Grinding wheel ..balancing hole?
Ian Parkin22/03/2016 17:11:54
1174 forum posts
303 photos
I bought a grren grit grinding wheel for a small grinder I had
after mounting it the blotter flapped out slightly showing a hole
is this ok? looks cast in
I've never seen a hole before on a stone
mechman4822/03/2016 17:39:11
2947 forum posts
468 photos
To balance a wheel you dress it on the periphery using a star wheel dresser, a diamond stone, or in some cases another abrasive stick, From the close up it doesn't look like a cast in hole to me it's more like some sort of impingement on the side of the wheel, in which case the bonding has been damaged, I wouldn't trust it. Give it the 'ring test' I'll lay odds on it gives off a dull, dead sound, bin it! . In all my years in the engineering business, working & teaching, I've never come across this before... I could be wrong but...
George
mechman4822/03/2016 17:45:29
2947 forum posts
468 photos
p.s. on some wheels the steel side washers may have slots in where there is the facility to add counterweights to balance the wheel on the shaft on a set of balance wheels ...I still don't like the look of it.
George.
Ian Parkin22/03/2016 17:54:39
1174 forum posts
303 photos
I've contacted the supplier they asked for the pictures so we will see what they say
David Jupp22/03/2016 18:17:13
978 forum posts
26 photos
May just be the lighting, but I don't like the look of the 'cracks' starting from the hole (especially obvious in top picture).
Rik Shaw22/03/2016 18:18:20
1494 forum posts
403 photos
A ring test is good for revealing an unseen flaw in a grinding wheel but in this case it is not needed. With a visible manufacturing flaw like yours the wheel should not be used anyway.
I have seen two large wheels explode during my time in the industry - both of which were caused by "stackups" rather than faulty wheels and the power released is scary.
Don't take a chance - scrap that wheel before it scraps you.
Rik
Edited By Rik Shaw on 22/03/2016 18:19:40
mechman4822/03/2016 18:59:14
2947 forum posts
468 photos
Posted by David Jupp on 22/03/2016 18:17:13:
Having looked again... this wheel is definitely KAPUT!... it IS cracked ! get rid. better still send pics to retailer & get a replacement / refund, & suggest to retailer they check their stocks.
George.
Brian H22/03/2016 19:07:45
2312 forum posts
112 photos
Ian, please heed the advice above and don't be tempted to try and use it, get a replacement.
Grinding wheels can be lethal if they give way.
Neil Wyatt22/03/2016 19:39:47
19226 forum posts
749 photos
86 articles
I agree with that, I am sure I can see the crack as well.
Above all, be glad you didn't try and use the wheel.
Well spotted David.
Rainbows22/03/2016 20:12:14
658 forum posts
236 photos
Crack it in half so no one ever mistakes it for being safe and mounts it on a grinder. Then maybe keep the pieces to use as handstones?
Ian Parkin22/03/2016 20:49:43
1174 forum posts
303 photos
Right
I pulled it off to investigate more and its definitely not cracked it rings as a stone should
But theres another hole on the other side
these are nice clearly made holes 8mm dia perfectly round and flat bottomed 5mm deep
ones at 12 o clock and the others at 4 o clock on the other side
these are put in during manufacture
its a 125mm 13mm wide wheel and they are 32mm and 35 from the centre
Roger Head23/03/2016 00:30:45
209 forum posts
7 photos
Ian, from the look of that photo, there is NO WAY in this world that I would spin that wheel up, let alone stand in front of it and grind something. It could conceivably be an unfortunate visual effect, but for the sake of a couple of quid I wouldn't risk it. Plain and simple!
Even at the best of times I treat wheels like a faulty gun cartridge that failed to fire.
Roger
Steven Vine23/03/2016 01:21:47
340 forum posts
30 photos
Hi Ian
Well done for spotting that, and for bringing it to light. It was lucky you were paying attention and noticed the label flapping out. Wow.
Would it be possible to let us know the wheel manufacturer (though it looks unbranded to me)? And, can you tell us the manufacturuers code on the label? Best not mention the supplier as that would be unfair I think (unless it was a no name ebay seller).
I did read that the resin bonded type of wheels have a 2 year shelf life. Mind you, I don't think any shelf life deterioration has caused those holes, else the bits would still be there under the label.
Thanks
Steve
Ian Parkin23/03/2016 08:32:12
1174 forum posts
303 photos
Some more photos and a blu tack impression of the holes
And the label which if its not clear is
1 125x13x31.75z 331556/ indistinct
C60 J6U
40 m/s mos-6110
Supplier was chronus so hopefully they will respond to my email pictures todaydsc00941 (medium).jpg
Ian Parkin23/03/2016 09:14:10
1174 forum posts
303 photos
Just had this in from Chronos
Hello
Thank you for the email, the hole is a result of the manufacturing process and it won't affect the performance.
Matt
Chronos
John P23/03/2016 10:07:40
451 forum posts
268 photos
Might be worth having a look at this video by Don Bailey
from Suburban tool in USA.
"How to dress and balance a surface grinding wheel"
In this 13 minute video the principle points of interest
are at 9 min 31 seconds and 10 min 34 sec .
There are many more interesting videos from Suburban
tool that are worth watching for people interested in grinding.
mechman4823/03/2016 10:27:31
2947 forum posts
468 photos
I think we're all waiting on what response you get with great interest.
FWIW...
Looking at the marking quoted & the universal standard marking system... Abrasive, Grain, Grade, Structure & Bond...
C60 J6U denotes ... n.b. The 'U' in your pic is a digital 'V'
C = Abrasive - Carbide
60 = Grain - Medium
J = Grade - medium
6 = Structure - Regular
V = Bond - Vitrified ( resinoid )
Carbide is generally Dark green, light green, sometimes black, your example shows a 'Grey' wheel, to me this denotes an Aluminium Oxide abrasive... Identifiable by 'A' not 'C', so for me, nothing ties in with the 'norm' ... as you say it 'rings', in essence I still have big doubts & am still of the opinion to recommend that you dispose / discard it.
George.
Anna 123/03/2016 10:47:19
72 forum posts
Hi all.
I havn't a clue about how grinding wheels are made but presume it is some kind of moulding process. In which case could it be that the little holes are being made by ejector pins that have not retracted completely during the moulding (similar to plastics injection moulding process)
Kind regards
Anna
Lambton23/03/2016 11:30:16
694 forum posts
I recommend every one mounting and using abrasive wheels of all kinds to get a copy of HSE publication "Safety in the use of Abrasive Wheels " HSG17
It can be downloaded free from the HSE web site. It contains all you need to know about the correct selection, use and mounting of all types of abrasive wheel and is most certainly not a "nanny knows best" publication.
Chris Evans 623/03/2016 11:31:28
2156 forum posts
I spent 50 years in tool making and used thousands of grinding wheels. I never saw one with holes in like that. I would bin it and get another.
