What size drill
Ordering drill bits
Mike Brett08/09/2016 15:00:28
129 forum posts
18 photos
Hi
Can anyone tell me what size drill I need to order to drill a 3.3 mm hole. I have ordered two lots of 3.3 mm drills and although they had 3.3 stamped on the base of the drill there actual measurement was 3.19 mm. Result of this was a broken tap, help please.
MW08/09/2016 15:29:26
2052 forum posts
56 photos
That sounds quite bizzare mike, i'd just go for HSS fully ground drill, normally with plastic and aluminium it will drill slightly undersize, in most metals it will drill slightly oversize.
You can drill bigger than 3.3 and it will still produce a thread on an M4x 0.7mm tap. 3.4 should be okay even if it doesnt do the same thing as your cursed 3.3's.
Michael W
John Rudd08/09/2016 16:09:02
1479 forum posts
Number drill between 3.3 and 3.4 ?
MW08/09/2016 16:13:54
2052 forum posts
56 photos
If it persisted in that particular material, if it's not a bad drill then you could even ream to 3.3 before you tapped it if it came down to that?
MichaeL w
John Haine08/09/2016 16:24:54
5563 forum posts
322 photos
Where did you measure? The hole or the drill shank? The shanks are usually slightly undersized, 0.11 mm would be unusual though, mine seem to be about 1% small at that sort of size.
Ian P08/09/2016 17:13:58
2747 forum posts
123 photos
It might sound patronising but to drill a hole 3.3mm diameter you need to use a 3.3mm drill!
Its not that simple however, standard twist drills are not precision hole cutters (although you dont need to be that precise if its a hole for tapping) and they cut holes about the nominal drill diameter.
The size of hole a particular drill will produce will vary with the material, speed of penetration and other factors. In your case it would seem that the drills you purchased may be wrongly marked if they are only drilling 3.19 holes (how did you measure that by the way?)
When you start tapping a hole you should get an immediate indication of whether the hole is undersize as the tap will need a lot more than normal of torque to turn. At that point its best to stop and review the situation rather than breaking the tap.
What is the material you are tapping, what is the thread? what type of tap, CS, HSS, spiral, thread forming, etc?
If you are working in SS, Titanium or Inconel best to have the tapping hole oversize.
Ian P
John Rudd08/09/2016 17:27:57
1479 forum posts
Blunt tap?
Mike Brett08/09/2016 17:48:08
129 forum posts
18 photos
The holes I am drilling at the moment are in brass . When I ordered the the first 3.3 mm drills and found they only drilled 3.19 mm I used those, then opened out the holes with an old drill I had that did measure 3.3 mm. This worked fine for a time but eventually the old drill has finally worn out and so I ordered another couple of drills from a different source which also only measure 3.19 mm. This is when I broke the tap, which was a M4x0.7. I have no way of measuring the holes I am drilling , but they are obviously to tight. I usually measure the drills by the shank but even so 3.3 to 3.19 seems a large difference. There must be a reliable source of drills somewhere but as yet I am still looking.
JasonB08/09/2016 17:56:04
What make of drill was it? I never have problems tapping M4 into holes drille dwith a 3.3mm drill, I tend to use Dormer A002 Jobbers and A022 Stub drills
Neil Wyatt08/09/2016 18:12:16
19226 forum posts
749 photos
86 articles
Posted by Mike Brett on 08/09/2016 15:00:28:
Hi
If you measure the shank of a drill can be undersize. This presumably helps stop drills jamming in deep holes. You need to measure across the widest part of the flutes.
Michael Gilligan08/09/2016 18:24:22
23121 forum posts
1360 photos
Mike,
It is fairly well known that 2-flute drills have a tendency to make tri-lobular holes [especially in thin materials] ... Ian's question is therefore significant: "(how did you measure that by the way?)"
HOWARDT08/09/2016 19:01:02
1081 forum posts
39 photos
A basic jobber drill at 3.3mm diameter will have a tolerance of size to -0.018mm(h8). A new correctly ground drill should give a H12 hole, 3.3/3.42 diameter. These are the sizes for named manufactured drills e.g. Dormer, Gurhing etc. If the shank is less than the marked size then suspect the drilled hole will be undersize also.
The shank is the same diameter as the twisted portion. Drill length should be chosen so that the flute is always clear of the hole, otherwise swarf will jam the drill. Also tap thread form should never be run in beyond the top of the hole as they will tap in both directions causing oversize thread form.
KWIL08/09/2016 19:02:48
3681 forum posts
70 photos
Buy Dormer drills from Greenwood Tools.
JA08/09/2016 19:32:09
1605 forum posts
83 photos
It is a long time ago but I think I was taught to expect a drill to drill oversize. I have always worked with this in mind and piloted holes when possible. If you finish an existing hole with a slightly larger good sharp drill you should get a hole diameter corresponding to that drill (with the usual caveats - rigidity, material, material thickness, etc). Obviously use the best drills you can afford.
By the way tri-lobular holes generally have a constant diameter - measure the diameter of a 50p piece.
JA
Michael Gilligan08/09/2016 19:52:50
23121 forum posts
1360 photos
Posted by JA on 08/09/2016 19:32:09:
That's the [w]hole point, JA, and why I mentioned the importance of Ian's question.
The 'diameter' may be constant, but ...
< sigh > I'll leave you to look it up for yourself.
JasonB08/09/2016 20:01:36
A simple way to gauge if the drill is cutting to its nominal size or the shank size is to drill a hole and then stick the shank of the hdrill into the hole.
If its a firm fit then its likely to be cutting to the shank size if its an easy fit then probably cutting to nominal size.
Mike Brett08/09/2016 20:02:58
129 forum posts
18 photos
Many thanks for all your detailed replies. I have know ordered some Dormer drills from Greenwood Tools.
Cheers Mike
Andrew Johnston08/09/2016 20:05:12
7061 forum posts
719 photos
Posted by HOWARDT on 08/09/2016 19:01:02:
Not always so. All my metric and imperial drills are within ±0.01mm of nominal size when measured at the tip, as near as I can tell. However, the shanks are 0.03mm to 0.1mm undersize, depending upon the drill size, and also taper slightly away from the tip.
PS: All my metric and imperial drills are Dormer, bought new in sets
SillyOldDuffer08/09/2016 20:05:13
10668 forum posts
2415 photos
Posted by John Rudd on 08/09/2016 17:27:57:
Blunt tap?
That would be my guess too.
When I was a total beginner I often used 3.2 and/or 1/8" holes for M4 in brass and aluminium without breaking the tap. (Now I always use at least the recommended diameter drills: a broken tap jammed in the hole isn't worth the risk.)
Although delightfully cheap the tap I used with 3.2mm holes was new and sharp. I thought it was a bargain until I used it on mild steel. After tapping one hole it was hopelessly blunt.
Ian P08/09/2016 20:07:34
2747 forum posts
123 photos
Do you mean that a tap can cut two sizes or that the cutting portion of the tap must not go below the face of the hole?
Ian P
