indexable carbide tools
matthew shay06/04/2016 18:10:43
24 forum posts
hi anyone use the indexable caride tools are there any good
mike T06/04/2016 18:18:14
221 forum posts
Yes and yes
Edited By mike T on 06/04/2016 18:18:37
Brian H06/04/2016 18:22:05
2312 forum posts
112 photos
Definitey worth it even if you don't need repeatability.
Vic06/04/2016 19:14:38
3453 forum posts
23 photos
Only when I need to as HSS is good enough for most jobs I do and far cheaper than buying inserts.
Neil Wyatt06/04/2016 20:23:30
19226 forum posts
749 photos
86 articles
I would have said no stick with HSS a couple of years ago, but now I'm a convert
So yes, but they take getting used to. Most folk here find CCGT and CCMT inserts work well on smaller lathes.
I still have plenty of HSS too.
Dave Smith the 16th25/04/2016 14:35:20
123 forum posts
33 photos
I have some CCGT and CCMT because i tried grinding a HSS lathe bit once and it was poor. Not a very good finish in aluminium at all. I had slightly better success with a thread cutting tool. Probably harder to get that wrong with 2 30 degree grinds
The el-cheapo 7mm and 10mm boring bars from China are much better than anything i can make. Says a lot for me doesnt it. But to me they appear to be quite good and well made. None of the screws have given way yet either.
MW25/04/2016 15:30:13
2052 forum posts
56 photos
Material choices are quite often debated and in my honest opinion the real magic is in the geometry of the tool you are using.
Because of how much more heat it can take the carbide will work even at high speed, so the traditional rules for speeds and feeds can be used alot more leniently within reason, obviously one down side is you can't resharpen it without a green grit wheel. Also because it is an inserted tip, you have to be mindful of how well it is fastened to it's holder, especially with insert p-off tools.
HSS can be sharpened with a standard corundum grinding wheel and is alot more flexible for re making into different sorts of tools.
Michael W
SillyOldDuffer25/04/2016 16:07:43
10668 forum posts
2415 photos
When first starting out as a Model Engineer there's a lot to take in: materials, tools, measuring, dials, cutting speeds, coolants, work holding, reading drawings, suppliers, setting up a workshop, what to buy first: there's an almost endless list of new things to explore.
An advantage of indexable carbide for the beginner is that it eliminates the need to develop a rather difficult new skill, that is how to correctly sharpen HSS with a grinding wheel. It's well worth joining the HSS club but these days newcomers can choose to do it as and when it suits them.
You won't go far wrong with indexable carbide. In my experience it's rather well matched to a small lathe run fast.
Cheers,
mechman4826/04/2016 11:00:50
2947 forum posts
468 photos
+1 Mike T... although I use a HSS tangential tool for most of my cutting, I have a few indexible tips that are used on ally so have most of my needs covered.
George.
Raymond Anderson26/04/2016 12:50:52
785 forum posts
152 photos
Yes, for indexable tooling, without a doubt. I still use HSS although very rarely. HSS is still used in industry on lathes especially for heavily interrupted cuts on HRSA's. So its not dead in the water, even in industry.
MW26/04/2016 13:29:32
2052 forum posts
56 photos
It is also alot cheaper when you consider the huge diversity of HSS cutters that are available whereas carbide being a bit more expensive and harder tends to restrict the range for it somewhat. I am a fan of all materials really, whether it be carbon, HSS or carbide steel i like to own a mixed array of tools for different jobs.
Michael W
Vic26/04/2016 22:08:14
3453 forum posts
23 photos
I was going to say how much I've enjoyed using an insert tool for a job that had clearance issues, but having just switched back to my tangential tool the finish I'm getting is great. smiley Must buy some more inserts I think. cheeky
