Whats the tolerance on that 1" shaft, easy + or - 1" or better :)
Dave Smith the 16th | 25/04/2016 00:49:14 |
123 forum posts 33 photos | Hi there, Dave from Brum here and I have good intentions but little patience 4 years ago I decided a lathe was required, no specific reason just a handy toy. I bought a SPG2109 a slight step up from the mini lathes. It has been used on and off for various jobs that could have been done by other means but, i wanted one Off to find the appropriate section now to get some help in setting up my lathe properly. After 4 years the bearings gave a rumble and I thought it was time to set it up properly. Getting something oval instead of round needs addressing.
PS i maybe quite mad, its the tablets honest
Neil Wyatt | 25/04/2016 09:03:36 |
![]() 19226 forum posts 749 photos 86 articles | Hello Dave, There are probably a pair of nuts on the far end of the main spindle that you can use to adjust the bearings. Neil |
Chris Evans 6 | 25/04/2016 09:47:53 |
![]() 2156 forum posts | Sit and think about what kind of work you want to do on a mill. I love my Bridgeport because it suits my old motorcycle hobby, to big and pricey for a lot of folk unless you come across an early one with 36" table. I am not to far from Brum, in between Lichfield and Burton on Trent. |
Ajohnw | 25/04/2016 10:43:39 |
3631 forum posts 160 photos | Your in the right place if you want to change the bearings. The front cone can be a pain to get off. The fit of the rear ones varies but can sometimes benefit from a very light polish to ease refitting. Arc euro have a pdf on titivating one of their lathes and they are all very similar. For slide adjustment Taig have a good pdf concerning building one of their lathes from their kit. Do it as they suggest lead screws out and look for a bit of resistance pushed by hand. BMTS are in the middle of town. If you take the spindle along and ask they will probably get the front cone off for you and refit a new one. Take the bearings and buy a decent european brand. It's likely to need a bearing press so as they are close no point in trying to knock something up at home and risk damaging the spindle. If you do change the bearings you will need to make a few bits and pieces. Couple of discs a touch smaller than the od of the bearing with a hole in the middle for all thread to press the new shells in. Something to locate in the spindle and keep the all thread central and a spacer to pull the spindle out. I did that badly like this, different lathe but the principle is the same. I didn't make sure the all thread was central. That made it a lot harder to get out and scored the spindle a touch. Fortunately it didn't damage it. What mill is more or less set by what table size and travel you need. In other word the area it can machine and also the daylight under the cutter which limits how "tall" work can be. If you want something that really has some grunt and doesn't take up much space personally I would go for one of these and not one of the variable speed machines. They used to be available in a number of sizes and sold well. I'd hope they still deserve the same reputation. John - |
hth | 25/04/2016 11:53:43 |
93 forum posts 22 photos | Posted by Dave Smith 16 on 25/04/2016 00:49:14:
What or where is Brum ? I am from Gippy , in the S.E. corner of Australia |
Michael Gilligan | 25/04/2016 12:00:41 |
![]() 23121 forum posts 1360 photos | Posted by hth on 25/04/2016 11:53:43:
Hi there, Dave from Brum here What or where is Brum ? I am from Gippy , in the S.E. corner of Australia . Possibly the centre of the Universe
Bazyle | 25/04/2016 12:46:03 |
![]() 6956 forum posts 229 photos | That's where filling in your profile can help, and perhaps an avatar incorporating a location indicator. |
Boiler Bri | 25/04/2016 13:21:05 |
![]() 856 forum posts 212 photos | its near the black country! |
Ajohnw | 25/04/2016 17:41:42 |
3631 forum posts 160 photos | Posted by Boiler Bri on 25/04/2016 13:21:05:
its near the black country! Yes and no. Touch south of some of it. John - |
Ajohnw | 25/04/2016 17:54:34 |
3631 forum posts 160 photos | Posted by Michael Gilligan on 25/04/2016 12:00:41:
Good link Michael. I had never noticed it before. It should add that Brum has more miles of canals than Venice. There is a bit more about the place here https://en.wikipedia.org/wiki/Birmingham John - Edited By Ajohnw on 25/04/2016 18:00:19 |
Dave Smith the 16th | 25/04/2016 18:14:38 |
123 forum posts 33 photos | I will look for my profile and add some info, Erdington near Spaghetti Junction. Not clear in my post above but i have started another thread about setting up my lathe, I changed the bearings already replaced the unbranded ones for some Timken ones. Its an SPG2109 and the manual supplied does not match my lathe it seems, shows a different pulley setup where mine just has one belt and a 2 speed gearbox. Manuals states 2 x 30206 bearings. NO... Luckily i managed to remove the old one before the wrong one was posted out to me. Changed my order to a 30206 and a 32007. Whoever fitted the bearings at the factory must have broken a bit of the casting off, there is a small piece missing, but just a small piece so that shouldnt be a problem. When i try to lift a longer shaft fitted in the jaws i do not get any rock as before and it still spins freely. Are the bearings only lubricated by oil splashing off the gears?
Thanks.
My spindle only has the 1 locking ring with a grub screw, not the 2 locking nuts as per the supplied manual.
JasonB | 25/04/2016 18:36:56 |
![]() 25215 forum posts 3105 photos 1 articles | They should be greased when assembled and then the correct preload set. Have a read of the Timkin Manual and then run your tests from the other thread again when the lathe has warmed up. |
Andy Holdaway | 25/04/2016 18:37:43 |
![]() 167 forum posts 15 photos | Brum and the Black Country mentioned in the same thread? The locals will be up in arms! Andy, from Stourbridge, birthplace of the Stourbridge Lion - has anyone modelled it? |
Dave Smith the 16th | 25/04/2016 21:13:03 |
123 forum posts 33 photos | If i click my name it says no profile?
Andy Holdaway | 25/04/2016 21:22:05 |
![]() 167 forum posts 15 photos | Dave, If you click on 'Settings' on the green bar at the top of the page, at the top left of the page that opens will be 'My Profile'. Click on that link and you can create / edit your profile. Andy |
Dave Smith the 16th | 25/04/2016 22:33:43 |
123 forum posts 33 photos | Thanks for that, I missed the profile link assuming the address page was it. I should have one now? I wondered if the grease would be washed away by the oil from the gearbox, The bearing outer race fits into the headstock and there are drain points below them. The old bearings were covered in oil when i removed them.
Thanks.
