Hacksaw blades
Old School19/12/2015 13:07:43
426 forum posts
40 photos
Can anyone recommend a source of good quality hacksaw blades for general use in my workshop. Most of my recent purchases have been very poor.
Chris Evans 619/12/2015 13:12:44
2156 forum posts
The same question from me. I prefer "All hard" blades finding they cut better/straighter and last longer than the flexible ones. Like old school my last few batches have been poor.
Michael Gilligan19/12/2015 13:16:17
23121 forum posts
1360 photos
Starrett
Excellent service from their online shop, and top quality.
Ajohnw19/12/2015 13:45:23
3631 forum posts
160 photos
I'll second starrett. I'm ok at the moment. Some on in a builders merchants in Pembrokeshire needed some decent ones and bought a load that were made in France. I bough several after trying one so still have a few left. They may not have any more now. They are on the road out of Milford heading towards Dale in case some one is in that area.
steamdave19/12/2015 14:06:07
526 forum posts
45 photos
Well, I must have had a bad batch of Starrett hand hacksaw blades. The yellow bi-metallic type - the ones where the teeth fall off the blade at the slightest provocation.
Tried different frames and different tensions; makes no difference. I've got some Bahco blades and they are excellent as far as I am concerned. Perhaps a bit more expensive, but if they do the job, it's money well spent.
The Emerald Isle
Michael Gilligan19/12/2015 14:49:02
23121 forum posts
1360 photos
Posted by steamdave on 19/12/2015 14:06:07:
Sorry [and surprised] to read that, Dave ... I've never had a bad one yet.
Old School19/12/2015 16:20:06
426 forum posts
40 photos
Thanks Michael which ones do you use bi metal or all hss?
James Alford19/12/2015 17:32:29
501 forum posts
88 photos
B&Q sell Irwin blades which seem to last fairly well.
James.
Michael Gilligan19/12/2015 17:33:00
23121 forum posts
1360 photos
Posted by Old School on 19/12/2015 16:20:06:
RedStripe all HSS, 32tpi
Note: these have a slight wave in the teeth, which helps swarf clearance.
I bought the box of 50 at a very good price, when they had a Sale smiley
... It's worth keeping an eye on their occasional offers.
Chris Evans 619/12/2015 17:45:10
2156 forum posts
The yellow Starrett and blue Eclipse blades have both been poor over the last few months. I tend to buy 10 at a time so stuck with them if poor quality. My "Donkey" power hacksaw uses Eclipse blades that last well.
IanT19/12/2015 17:46:16
2147 forum posts
222 photos
I've used Bahco (owned by Sandvik I think) in the past with every satisfaction but I'm currently using Lawson Hardflex (a US brand) 12" blades (spotted at a local car boot I'm afraid) that have proved to be very durable. I think any good quality 'brand' hacksaw blade should be OK, just avoid any B&Q/Wickes/Dyas/Screwfix/Tesco etc ( the list is endless) Own Brand or No-Brand junk.....
For my Junior blades - I'm using Eclipse blades that I was lucky enough to spot at a very reasonable price in a branch of Hurst's whilst on holiday on the IoW. So I brought quite a few packets of assorted tooth sizes. Several years back now though...so I must look again this Easter !!
I use bi-metal/flexible blades (rather than 'all-hard'  by the way. I cut mainly "softer" materials (like mild steel and brass) rather than stainless or more exotic stuff. Having a range of 'tooth' sizes is very useful and I use new blades for brass and then 'promote' them on to steel use once they are "run-in"...
Hacksaw blades are one of those things where it really is a waste of money to cut corners on price (same as files). Buy a good brand product from a reliable source Old School and you shouldn't go too far wrong.
IanT
Edited By IanT on 19/12/2015 17:48:00
IanT19/12/2015 17:59:31
2147 forum posts
222 photos
Just checked the Lawson website - $50+ for Qty 5 blades. I purchased half a dozen packs for much less than that (so I'm feeling pleased with myself...)
