Press fit bush
Daniel13/09/2016 18:05:36
338 forum posts
48 photos
Hello All,
I need to make a bronze bush to fit into a cast iron tractor clutch pedal.
The clevis pin hole is well oval.
I have plunge milled the pedal out to 14mm and the clevis pin is 10mm.
With a 2mm wall on a bronze bush having an interference fit (pressed),
into cast iron, what outside diameter would be recommended for the bush?
I imagine a slight tad over 14, but how much would this slight tad be ?
Exactly ?
Thanks in advance for any help
Michael Gilligan13/09/2016 18:23:53
23121 forum posts
1360 photos
Posted by Daniel on 13/09/2016 18:05:36:
With a 2mm wall on a bronze bush ...
Exactly ?
I flatly refuse to discuss exact tads with a man who works in whole millimetres devil
... But you may find this useful:
http://www.tribology-abc.com/calculators/e3_8.htm
Edited By Michael Gilligan on 13/09/2016 18:27:38
Martin Connelly13/09/2016 18:28:34
2549 forum posts
235 photos
Loctite it to avoid tensile forces in the cast iron.
Martin
JasonB13/09/2016 18:36:44
I would also check your hole as plunge milling may be spot on but more likely a tad under or a tad over 14mm.
For a practical idea I have just mic'd a sintered bronze bush and it is 0.003" oversize on 3/4" nominal size, not tapered. So thats a a tad over 0.075mm for the press if but if the iron is a bit thin you may want to try 0.04-0.05mm over bore dia
Neil Wyatt13/09/2016 18:49:22
19226 forum posts
749 photos
86 articles
If feasible, ream the bush after fitting, if the fit is critical, (which I guess it isn't).
speelwerk13/09/2016 19:11:55
464 forum posts
I support Martin, a 2 mm wall in cast iron will fracture without warning. Niko.
JasonB13/09/2016 19:15:23
We don't know how thick the iron pedal is.
The hole in the pedal is now 14mm, the pin it pivots on is 10mm which gives the BUSh a 2mm wall thickness
HOWARDT13/09/2016 19:51:22
1081 forum posts
39 photos
Have a look at Oilite, Manganese Bronze. Although these are not re-machined after fitting, they achieve the correct bore after being press fitted into the correct hole.
Daniel13/09/2016 20:06:26
338 forum posts
48 photos
Posted by Michael Gilligan on 13/09/2016 18:23:53:
Thank you for the link. That is a cool calculator.
The complete absence of any decimal points, let alone anything after them, was an effort to maintain the agricultural spirit of the adventure. However, even as I pressed the "create thread" button, I saw that this was doomed. At some point I would need to resort to something a bit smaller. It's a pity that the DRO doesn't do Tads, really. dont know
Daniel14/09/2016 06:54:03
338 forum posts
48 photos
Thank's everyone for the replies. Last night's forum time was cut short by a storm and power failure.
Martin - I had temporarily forgotten about Loctite; that is most likely the way to go.
Neil - I will ream the bush after fitting. Critical it isn't, by any stretch of the imagination, but seems good form.
Jason - The pedal is about 15mm thick. My tape measure is not equiped with smaller increments.
And, of course, for the loctite solution, the finished article only needs to be a Tad, or two, under 14mm.
No unnecessary stresses, etc, either on me, or the pedal, and not a decimal point in sight. laugh
JohnF14/09/2016 08:30:41
1243 forum posts
202 photos
Daniel, if it's the clutch foot pedal I doubt it is cast iron, more likely a steel forging. What tractor is it ?
Edited By JohnF on 14/09/2016 08:31:12
Michael Gilligan14/09/2016 08:59:44
23121 forum posts
1360 photos
PostScript: ... For the benefit of those who may not be familiar with the term:
A 'tad' [or more properly, T.A.D] is a Tiny Atypical Dimension
Example: On a drawing generally dimensioned in inches; one micron would be a 'tad'
or, when referencing whole millimetres; tenths of a thou would be 'tads'
angel MichaelG.
MW14/09/2016 09:24:22
2052 forum posts
56 photos
Posted by JohnF on 14/09/2016 08:30:41:
You're probably right, i can't imagine that being a casting either.
Michael W
Neil Wyatt14/09/2016 09:48:56
19226 forum posts
749 photos
86 articles
Posted by Michael Gilligan on 14/09/2016 08:59:44:
angel MichaelG.
[ BLUFF ]
Chris Evans 614/09/2016 10:04:33
2156 forum posts
From a practical point of view it would not matter if the bush was loose on the peddle hole by a couple of thou. It will not wear the peddle out in your lifetime and will be retained by the peddle fixing.
Neil Wyatt14/09/2016 11:19:10
19226 forum posts
749 photos
86 articles
angel MichaelG.
[ BLUFF ]
Daniel14/09/2016 12:59:02
338 forum posts
48 photos
Micheal - That saved me the trouble of some research. I was convinced that a Tad was a more or less precise measurement. It's true that whole millimetres can be a bit (tad), cumbersome.
I've sometimes been known to use "half a Tad", but that is only on extremely precise work., and somewhat rare.
The (non) deliberate mitsake of referring to the clutch pedal as cast iron is just that; a mistake.
As pointed out, it is most likely a steel forging or similar.
The tractor is a Someca 40 & French.
Chris - quite agree with you, that the bush could even float. I just wanted to do a reasonable job for the simple pleasure of doing so; as with most of what we get up to. Avoiding any unnecessary accuracy, of course. smile p
Daniel14/09/2016 13:00:46
338 forum posts
48 photos
Sorry - can I change the thread title now ?
I'm thinking "Loosely Fitting Bush", may be more appropriate.
duncan webster14/09/2016 15:43:35
5307 forum posts
83 photos
Exactly ?
For the diehard Imperial brigade I'm considering making a Micrometer which reads in 1/1024" increments. That's 2 to the power 10, and is a logical extension of 1/8", 1/16" etc. Any takers?
SillyOldDuffer14/09/2016 15:59:23
10668 forum posts
2415 photos
Posted by duncan webster on 14/09/2016 15:43:35:
Works even better if we redefine the inch to be 25.6mm as well.
