Basic Clock Design
James Alford11/04/2016 07:31:27
501 forum posts
88 photos
One day, I should like to build a clock and have drawn out this design, using a detailed guide for designing the escapement. I propose to use a 1 mod cutter and all measurements shown are both the number of teeth and the pitch diameter. It will have a one metre (or thereabouts) pendulum and be spring driven. I have made no attempt yet to design the cosmetics, just the basic gearing.
Can anyone see any glaring errors in my plans?
Thank you.
James.
34 view.jpgJames.
Edited By James Alford on 11/04/2016 07:39:38
Sam Longley 111/04/2016 07:49:03
965 forum posts
34 photos
Yes--- You will need some hands on the frontsmiley
Michael Gilligan11/04/2016 07:53:35
23121 forum posts
1360 photos
James,
Is there a good reason why you have chosen to use spring drive ?
Russell Eberhardt11/04/2016 08:02:06
2785 forum posts
87 photos
Just a suggestion: With a one second pendulum you have a long case so why not make it weight driven. That will give a constant driving force unlike a spring.
Russell.
James Alford11/04/2016 08:02:50
501 forum posts
88 photos
Posted by Michael Gilligan on 11/04/2016 07:53:35:
James,
Michael. The overall design that I have in my mind uses a quite delicate and thin skeleton frame. If I use weights, which was my first thought for simplicity, the frames would need to be somewhat chunkier, I imagine.
Posted by Sam Longley 1 on 11/04/2016 07:49:03:
Doh! I knew that I had forgotten something!
Michael Gilligan11/04/2016 08:51:03
23121 forum posts
1360 photos
Posted by James Alford on 11/04/2016 08:02:50:
James,
James,
A spring would need to have the same stored energy, to drive the clock for a given duration.
You would also [assuming it is to be a useful timepiece] need to consider including a fusee.
If the overall construction is to be light, then an electrically wound remontoire [which could be weight or spring] might be the answer.
James Alford11/04/2016 08:57:30
501 forum posts
88 photos
Michael,
With a spring drive, would not the force of the spring be contained within the barrel, rather than being supported by the actual frame?
James.
Russell Eberhardt11/04/2016 09:04:37
2785 forum posts
87 photos
Posted by James Alford on 11/04/2016 08:57:30:
Michael,
James.
No, it will be balanced by a ratchet mounted on the frame.
Russell.
Michael Gilligan11/04/2016 09:04:43
23121 forum posts
1360 photos
James,
My understanding is that the driving force from the spring is applied to the train through the barrel teeth, and reacted on the barrel arbor ... effective loading being the same as a weight.
Someone please correct me if I am wrong !!
Edit: ... I note Russell's mention of the Ratchet [Pawl]; which does change the vector, but not the total force.
Edited By Michael Gilligan on 11/04/2016 09:09:00
Russell Eberhardt11/04/2016 09:25:48
2785 forum posts
87 photos
The driving force is required to overcome friction, to accelerate the wheels on each beat, and to overcome the pendulum losses (mainly air resistance). You can reduce the force required for acceleration of the wheels by using lighter wheels, perhaps go to 0.6 mod rather than 1 mod?
Russell
Michael Gilligan11/04/2016 09:48:20
23121 forum posts
1360 photos
Posted by Michael Gilligan on 11/04/2016 08:51:03:
Useful notes here: **LINK**
Neil Wyatt11/04/2016 10:44:12
19226 forum posts
749 photos
86 articles
Possibly the frame only needs to be robust in the area between the spring arbour mounting and the ratchet, with a weight the whole bottom part of the frame needs to be beefed up.
Russell Eberhardt11/04/2016 11:51:27
2785 forum posts
87 photos
For a reasonably well made 8 day movement with a one second pendulum the weight required will be between four and five kg. Not really a lot for the frame to support. No beefing up should be required even for a relatively light frame.
Russell.
James Alford11/04/2016 22:02:26
501 forum posts
88 photos
Thank you for all of the replies. I do not know anything about remontoires, so shall look into these.
I can see how the frame would need to be beefed up to brace a pawl if mounted on it. However, I have seen a number of designs, like this one where the pawl is mounted on either the main wheel or the back of the barrel itself. In this case, would not the stored force be contained within the barrel and the wheel, rather than the frame?
James.
Russell Eberhardt11/04/2016 22:37:59
2785 forum posts
87 photos
Posted by James Alford on 11/04/2016 22:02:26:
That is the barrel from a weight driven clock - not a spring barrel. In fact it is from this clock. Is that the sort of thing you were thinking of making?
Russell.
James Alford11/04/2016 23:28:28
501 forum posts
88 photos
Posted by Russell Eberhardt on 11/04/2016 22:37:59:
Russell.
Russel,
That is a good point, one that I had not considered. Yes: the picture in the link is the type of thing that I am thinking of building, albeit without the shelf on which it is sitting.
James.
Russell Eberhardt12/04/2016 07:56:52
2785 forum posts
87 photos
A book describing how to make that clock is available here.
I would also recommend looking at Ian Cobb's site.
Russell
Stephen Benson12/04/2016 08:12:36
203 forum posts
69 photos
I would rethink the 1 module cutter it would make the timepiece too large 0.6 module would better for that style of movement
James Alford12/04/2016 08:26:55
501 forum posts
88 photos
Stephen: I have also come around to that way of thinking and am in the process of doing so.
Russell: thank you for the links.
JAmes.
Ajohnw12/04/2016 10:51:10
3631 forum posts
160 photos
There is a mechanical remontoire here that looks like it may be achievable
By a Frenchman called Robin. There are odd bits on the web about it. The general idea is that this drives the escapement directly and is rewound via some other source of power. The aim should be to minimise the friction etc variations on the drive to the escapement to get round the usual regulation problems with weight driven clocks.
smiley Must admit I am not sure if does that but thought it might be of general interest.