Interesting spec - perhaps explaining the higher price....
IanT
Michael Gilligan19/12/2015 18:06:41
23121 forum posts
1360 photos
Posted by IanT on 19/12/2015 17:46:16:
... Buy a good brand product from a reliable source Old School and you shouldn't go too far wrong.
IanT
Ian,
I think that was the gist of his original question
Unfortunately... It seems that some 'good brands' may no longer be what they were.
Edited By Michael Gilligan on 19/12/2015 18:08:01
Peter G. Shaw19/12/2015 19:00:29
1531 forum posts
44 photos
Also, I think it is important to obtain a mix of teeth per inch. Currently I have Vanguard All Hard 32T (which I think were an offer at some time through ME), Eclipse 24T (flexible HSS) and two Faithful 18T Bi-Metal blades which I've so far used only on aluminium. For the Junior hacksaw I have a pack of 10 Eclipse 32T described as Spring steel blade, and a pack of Faithful 32T described as manufactured from high quality steel fully hardened and tempered (make of that what you will).
Most work is done with the 24T blades with the 32T blades reserved for narrower work.
Peter G. Shaw
Mick Henshall19/12/2015 22:01:06
562 forum posts
34 photos
Sandvik for me,last ages good value
Mick
Barry Q19/12/2015 22:59:35
41 forum posts
Although have used Eclipse blue blades in the past they seem to wear out quickly these days so now use Bahco Sandflex with no problems to date. Get mine from Axminster Tools but sure other outlets exist.
Barry
"Bill Hancox"20/12/2015 01:20:24
257 forum posts
77 photos
The last batch of blades I purchased a couple of years ago were a mix of Starrett and Sandvik. Both are lasting extremely well especially since I started to lube my blades with this **LINK** . I also noticed an improvement in blade life and performance when I purchased this hacksaw frame. **LINK**
Although I have not as yet tried them, I do have several "Ultra Major" HSS blades (France) that I found in one of my late father's tool boxes. Available in the UK here. **LINK**
Bill
Michael Gilligan20/12/2015 07:48:25
23121 forum posts
1360 photos
A suggestion:
This thread has already revealed a wide range of opinions, based on the limited experience that we have each had with various blades. ... I think we need a proper test; to provide some quantitative results.
Obviously; a small Power Hacksaw with a stroke-counter would provide a suitable test-machine.
If someone has such a machine available: We could each supply sample blades, and the results of a prescribed test would make a very useful reference for us all [at much less cost and effort than each doing our own subjective tests].
... The fee for an article in MEW should cover the running costs of the machine.smiley
Nigel McBurney 120/12/2015 09:22:18
1101 forum posts
I do not use my Eclipse hacksaw much as i have a Rapidor and a Do All bandsaw,when you get older a hacksaw gets handwork, last week I changed my Hacksaw blade,looked in the blade box and there was a pack of eclipse blades 24 tpi, all hard I don't know where they came from,probably an auto jumble,as I don't recall ever buying new blades from a tool supplier in the last 30 years,anyhow started to use the saw and the blade kept jamming,the blue paint was rather thick and there appeared to be no appreciable set to the teeth,tried another one ,result same as before,had a look at the rest,all were marked with the Eclipse brand marks and made in sheffield,perhaps it was Sheffield somewhere in China or India,went back to some other Eclipse blades which I had in stock and all was well.I also buy my bandsaw blades from auto jumblers and s/h tool dealers as my saw has a built in welder, most of the blades have been Starret,though I did pick up a half used box of genuine Do All blade ,unfortunately only enough to make one blade,its cutting performance was far far better than the Starrett blades.
Neil Wyatt20/12/2015 10:13:52
19226 forum posts
749 photos
86 articles
The yellow and green Starret ones if you can get them knock spots of any others I have used. Eclipse and Bahco are OK, but beware of eclipse look-alikes.
