Bevel gear and pinion
Rik Shaw20/01/2016 10:03:16
1494 forum posts
403 photos
Just "window" shopping a moment ago and came across this - very good value (I thought). I was quite taken by the variable approach angle of the pinion. I could almost contemplate designing a model / tooling item around this.
Just a thought you understand thinking
Rik**LINK**
Ian S C20/01/2016 10:25:40
7468 forum posts
230 photos
Looks like a good start for a electric or IC powered locomotive.
Ian S C
Michael Gilligan20/01/2016 10:38:54
23121 forum posts
1360 photos
Reduction Gear for a Power Hacksaw, Die-Filing Machine, etc
... Should be simple to integrate a crank-pin or eccentric into that big gear.
ega20/01/2016 10:49:09
2805 forum posts
219 photos
Would this be sintered rather than machined?
Michael Gilligan20/01/2016 10:58:35
23121 forum posts
1360 photos
Posted by ega on 20/01/2016 10:49:09:
Yes ... or a least the ones I have seen are.
JasonB20/01/2016 13:18:38
Thats what I did for my Tidman engine, went looking on e-bay and found a set of 2:1 Mod 1.5 bevels delivered for £6, hardened too. Not worth buying the metal let alone the cutters for a one off
KWIL20/01/2016 16:51:20
3681 forum posts
70 photos
"Spiral Bevel" gear, common in auto differential gear box.
Neil Wyatt20/01/2016 17:43:50
19226 forum posts
749 photos
86 articles
Exactly what I used in my 3 1/2" gauge loco. I plan to replace the rest of the gearbox with toothed belts.
I've bought a pair for my 5" gauge one, when I eventually get round to it...
Mick Henshall20/01/2016 19:18:30
562 forum posts
34 photos
Building my own shaper I bin trying to find a method for raising the table,I had thought of using a set of mitre gears so it could be raised remotely as space is limited to get my digits in, this looks like a possible solution and as I never throw anything away I have some duff angle grinders which should give me the bits I need
Nice one Rik
Mick
Michael Gilligan20/01/2016 19:40:21
23121 forum posts
1360 photos
This may be of interest ...
One tooth of a sintered Timing Pulley: MXL profile = 0.080' pitch
[ it gives some idea of the surface finish ]
