filing rest
mick7002/08/2016 10:22:12
524 forum posts
38 photos
been offered a filing rest for lathe.
can't seem to find much info apart from useful for filing flats on rd stock.
are they useful to have and exactly what are they for?
it came from myford and will need spacer to fit my lathe but thats not a problem.
got some money left over from last month so it needs spending.
cheers
Ajohnw02/08/2016 10:45:20
3631 forum posts
160 photos
I'm pretty sure I have seen mention of them being used to file round work parallel even to the extent of a twin roller version being mentioned in ME. - Which I haven't bought for >> than 15 years.
JasonB02/08/2016 12:08:21
If you don't have a mill they are used to file square, hex etc flats onto a round bar using simple indexing of the spindle.
Never seen mention of them being used to file round work parallel and all have twin rollers, one either side of the work so the file stops cutting the work as it runs on the rollers.
Martin Kyte02/08/2016 12:11:06
3445 forum posts
62 photos
As you say filing flats on round stock. Producing squares. Making D bits.
I'd say handy but not essential especially if you can transfer stuff to the mill.
Depends how cheap it is. If you just want to spend money then collets , reamers , taps and dies ?
regards Martin
Philip Rowe02/08/2016 12:13:38
248 forum posts
33 photos
I made my filing rest back in the 70/80s from I think a G.H. Thomas design. To be honest it doesn't get that much use but it is quite useful when putting flats on round stock. On one occasion a triangular head on a bolt that needed to be tamper proof.
What is suprising is how quickly one can achieve things like this as opposed to removing the stock from the chuck and transferring to the mill, not forgetting all the set up time.
Phil
Bazyle02/08/2016 12:42:19
6956 forum posts
229 photos
As well as having two rollers to control 'depth of cut it should have shoulders on the rollers to provide a longitudinal end point. Then you have to make sure the safe edge of your file is properly safe not having the thin line of residual teeth form the forming process. You also want to make sure it has good design of height adjustment. Newer designs use the height control of a QCTP.
Phil P02/08/2016 13:13:51
851 forum posts
206 photos
Posted by JasonB on 02/08/2016 12:08:21:
Jason
They don't all have twin rollers, in fact the majority of ones for watchmakers lathes only have one roller. I dont see how they can be used with any accuracy or repeatability though.
I have just managed to get hold of a twin roller one myself, its main use for me will be "reducing" the size of hexagons on small commercial BA bolts, or making them from scratch using round stock. I think doing each one in the mill might be very time consuming, so I am going to try this method first.
Phil
JasonB02/08/2016 13:26:21
I'd not seen the watchmaking ones Phil, as you say sounds lke they will only be as accurate as you can keep the file level.
I suppose if you have one of those spin indexers that will just jump to the next index point as you pull the lever it would be quite fast on the mill especially if you cut in both directions, even more so if you have lever feed rather than handwheels. A standard spin indexer would take a while pulling the pin out, rotate, put pin back etc.
J
Ajohnw02/08/2016 13:30:09
3631 forum posts
160 photos
I had my tongue in my cheek. I am 100% sure I have seen comments about using them to remove taper in round work. They could also clearly be used for final sizing and polishing. As I haven't done either I can't comment on the practicality but given that they are made with sufficient accuracy / adjustability I really can't see why it shouldn't work out.
I have also seen designs with one roller as Phil mentioned and not for watch making as well.
Ian S C02/08/2016 13:54:42
7468 forum posts
230 photos
For forming hex heads on bolts, making nuts, and other simple forms, it's often quicker to file them than set up the mill and rotary table. Ian S Cdsc01000 (640x480).jpg
clivel02/08/2016 14:57:41
344 forum posts
17 photos
Probably one of the simplest filing rests that one can make, is something like the one I made for my Unimat a few years ago, based on an idea in another forum.
Here are two views. Partly disassembled and assembled.
To use it, simply mount it in the lathe toolpost rotated about 30 to 45 degrees from the vertical. The crosslide is then used to adjust the filing depth. This photo of it being used to file a flat on the end of a rod should make it clearer.
Although it doesn't get much use, it is handy on occasion, and far faster to set up than setting up the milling attachment.
I have subsequently made two changes to it since the photos were taken: I replaced the socket head screws with countersunk screws allowing it to get closer to the chuck, and I also reduced the diameter of the thick washers which hold the rollers on and also act as a stop for the file as they limited the maximum diameter of the work piece.
Phil P02/08/2016 17:11:02
851 forum posts
206 photos
You have just answered a question for me.
I had always wondered why some of the double roller filing rests for watchmakers lathes were designed with the rollers at different heights.
The penny has just dropped. Thanks
Phil
