 forum posts 744 photos | . Was was watching a doc only last week of them making the new(ish) Corvette Stingray. They were cracking the conrods on the engines for those. Nick Edit :- Had a look to see it it was on youtube. It was. Go in to about 6 mins 20 secs. Edited By Nick_G on 12/12/2016 19:50:09 |
vintagengineer | 17/12/2016 21:01:00 |
![]() 469 forum posts 6 photos | Yes there is a company in Sheffield that forge tank wheels.
Posted by clogs on 12/12/2016 19:05:52: Hi All, anyone know what the lumpy powder looking stuff is that was thrown into the hub center when forging..... Grahite for lube....? do we still make forgings in the UK? thanks Clogs
