Rufus Roughcut | 12/04/2016 20:55:33 |
83 forum posts 20 photos | Hi Gents Recently aimed to make a replacement 5 tpi worm shaft for a mini cultivator on myford ML7/ ML10 without gearbox as the lead screw is 8 tpi has anyone achieved less than 8tpi lefthand worm shaft on these or could anyone offer suggestions Rufus |
Michael Gilligan | 12/04/2016 21:11:38 |
![]() 23121 forum posts 1360 photos | No practical experience; but I believe the preferred method is 'thread milling' A milling spindle replaces the normal lathe tool, and away you go. MichaelG. |
Bazyle | 12/04/2016 22:34:04 |
![]() 6956 forum posts 229 photos | Common solution is to set up as normal but use the leadscrew handle to provide the power. I believe the ML10 has a handle.... |
John P | 13/04/2016 09:45:37 |
451 forum posts 268 photos | Hi Rufus John
Jon Gibbs | 13/04/2016 09:59:24 |
750 forum posts | Posted by Bazyle on 12/04/2016 22:34:04:
Common solution is to set up as normal but use the leadscrew handle to provide the power. I believe the ML10 has a handle.... Bazyle, Do you mean a mandrel handle? Otherwise how do you guarantee 5TPI? [Edit: Oh, I think I see now - Doohh. Is the idea to drive the spindle from the leadscrew? - thanks] Jon Edited By Jon Gibbs on 13/04/2016 10:03:24 |
Ajohnw | 13/04/2016 10:23:59 |
3631 forum posts 160 photos | 5 tpi from an 8 tpi leadscrew should be ok it's not pushing things all that far. Just run the lathe at min speed and check how fast the carriage moves to be sure you are comfortable with it or turn said leadscrew or the lathe spindle with a handle. If you were making lots and lots of them things will wear out more quickly than more normal pitches but you aren't. For one offs the main problem with this sort of thing can be the speed the carriage moves at. I recollect Rod cutting helical gears like this with a much coarser pitch so had to use a handle. John - |
Russell Eberhardt | 13/04/2016 12:13:06 |
![]() 2785 forum posts 87 photos | I've cut 1" pitch oil grooves by use of a leadscrew handle driving the spindle through the change wheels. More than one way to skin a cat! Russell. |
Roderick Jenkins | 13/04/2016 13:17:15 |
![]() 2376 forum posts 800 photos | Posted by Ajohnw on 13/04/2016 10:23:59: I recollect Rod cutting helical gears like this with a much coarser pitch so had to use a handle.
Indeed. That was using a milling spindle powered gear cutter - analogous to thread milling. Driving a single point threading tool from the leadscrew handwheel is probably going to be difficult since the mechanical advantage is all the wrong way. Personally, I'd do as John suggests and set it up in the conventional way to cut 5tpi - just be aware of the issues, take it slowly and carefully and see if it works. A hand crank on the lathe mandrel is always a useful thing to have and I often use it for thread cutting, it will give you some feedback as to how the job is going before anything breaks! HTH, Rod Edited By Roderick Jenkins on 13/04/2016 13:19:28 |
Ajohnw | 13/04/2016 14:51:27 |
John - |
