Grooving Tool
Where from??
Rod Ashton07/05/2016 12:54:15
344 forum posts
12 photos
I am trying to purchase a lathe grooving tool + inserts. The regular suppliers R.. & Ch.... seem to have no idea of the shape/dimensions of their inserts. Since this is critical for CNC accuracy can I ask where do you get your mid price tooling from.
JB seem not to do one.
All seem to think I want a parting tool, not the same thing of course. If you can help I would be grateful.
Rod Ashton07/05/2016 13:05:05
344 forum posts
12 photos
Apologies just found what I wanted at ARC with all the required info.
JasonB07/05/2016 13:08:31
I did not know Ketan did grooving tools have you got a link? I'm not counting the ones that are parting tools but not used to cut all the way through. There are several grooving systems about, I use the "Mini-thin" one
J
Edited By JasonB on 07/05/2016 13:21:38
Muzzer07/05/2016 14:01:55
2904 forum posts
448 photos
Cutwel stock both Korloy and Simtek grooving tool systems. However, APT Tools also do a generic own-brand version of the MGMN system which is a fair bit cheaper - I'm pretty sure it's compatible with the Korloy MGT system and others. However, Cutwel periodically offer a free tool with 10 inserts etc which makes the cost a bit more bearable.
I'm pretty certain my Korloy grooving / parting tool is the KGT system which isn't compatible with the MGT system despite the appearance. I think it's just a more recent version of the same concept. You can get a variety of inserts with different profiles and they are good for both parting and profiling ie you can cut any direction.
Here's a KGT video from Korloy to get you in the groove.
Murray
Rod Ashton09/05/2016 08:19:24
344 forum posts
12 photos
Jason - Just pop "grooving tools" into the ARC search and you will see the selection.
JasonB09/05/2016 08:31:19
Yes at time of writing I was thinking of tools with specific grooving inserts eg set widths and shape rather than the "narrow partingtool that cuts 3 ways" which is a grooving & turning tool
Edited By JasonB on 09/05/2016 08:31:55
Nick_G09/05/2016 08:37:12
1808 forum posts
744 photos
I am also considering a tool that takes the MGMN 200 inserts for grooving / parting. Has anybody used one.?
Nick
Chris Hembry09/05/2016 09:24:56
52 forum posts
Hi Nick,
Not tried the MGMN system, but do use the very similar Korloy KGT system. Having a need to part off 1" Hex 303 in large quantities, I could not find another system rigid enough. I use the 2mm width, speed 730 rpm, feed 25"/min and have no issues.
Regards, Chris
Nick_G09/05/2016 09:37:46
1808 forum posts
744 photos
Posted by Chris Hembry on 09/05/2016 09:24:56:
Hi Nick,
Regards, Chris
Thanks Chris,
Looks a versatile system and while not cheap is not too OTT either. **LINK**
Besides I have given up buying cheap tools. Perhaps I am overly heavy handed with them but it usually ends up with gritted teeth and swearing from me.
Nick
John Stevenson09/05/2016 09:52:51
5068 forum posts
I am using the narrow top clamp type tool from ARC on my CNC lathe doing 'O' ring grooves for spool valves which are quite critical on width.
This tool can cut sideways if needed or plunge in repeatedly to get the required groove width.
TBH this is now my tool of choice for grooving or parting off if the material is less than 32mm for parting off. Tips last far longer than the clip in type and the spool valves which are 20mm, 25mm and 30mm in diameter can be parted off at 1200rpm, in fact all the operations are done at 1200 rpm.
Nick_G09/05/2016 10:03:26
1808 forum posts
744 photos
Posted by John Stevenson on 09/05/2016 09:52:51:
Hi John,
I have a friend who like yourself is a pro.
I am amazed at the speed and feeds he parts off at. - It's like a hot knife through butter.!
But his machines are big rigid lathes or Ward capstans.
Nick
Andrew Johnston09/05/2016 10:15:38
7061 forum posts
719 photos
Blimey, 34 thou per rev? surprise
Chris Hembry09/05/2016 14:57:46
52 forum posts
I'll check, been a while since I wrote the program and had no reason to look at it again
Chris Hembry09/05/2016 18:56:11
52 forum posts
25 is programmed which would have given 2.5 inch/min. However, that program is now fully converted to metric so is actually 25mm/min. My mistake. Previous software version only permitted feed rates in inch/min regardless of whether rest of program was in metric or imperial, hence the confusion.
Muzzer09/05/2016 20:09:13
2904 forum posts
448 photos
Bottom of page 10 of the May Cutwel flyer has MGT tool and 30 inserts for £99 if you are wavering....
Jon09/05/2016 23:20:21
1001 forum posts
49 photos
I use both daily for turning, parting and grooving currently fitted with neutral DGN2202J inserts from Iscar being my favourite in a DGTR one piece tool. Much like the Korloy above I would be tempted with. These work on anything you care to throw at them, whether titaniums, aluminiums, steels, plastics or brass. One tool can do multiple operations, these are worth it having tried just about everything. The only problem I get is using appropriate left or right hand tip and it leaving a burr when parting.
Certainly can plough straight in parting at alarming rates in nearly all metals inc titaniums, just clear the debris regularly on 6082. **LINK**
Iscar above substantially better for turning than the Teutec C type quite similar to MGMN mainly due to the radiused edges. **LINK**
Internal boring, grooving and undercutting look no further than Horne circular interpolation meant for milling, I cant praise enough for lathe work and I am hard to please. Word of warning the tips are dear, last a long time and would be revolved when worn. So 6 sided in to £30+ aint bad, around £20 for three sided all interchangeable whether bullnose, chamfer or straight cut my favourite tool I couldn't be without. **LINK**
Andrew Johnston10/05/2016 09:53:49
7061 forum posts
719 photos
Posted by Muzzer on 09/05/2016 20:09:13:
Damn it; had to go and dig the flyer out of the recycling bin! Fortunately (?) it's not quite what I'm looking for. What I actually want is a copying insert, ie, rounded tip, that I can use with my hydraulic copying unit.
Neil Wyatt10/05/2016 09:59:45
19226 forum posts
749 photos
86 articles
Posted by Nick_G on 09/05/2016 10:03:26:
Hi John,
Nick
See my comments elsewhere or in ME about using parting inserts on a humble mini-lathe. I think matching speed and feed (and making sure they aren't too low) is more important than rigidity. Worst thing is too slow = rubbing = horrible noise and as your instinct (and received wisdom for HSS) is to slow down it takes practice to gain confidence to just up the speed and plough the insert into the work..
David Colwill10/05/2016 10:43:27
782 forum posts
40 photos
I have just checked and found that I use the MGT parting system. I have found it to be great. I part 25mm at 1289 RPM on a Smart and Brown 1024. I also have some of the inserts with a 3mm diameter tip. The insert life is fantastic.
Hope this helps.
David.
Andrew Johnston10/05/2016 11:38:38
7061 forum posts
719 photos
Posted by Chris Hembry on 09/05/2016 18:56:11:
Chris: Thanks for the elucidation; there's no accounting for the bizarre logic incorporated in software! I normally part off at 4 thou per rev.
