Thrust washer
Wolfie05/11/2016 14:48:05
502 forum posts
OK can anyone explain to me in words of one syllable what a thrust washer is?
If you talk about 'axial forces' you will have already lost me lol crook
Howard Lewis05/11/2016 15:11:20
7227 forum posts
21 photos
A Thrust Washer takes the force along a shaft (The axial force).
In the case of a lathe, it takes the load trying to push the Mandrel out of the back of the Headstock when you are taking a cut along the bed towards the Headstock. If the lathe has Taper Roller Bearings in the Headstock, these not only locate the mandrel radially, but also take the thrust.
Could take the form of a washer, (Bronze, Phosphor Bronze, Brass, Nylon, etc) or a bearing with needle rollers disposed radially, sandwiched between two hardened steel washers. These, in turn bear against a face of the housing.
Your car engine will have thrust washers between faces on the crankshaft and the crankcase, to take the thrust when you depress the clutch pedal.
In a ship, the thrust of the propellor against the hull used to be taken by thrust blocks made of wood, (Lignum Vitae)
Tim Stevens05/11/2016 15:51:20
1779 forum posts
Axial means in line with the axle, and radial means in line with a radius. So, as Howard says, a thrust bearing copes with axial loads or forces or pushes or pulls along the axle, spindle, shaft, etc.
It does seem an odd term when you think that ALL bearings* are intended to resist thrust, why pick on axial ones to pin the name to? But I suppose its the same as electric motor 'brushes' which are solid lumps, and 'analogue' clocks that go round in identical jerks and have hands ...
* PS not compass bearings, though!
Regards, Tim
Edited By Tim Stevens on 05/11/2016 15:52:37
not done it yet05/11/2016 16:16:22
7517 forum posts
20 photos
Words with more than one syll-ab-ul folks. Try it like this.
It is the thing used at the place where the force of the cut (for a lathe), or the load on the end, is thwart in the line of the axis of a round bar while it is spun (or it could be still and pushed, I dare say).
The force on a shaft while it turns by a belt drive would be like a spoked line of force which bears on the side of the thing in which it runs (on which the shaft slides). This force must be pushed back by a force of the same size, too.
All force must be the same in all lines or the shaft would move. These two are at right bend to each and each can be more boss at any one time.
Edited By not done it yet on 05/11/2016 16:17:28
Bob Brown 105/11/2016 16:55:28
1022 forum posts
127 photos
Posted by Howard Lewis on 05/11/2016 15:11:20:
I've never seen a ships propeller thrust block in wood but have seen propeller shafts in wood bearings. Normally the loads are carried in thrust block that has a series of pads that have a pivot on them to allow an oil film between them and disc on the shaft.
Wolfie05/11/2016 17:07:52
502 forum posts
OK so how does simply putting a washer on a shaft create this counter force? Wont it just slide on the shaft?
Bob Rodgerson05/11/2016 17:14:05
612 forum posts
174 photos
It would be made to bear against shoulder on the shaft.
Tim Stevens05/11/2016 17:31:31
1779 forum posts
The washer will not create anything - sorry. This is a difficult question to answer, Woolfie, not because the science is hard but because I do not know where you are starting from. If I make assumptions (such as that you know about Newton's Laws of force and motion) then you might struggle if you are not up to speed on the science, but if I really do start from square one, you are likely to consider me a patronising old fart.
Basically, look at a boat propeller, and this turns, providing a force trying to push the boat forwards. This force happens because the propeller is pushing the water backwards. What stops the force back from the water from pushing the propeller shaft into the boat? Well it has to have something to push against. And to stop this thing (whatever it is) from wearing out as the prop shaft pushes against it, we add a device designed to resist the force without wearing out. This 'thing' is called a thrust bearing. It holds the prop shaft in place (up and down and side to side) so the water does not get into the boat, but its main job is to resist the push of the prop shaft.
