Dave Smith the 16th | 22/05/2016 00:28:07 |
123 forum posts 33 photos | I have a lathe already and should be picking up ths SX2 mill on Tuesday. I dont have the full dimensions yet, but i may need to make a few helical gears in aluminium or brass. If they were straight then no issue, just cut a length and chop out the required number, but what can be done with a slight helix on the gear? Limited skills and tools as usual Any simple methods to creating more than 1 gear easily? Or should i just get comfy and make them one at a time?
Thanks again. (i have so many questions)
John Reese | 22/05/2016 01:45:40 |
![]() 1071 forum posts | Traditionally they would have been done on a Universal milling machine. That is a horizontal mill on which the table could swivel to the helix angle. The work would be held on an arbor on a universal dividing head. The shaft of the dividing head would driven through a gear train from the X axis lead screw. A standard involute milling cutter would be used. Most of the early 20th century machining texts show the setup. It is not something a hobby machinist is equipped for. Other than shops specializing in gears I do not know of a machine shop within 100 miles that would have the equipment or know how to use it. Most helical gears are cut on hobbing machines. Try to find a source of stock gears. If you are willing to build a machine to make your gears there are kits and drawings available to build a small hobber. I think Hemmingway sells such a kit. I am not sure if the kit will handle the lead angle you want. I believe the hobber is shown in illustrations in Ivan Law's book on gears and gear cutting. |
JasonB | 22/05/2016 07:21:03 |
![]() 25215 forum posts 3105 photos 1 articles | If you wait for ME 4536 there will be an article by Rod Jenkins on making small helical gears in the home workshop which should answer your questions. J Edited By JasonB on 22/05/2016 07:24:11 |
Jens Eirik Skogstad | 22/05/2016 07:43:18 |
![]() 400 forum posts 22 photos | It is not difficult to make helical gear as i did in this method. See the movie..
Nigel McBurney 1 | 22/05/2016 09:52:44 |
![]() 1101 forum posts 3 photos | A universal mill is not essential for cutting spiral gears, providing a universal dividing head with a full set of gears is available spiral gears ,worms,and short threads can be cut on a turret hill ,or a plain horizontal mill with a bolt on vertical head, which can swivel to 90 degrees either way,The universal mill with swivelling table has a couple of advantages, the horizontal arbour is more rigid than a vertical head (stub arbour)and additional arbour supports can be used in some circumstances, so production cutting with lower number DP cutters is easier and quicker,plus it is easier to centre the gear ,over the gear blank then swing the table to the correct angle,the snag with the swinging table is it usually swings to 45 or 50 degrees so cannot deal with short lead spirals say for 2 to 1 side shaft gears on horizontal i/c engines.in that case the table is set a zero and the vertical head swivelled to the required angle or the vertical head is swivelled to 90 degrees i.e. spindle parallel to table,and the table swung to around 25/30 degrees .For thread milling over a reasonable length a universal head was made for for horizontal mills which had a double swivel and smaller spindle to reduce the bulk of the head to give sufficient space for the head to clear the work. I have both a universal mill and a turret mill and have cut lots of spiral gears for stationary engines,and large worm for a full size Burrell . With a lot fiddling the spiralling tooling can machine good spirals in plain bearings.If any one is buying a mill with possibly the idea of machining spirals in the future make sure the the head on the turret mill will swing a full 90 degrees a lot of imports only swing to 45 degrees,this also applies to vertical attachments for horizontal mills. |
Michael Gilligan | 22/05/2016 09:54:59 |
![]() 23121 forum posts 1360 photos | Very informative videos, Jens Thank you. MichaelG. |
Jens Eirik Skogstad | 22/05/2016 10:24:11 |
![]() 400 forum posts 22 photos | You can not use same gear cutter to cut helical gear such as gear cutter for 12-13 teeth in helical gear who need 12 teeth. The gear cutter is choosed depending on angle of helical gear and counts of teeth. Read through from page 14-13 to 14-14 about how to manufacturing a helical gear. To choose the gear cutter to mill helical gear choosed by angle and counts of teeth, read though from 14-9 to 14-11 how to choose the right gear cutter in this link --> |
Jens Eirik Skogstad | 22/05/2016 10:24:30 |
![]() 400 forum posts 22 photos | Posted by Michael Gilligan on 22/05/2016 09:54:59:
Very informative videos, Jens Thank you. MichaelG. Thanks |
Dave Smith the 16th | 22/05/2016 13:42:14 |
123 forum posts 33 photos | A little bit of whoosh, something flew over my head there The angle is very small, virtually a spur gear, which im hoping will work but i am guessing that it will need that small angle cut into it. The size/shape is unlikely to be an off the shelf item. Just seen the price of gear pitch gauges, a big ouch. Is there an online reference to compare gears? Hoping to just mount it on a shaft and offset by x degree and then take a cut, i was just curious as to whether i could make more than one gear at a time?
