Dickson type T00 toolholders
Gordon A21/06/2016 23:39:55
157 forum posts
4 photos
Following the demise of the small Coventry firm that manufactured good quality toolposts and holders, a new source has appeared on "The Bay", item number 112020207224. This firm is also situated on the outskirts of Coventry.
Link
I have no connection to this new source but was a very satisfied customer of the previous one.
Apologies for my inability to post a better link to the item, but hope it will be of interest to some members.
Gordon.
Edited By JasonB on 22/06/2016 07:26:02
Jon Gibbs22/06/2016 08:41:49
750 forum posts
Well spotted Gordon!
Do we think this is a resurrected A&R Precision then?
It seems that the holders are now blackened which is a bit of a departure but if they fit who cares.
Having tried a few toolholders from different suppliers, including SOBA from Chronos and the official Myford ones, my A&R variants are by far the best in terms of height clearance for stiffer & deeper tooling.
Jon
Douglas Johnston22/06/2016 09:00:01
814 forum posts
36 photos
Well spotted indeed, I have been thinking about getting some more holders for a while and have just been on ebay to buy a pair of these to check them out. If they are a good fit for my toolpost I will get more ,although the present listing says there are only 5 pairs left (well 4 now I have mine! ) but with any luck they will list more in future.
The listed ones are the size I need for a Myford Speed 10 but may be too small for some users. The price is very reasonable compared to other suppliers and if they are well made they are a real bargain. I will report back once I have received them.
Doug
Robbo22/06/2016 09:15:12
1504 forum posts
142 photos
The name is familiar, but due to a computer crash I have lost correspondence I had with A & R Precision.
The description is the same as used before, and is still erroneous. These are not the size for a Boxford toolpost.
DMB22/06/2016 10:07:01
1585 forum posts
Googling Lynam Eng. as quoted on Ebay gives no website for them just a company check so cannot find out their other products if any
Jon Gibbs22/06/2016 10:25:21
750 forum posts
According to Companies House, A&R Precision Ltd went into liquidation in July 2015 (Director: Daren Lynam)
and Lynam Engineering Ltd was incorporated in May 2015 (Director: Daren Lynam).
Jon
Bazyle22/06/2016 11:15:32
6956 forum posts
229 photos
Hope he is in production and this isn't just 'old stock' from the liquidation.
I run a Myford size on a Boxford and it is fine for normal work and makes the holders cheaper. I was sold it at the Sandown show years ago as Boxford one and don't know if it was a deliberate downsizing to make a show offer price or a mistake in handing over the wrong one. Didn't have anything to compare it with until so not aware until I came to get more holders.
Peter Wood 522/06/2016 12:02:46
94 forum posts
11 photos
My second hand Myford S7 came with a Dickson type toolholder. I have since bought quite a few toolholders from Soba, Chronos etc but all have the limitation that I can only use 8mm tooling. When such tools are used there is less than 2mm horizontal clearance between the toolpost flat on the compound slide and the bottom of the toolholder. This means that it is impossible to get 10mm tool on centre height.
I did inherit a parting tool holder which has a rebate across the toolholder base presumably because of this limitation but all my other holders are far too hard for this treatment.
Has anyone found a solution to this problem?
Jon Gibbs22/06/2016 13:10:18
750 forum posts
I would try the toolholders linked to by the OP (Only 4 off available now though).
I bought my original toolholders and QCTP set from A&R Precision and find I can use 10mm tooling easily on my ML7.
Since then I've bought the SOBA toolholders from Chronos and toolholders from Myford and these have a thicker lower shelf. I can just about use 3/8" tooling in the Myford ones but can confirm your findings about the Soba ones andthey are now only used for boring bars with lower cutting edges.
I'll try and find the original threads where this issue was discussed.
http://www.model-engineer.co.uk/forums/postings.asp?th=82603&p=1
http://www.model-engineer.co.uk/forums/postings.asp?th=104291
http://www.model-engineer.co.uk/forums/postings.asp?th=80916&p=1
HTH
Jon
Edited By Jon Gibbs on 22/06/2016 13:21:27
Edited By Jon Gibbs on 22/06/2016 13:23:10
Edited By Jon Gibbs on 22/06/2016 13:24:32
Douglas Johnston25/06/2016 10:16:10
814 forum posts
36 photos
Just received the toolholders from Lynam Engineering as listed on ebay. They are very nicely made with a black finish apart from the mating surfaces which have been ground. They are a perfect fit on my toolpost and I'm very pleased with them. They are UK made and the quality shows. I had thought of making some myself but there is a lot of work involved and they would never be as good and hardening would be a problem.
Douglas Johnston25/06/2016 10:56:04
814 forum posts
36 photos
When I got my original toolholders I got fed up with the mess the screws were making on the top of my homemade carbide insert tools, which were not hardened. I inserted brass pads into the ends of the screws and this made all the difference. HSS tools would not be a problem but when I started using carbide tips a good few years ago the tip holders were very expensive so the DIY route was worthwhile.
Doug
Ajohnw25/06/2016 12:57:06
3631 forum posts
160 photos
Posted by Bazyle on 22/06/2016 11:15:32:
My Boxford uses the same tool holders as per Myford but the tool post has a plate attached some how to the bottom. It was made by Myford. The plate is around 10mm thick. It's all looks to be ground all over. Only problem really is that the holders wont accept 16mm boring bars. One could be designed to do that easily though.
Bazyle25/06/2016 14:12:42
6956 forum posts
229 photos
John thanks for pointing that out. I should have mentioned I have a plate too, about 3/16 which was what fell to hand at the time.
I wonder if ME could find out more about this chap and do a one pager. Any British mfr of tools should be of interest to the readership. It might be nice to see if he has the equipment to branch out into other sizes and the other types of holder ie for piston/wedge type.
Ajohnw25/06/2016 15:22:17
3631 forum posts
160 photos
I'm pretty sure the plate on mine came with it on from Myford. I've always wondered if they did some heftier tool holders for it. I suspect it may have been produced for the 254.
At some point I will probably modify a standard 1/2" parting off blade holder to take a larger boring bars. It should be just a case of making a sort of bolt on block with groove to take a larger bar. I'd guess it may be possible to go up to 25mm on a Boxford. 16mm wouldn't be a problem at all as that nearly fits the usual size of tool holder.
Paul Barter25/06/2016 15:59:39
112 forum posts
8 photos
Thank you Gordon A, I have just received two excellent toolholders from Lynham Engineering, the fit and finish is, in my opinion better than the "foreign" clones I have bought in the past to fit my genuine Myford toolpost.
Paul
John C25/06/2016 17:37:13
273 forum posts
95 photos
Well spotted - thank you! I have just bought a couple of these from the link. I have had toolholders from A and R in the past and they were absolutely first class. It is very satisfying to be able to support firms making stuff in the UK.
KWIL25/06/2016 19:55:40
3681 forum posts
70 photos
Mine fit OK, the lower disc of the height adjuster is marginally too thick, but that is not a problem. I do not care if the blacking is removed.
Definately new "A&R", even Sally still works there!
KWIL25/06/2016 20:02:32
3681 forum posts
70 photos
Street View their address and you see....unit 3 = A&R Engineering on the old google street view picturessmileysmiley
Gordon A25/06/2016 21:42:09
157 forum posts
4 photos
Thank you all for your feedback, spotted them during one of my many idle moments!
Gordon.
Neil Lickfold26/06/2016 07:37:28
1025 forum posts
204 photos
Posted by Douglas Johnston on 25/06/2016 10:16:10:
Can you post or PM a link to where you brought the tool holders from please. Thanks, Neil Lickfold