In practice, a shoulder on the shaft might push against a washer fitted to the boat - this is a very basic thrust bearing. But the turning combined with the continuous force will wear it out, so we try oil and grease - which are an improvement. But the turning action squeezes out the lubricant, and the continuous force does not allow any slack to allow more lube in. So, special self-lubricating material (such as wood or plastic or metal impregnated with oil or graphite, etc) is used, and there still needs to be a smooth flat surface to push against, so this is what the washer provides. Clever thrust bearings can include steel balls or rollers to avoid the sliding, or the use of swivelling plates which tilt under load to allow lubricant in (as mentioned by Bob Brown above).
I hope this helps, but do ask again if there are gaps in the explanation for you.
Regards, Tim
PS: I am reminded of a student who was puzzled by an explanation of how a car engine works. After several frowns, he said 'Does petrol burn, then?'
Michael Gilligan05/11/2016 18:42:09
23121 forum posts
1360 photos
Can't do it with words of one syllable, but how's this for simple ?
Think of a door 'meeting' a door-stop ...
Now imagine the whole thing spinning
That's a thrust washer In action.
Michael Horner05/11/2016 18:56:18
229 forum posts
63 photos
Hi Wolfie
Have a look at this! **LINK**
else try Wikipedia.
Cheers Michael
stevetee05/11/2016 19:52:17
145 forum posts
14 photos
M
Edited By stevetee on 05/11/2016 19:54:20
Michael Gilligan05/11/2016 20:16:59
23121 forum posts
1360 photos
^^^ Concise, but perhaps a little too cryptic, Steve.
HOWARDT05/11/2016 21:05:44
1081 forum posts
39 photos
A washer, a circular object with a hole in the centre and usually thin in relation to its diameter. A washer becomes a thrust washer when the thrust or load is placed on its face.
Martin Connelly06/11/2016 09:36:08
2549 forum posts
235 photos
There is a video by EricTheCarGuy on YouTube called thrust bearings and what they do. A thrust washer is a basic type of thrust bearing so this video is relevant to the question. **LINK**
Martin
Wolfie06/11/2016 12:47:57
502 forum posts
Posted by Tim Stevens on 05/11/2016 17:31:31:
Regards, Tim
Thankyou this makes it quite clear. It was the requirement for it to be self lubricating which was the sticking point, I couldn't quite work out what made them any different from any other washer but now I know why!
Edited By Wolfie on 06/11/2016 12:48:21
Wolfie06/11/2016 12:49:10
502 forum posts
So in effect, its a sorta flat bearing?
Mark Simpson 106/11/2016 13:31:12
115 forum posts
30 photos
like this...IKO Nippon Thompson Roller Bearing Thrust NTB1730AS
or this...51101 SKF Thrust Bearing 12x26x9
or this (much more expensive...)
Always sandwiched between two shoulder/faces/somethings...
Muzzer06/11/2016 13:43:25
2904 forum posts
448 photos
Wow. A moderator on a model engineering forum with 500 posts to his name lacks both the basic knowledge of what a thrust washer is - and the ability to Google it. I thought I had a good armchair!
MW06/11/2016 13:54:36
2052 forum posts
56 photos
Posted by Muzzer on 06/11/2016 13:43:25:
I don't see how that applies to his circumstances. Being a good M.E isn't about belittling those who know less than you might.
Michael W
Hopper07/11/2016 03:43:54
7881 forum posts
397 photos
Posted by Wolfie on 06/11/2016 12:47:57:
...Thankyou this makes it quite clear. It was the requirement for it to be self lubricating which was the sticking point, I couldn't quite work out what made them any different from any other washer but now I know why!
It sure would help if you let slip a few details about what exact application you are looking to use a thrust washer for.
They don't necessarily need to be lubricated, or even self-lubricated at all. A thrust washer can be used in a totally dry application, for example taking up end float in a shaft where the washer is placed between a shoulder on the shaft and the inner race of a sealed ball bearing.
