Brain Teaser
Neil Wyatt04/03/2016 15:02:28
19226 forum posts
749 photos
86 articles
What's the difference between tube and pipe?
JES04/03/2016 15:10:52
84 forum posts
71 photos
I would think a tube is straight whereas a pipe can be bent?
But I really don't Know!
JES
Simon Williams 304/03/2016 15:11:21
728 forum posts
90 photos
Weight!
Neil Wyatt04/03/2016 15:12:52
19226 forum posts
749 photos
86 articles
"That's good, but it's not right!"
Rik Shaw04/03/2016 15:16:32
1494 forum posts
403 photos
One is spelt T-U-B-E and the other is spelt P-I-P-E
Cornish Jack04/03/2016 15:18:50
1228 forum posts
172 photos
ISIHAC fans will cry , in unison, Mornington Crescent!! cheeky ... but, of course, the answer is - tube gets you from Piccadilly to Leicester Square, underground, while pipe is what you pack your tobacco in! Simple - next, please
rgds
Bill
Brian H04/03/2016 15:21:01
2312 forum posts
112 photos
Posted by Cornish Jack on 04/03/2016 15:18:50:
rgds
Bill
(All groan!!!)
Brian H04/03/2016 15:23:39
2312 forum posts
112 photos
I believe that tube is small bore and pipe is bigger. Don't know where the cutoff point is though.
Edited By Brian Hutchings on 04/03/2016 15:24:01
Trevorh04/03/2016 15:29:51
316 forum posts
89 photos
Tube is measured by OD Pipe is measured by ID
i hope
Michael Gilligan04/03/2016 15:30:47
23121 forum posts
1360 photos
Close to Brian's answer, but not quite ...
I think the distinction comes with the 'aspect ratio' of wall thickness to diameter.
Likewise, I don't know the transition point ; and I don't know where 'Hollow Bar' comes into it.
[pretty useless today blush]
Michael Gilligan04/03/2016 15:34:18
23121 forum posts
1360 photos
GIYF
dave george 104/03/2016 15:46:22
59 forum posts
This is my view
Tube
Tube is normally used for structural purpose. Sizing is based on the exact outside diameter and wall thickness of the tubing
Pipe
Pipe is normally used to transport gas and fluids. Sizing is based on the nominal outside diameter ( nps ) and the wall thickness
John Hinkley04/03/2016 15:47:33
1545 forum posts
484 photos
When go-karts (as they were called then) were just becoming the latest craze, a few of us got together to build one. Another friend (not mechanically minded) suggested that the chassis would be stronger if we made it out of "solid tube"!
Jon Gibbs04/03/2016 16:03:08
750 forum posts
Posted by Trevorh on 04/03/2016 15:29:51:
i hope
+1
Jon
Jon Gibbs04/03/2016 16:07:24
750 forum posts
Posted by Jon Gibbs on 04/03/2016 16:03:08:
+1
and, confusingly, domestic plumbing copper "pipe" is actually tubing since the OD's of 15mm, 22mm and 28mm are the outside dimensions. In the old days 1/2" and 3/4" copper pipe was pipe.
Jon
Sam Longley 104/03/2016 16:25:23
965 forum posts
34 photos
It is to do with manufacture. tube has a seam - albeit welded after manufacture- pipe is extruded
So your copper pipe is extruded & your steel pipe will have either a butt joint or a welded seam
Trevorh04/03/2016 16:31:45
316 forum posts
89 photos
but sam you are forgetting that you can get seamless pipe in stainless - I use it for my solvent installations, and I think there is also the seamless Black pipe
cheers
SillyOldDuffer04/03/2016 17:17:54
10668 forum posts
2415 photos
Is this just the English language playing games with us again?
English has upwards of 250,000 words happily stolen from just about everywhere in the world. So I can say "I pulled a full-on schadenfreude haka outside the bungalow's gazebo when I saw the naff old-school henna tattoo on that hooker's derriere. " English is a complete mongrel and all the stronger for it, but it's not always consistent or logical.
Pipe is Old English and Tube is Latin. They have similar root meanings. Over the years english speakers have used both to to add subtle meanings to their blatherings. That's why we need ducts and conduits as well
JA04/03/2016 17:23:38
1605 forum posts
83 photos
I worked at Corby steel works (BSC, Tubes Division) in the mid 1970s.
There is no difference.
JA
Neil Wyatt04/03/2016 17:41:47
19226 forum posts
749 photos
86 articles
I think in plain English there is no meaningful difference as JA says, however as a few folk have pointed out
"Tube is measured by OD Pipe is measured by ID"
Good example is BSP threads which confuse all beginners as they appear much toe big for the sizes quoted - beacuse these are the bore sizes of the pipes they are used with.
I'm sure there are exceptions - plastic drain and waste 'pipes' come to mind.
