£4. jobs
phil burley | 12/01/2016 18:37:47 |
![]() 45 forum posts 1 photos |
regards Phil |
ASF | 12/01/2016 18:46:30 |
131 forum posts 12 photos | |
Graham Titman | 12/01/2016 20:08:44 |
![]() 158 forum posts 28 photos | Hi Phil when you set it up make sure you put the magnet in the right way up the one i had would not work then i discovered turn magnet over and it worked.Graham |
ian j | 12/01/2016 20:13:46 |
![]() 337 forum posts 371 photos | There's a lot of info. in this previous thread:-**LINK** Ian |
Gary Wooding | 13/01/2016 08:16:39 |
1074 forum posts 290 photos | Doesn't the magnet cause imbalance? |
Michael Gilligan | 13/01/2016 08:46:10 |
![]() 23121 forum posts 1360 photos | Posted by Gary Wooding on 13/01/2016 08:16:39:
Doesn't the magnet cause imbalance? . Gary, In theory, I suppose it must ... But the one supplied is very small and light. MichaelG. |
Howi | 13/01/2016 08:46:28 |
![]() 442 forum posts 19 photos | The Magnet is 5mm in dia and 3 mm thick, hardley likely to cause imbalance. Â Edited By Howi on 13/01/2016 08:47:49 |
phil burley | 13/01/2016 11:50:04 |
![]() 45 forum posts 1 photos | thanks ever so much , I might be able to get it to work now !!! regards Phil |
Ian Hewson | 13/01/2016 16:21:11 |
354 forum posts 33 photos | This got my counter to work first time, from a thread a few weeks ago.
Tim Stevens | 13/01/2016 16:44:35 |
![]() 1779 forum posts 1 photos | If the mass of the magnet really is a problem, make up a dummy in brass or stainless and mount it opposite the real one. I have used on the these tachos on my Champion 20V mill, and it gives a much steadier reading (ie slower changes) than the original. And surprisingly, they do agree pretty well ... Regards, Tim |
norman valentine | 13/01/2016 16:54:49 |
280 forum posts 40 photos | I bought a cheap Chinese rev counter for my milling machine and spent a long time trying to get it to read off the magnet that I had installed. I only got it to work when someone suggested that I had a Hall Effect Sensor that did not require a magnet and would read off the shallow hole that I dad drilled to mount the magnet.