Thanks.
Dave Smith the 16th | 22/05/2016 15:45:39 |
123 forum posts 33 photos | Can anyone help with the gear size? 20 tooth and 29mm diameter, the lowest part of the tooth does not extend to the highest part of the next tooth, thats how little a helix it is.
Thanks.
Michael Gilligan | 22/05/2016 16:07:27 |
![]() 23121 forum posts 1360 photos | Posted by Dave Smith the 16th on 22/05/2016 15:45:39:
Can anyone help with the gear size? 20 tooth and 29mm diameter . I make that a little over Mod 1.3 ... Which is possible, but unlikely ... Could you please double-check that diameter ? MichaelG. . P.S. ... It's a simple calculation, but I've just found this very handy page. Edited By Michael Gilligan on 22/05/2016 16:23:22 |
JasonB | 22/05/2016 16:27:33 |
![]() 25215 forum posts 3105 photos 1 articles | Try 20 DP, only 0.001 over 29mm looking at HPC's helical gears. I think its a different calculation for helicals so spur gear calculations won't work, also varies for parallel or crossed.
Edited By JasonB on 22/05/2016 16:48:07 |
Michael Gilligan | 22/05/2016 16:43:20 |
![]() 23121 forum posts 1360 photos | That's better, Jason Although I make that 29.21mm O.D. ... I couldn't find an 18 DP listed anyway MichaelG. Edited By Michael Gilligan on 22/05/2016 16:49:38 |
John Reese | 22/05/2016 16:55:29 |
![]() 1071 forum posts | My thanks to all of you who have added to my education. Model Engineers seem to have a particular talent for figuring out how to get the job done without the "right" tools. John |
Michael Gilligan | 22/05/2016 16:58:39 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 22/05/2016 16:27:33:
... I think its a different calculation for helicals so spur gear calculations won't work, also varies for parallel or crossed. . ... and I hadn't realised how big that variation is |
Neil Wyatt | 22/05/2016 18:55:52 |
![]() 19226 forum posts 749 photos 86 articles | Saw a great device at Harrogate that apparently was described in ME some years ago. In short its a small dividing head and tailstock on a slide. The head end has an angled template and you reset it before each tooth then it makes a part turn as you feed each tooth space past the cutter. Much easier to understand when you see it in action. |
JasonB | 22/05/2016 19:16:21 |
![]() 25215 forum posts 3105 photos 1 articles | Couple of photos of Mike Sayer's spiral gear cutter here which is what Neil is talking about Edited By JasonB on 22/05/2016 19:16:34 |
Andrew Johnston | 22/05/2016 19:40:55 |
![]() 7061 forum posts 719 photos | As a first pass the number of 'teeth' used to select an involute cutter for a helical gear is the actual number of teeth divided by the cube of the cosine of the helix angle. Here's the proof: The OD is also related to the helix angle, so not fixed for a given number of teeth. Andrew |
Jens Eirik Skogstad | 22/05/2016 19:53:38 |
![]() 400 forum posts 22 photos | Found the easy way to create the tool to mill helical gear in Youtobe. Really simple than my tool as i showed in early post of my movies. Function is about same as my tool. Be sure there are no play in the tool before you are creating the helical gear. Edited By Jens Eirik Skogstad on 22/05/2016 20:00:12 |
John P | 22/05/2016 20:09:43 |
451 forum posts 268 photos |
The photo helical gear 2 shows a 100 tooth 1mod gear 5 deg left hand The last photo helical gear 3 is similar to the photo 2 except the hand is Getting back to the OP's original question ? "Limited skills and tools as usual" . We have all been there at some time. Any simple methods to creating more than 1 gear easily? Or should i just get comfy Probably not as to make anything such as this requires some commitment in time. As answers i doubt this is of much help but is probably true. John |
