Roger Hart | 17/02/2016 14:19:05 |
157 forum posts 31 photos | I am making a bearing for a 1/2 inch polished shaft in Delrin (black nylon) and find it is a bit tight and despite use of a 1/2 inch reamer (a bit old though) remains tight. The shaft measures about 2 thou under 1/2 inch. I have tried freezing it an re-reaming (no good) and heating up the shaft (a little better), but short of a new reamer - any ideas? I have had trouble with Delrin before - it seems to 'relax' after machining, is this just me or a general thing?
Andrew Johnston | 17/02/2016 14:49:13 |
![]() 7061 forum posts 719 photos | It's not entirely you! Many plastics, and gunmetal/bronze, have a tendency to close up slightly after reaming. However, if the shaft is 2 thou under I'd be slightly surprised if Delrin closed up that much. So I suspect the reamer. Try drilling it rather than reaming, or bore it. Andrew |
Bob Brown 1 | 17/02/2016 14:56:12 |
![]() 1022 forum posts 127 photos | Do you mean Delrin or Nylon ? |
Jeff Dayman | 17/02/2016 15:02:31 |
2356 forum posts 47 photos | It sometimes does move when large amounts of material are removed. Best to get it within .020 over finished size and let it sit a few days somewhere warm (not hot), then finish to size. Same thing with many plastics. JD |
KWIL | 17/02/2016 15:14:31 |
3681 forum posts 70 photos | If you bore the Delrin with a sharp cutter or CCGT insert you can achieve a good running fit, fine finishing cuts. As Jeff says, large cuts cause trouble. |
Chris Evans 6 | 17/02/2016 16:04:52 |
![]() 2156 forum posts | Delrin is a bugger to machine grabs drills and even when bored to size the size can change overnight ! Razor sharp tool and bore to size, good luck. |
Michael Gilligan | 17/02/2016 16:49:56 |
![]() 23121 forum posts 1360 photos | Roger, As Bob suggests: Delrin is not Nylon ... useful comparison here That said; they can all be troublesome. . My Dad taught me a trick which often helps on difficult materials:
It may, or may not, work for you; but it's worth a try. MichaelG. |
Fatgadgi | 17/02/2016 18:32:49 |
188 forum posts 26 photos | Plastic tends to have a high coefficient of thermal expansion, so it expands when it gets warm, much more than metals. This can make the part shrink an hour after cutting to be tight on a bearing from a reamed hole size. but it's also very difficult to take a small cut in plastic with anything other than a razor sharp tool. And when a tool doesn't cut it rubs and produces heat. Perhaps bore it with a nice sharp HSS tool until you're happy with the fit ? Or as Andrew said a sharp drill's worth a try. Cheers - Will |
Jon | 17/02/2016 19:51:12 |
1001 forum posts 49 photos | Quite agree you wont ream it with a sized reamer it will be well under size. Better way as Will stated bore it but keep It cool.
John McNamara | 17/02/2016 22:42:21 |
![]() 1377 forum posts 133 photos | Hi Roger Rather than making the bearing from a block of plastic, would it be possible to make the block from Aluminium or stainless then fit a say 2mm plastic sleeve. Companies like IGUS actually sell precision plastic dry sliding bearings with an aluminium body. There is a company in the US that makes them too, I cant remember their name! fairly inexpensive. You can also but ready made plastic Teflon or other bearing bushings from most bearing suppliers, even cheaper. |
Danny M2Z | 18/02/2016 06:17:06 |
![]() 963 forum posts 2 photos | I have made a few cleaning rod guides from Delrin and Nylon 66 (they fit into the breech of rifles to keep things concentric). They are usually about 6" long. The rifle cleaning rods have been ground to precisely 0.200". I found that it required a 0.202" very sharp HSS (Sutton) drill bit at low rpm to make a hole for a sliding fit using sprayed coolant for the drill bit. I used a spray can of Inox MX-3 as it was handy and had a spray tube. Lanolin based, it's good for the lathe. Check the swarf, if it starts to clarify it is getting too hot. The deeper the hole, the greater the friction so keep withdrawing the bit, feel it, if it's too hot to touch, slow down. "Softly, softly catchee monkey" * Danny M * |
Roger Hart | 18/02/2016 07:27:42 |
157 forum posts 31 photos | Thanks everyone. I checked the invoice - Acetal Delrin. The job is not critical, made mostly from the junk box and a bit of Delrin rod left over from a previous job. I had some holes tighten up on the previous job - so tricky stuff. Actually the polished rod is only 1 thou under size (checked with Moore & Wright) - so less surprising it was tight. Thanks for the tip about raising a burr on the reamer, think I will try that. Next time - more thought first! |
Martin Connelly | 18/02/2016 08:12:09 |
![]() 2549 forum posts 235 photos | An adjustable reamer may be of use in this material. You only want it slightly over size to make sure it does not cut a lot off, just a very fine swarf that is more like dust. Keep it cool and repeat a few times at the same setting until it stops cutting. Martin
Ian S C | 18/02/2016 10:56:13 |
![]() 7468 forum posts 230 photos | For a tool makers reamer use a bit of the same size as the shaft that is going to fit the hole. After you have cut the angle with a hacksaw, file the angle flat, and leave a wee burr. Don't harden, this will do aluminium, and brass, I'v used it on my hot air engines. |
