Maurice | 22/09/2016 19:05:19 |
469 forum posts 50 photos | I have a very elderly "Primus" gas torch with three burners. The smallest used to produce a very neat flame, very controllable and a pleasure to use. Over the years it has become progressively blocked until it no longer functions. The inlet side is covered with a fine mesh, and the flame side has a brass disc with a ring of small holes. The is no apparent way to dismantle it. Is there anything that I could soak it in that might unblock it please? Maurice |
KWIL | 22/09/2016 19:57:31 |
3681 forum posts 70 photos | You could try Citric Acid solution, worked for me on one burner. |
Neil Wyatt | 22/09/2016 20:28:48 |
![]() 19226 forum posts 749 photos 86 articles | Carburettor cleaner might work. Or an ultrasonic cleaner will almost certainly shake the soot out. Neil Edited By Neil Wyatt on 22/09/2016 20:29:15 |
Ian S C | 23/09/2016 12:29:45 |
![]() 7468 forum posts 230 photos | I took mine to a gas engineer, he had a suitable size pricker for the hole in my torch. I now use a fine brass wire from a small(toothbrush size)wire brush. With your one you might not be able to do that. Ian S C |
Brian Wood | 23/09/2016 16:05:42 |
2742 forum posts 39 photos | I use one strand of multi strand 3 amp copper wire in the single jet just below the flame. It needs magnification and a steady hand but it does work. |
Maurice | 23/09/2016 18:07:34 |
469 forum posts 50 photos | Thanks gents, I'll try citric acid, I can't see the jet to clean it. Maurice |
Speedy Builder5 | 23/09/2016 19:44:56 |
2878 forum posts 248 photos | Get some of these - Postage to UK is cheaper. |
Michael Gilligan | 23/09/2016 20:04:22 |
![]() 23121 forum posts 1360 photos | Posted by Maurice on 23/09/2016 18:07:34:
... I can't see the jet to clean it. . Speedy Bulder5 ^^^ ... I presume it's the 'Needle Flame' burner. MichaelG. |
Paul Lousick | 23/09/2016 23:26:22 |
2276 forum posts 801 photos | Get a set of these. Available from gas welding suppliers for cleaning oxy torch nozzles or from car accessory stores for cleaning carburetor jets. (also available on e-b**) The ends of the wires are made like tiny files. Edited By Paul Lousick on 23/09/2016 23:28:12 |
julian atkins | 24/09/2016 00:06:54 |
![]() 1285 forum posts 353 photos | I also have the kit Paul has. The problem with this kit is that it merely pushes the muck back in to block up again. The jets, if removable need removing and blown through on an air compressor. Cheers, Julian |
Michael Gilligan | 24/09/2016 00:22:02 |
![]() 23121 forum posts 1360 photos | Maurice's burner is, I presume similar to 8842 as shown on this page http://www.dpsgas.co.uk/shop/sievert/sievert_pg3/ I have two variants ... One screws onto a 'neck tube' and the other is 'integrated' So far as I'm aware, neither can be cleaned with the devices mentioned. MichaelG. |
