Affordable CAD software?.
Would like to use CAD but software seems expensive.
Bob Mc12/12/2015 19:48:06
231 forum posts
50 photos
Please let me know if this has already been discussed, however I can't find any reference in the Threads for this topic.
I would like to make a start producing drawings using some sort of CAD, however I was blown away when I saw the price of Autocad..!!
is there anything that would be suitable for model engineers and which could be used for uploading to ME magazine for example, surely there must be something reasonably priced....well less than £50 in my case or its out of my league.
Have looked on Ebay and although there are copies of what is claimed to be Autocad, it appears that they are either free trials or somewhat legally 'iffy'; in the first case I don't want drawings disappearing from my files after a certain time, and in the second case I don't want to end up in clink..!!
TSH12/12/2015 19:58:59
45 forum posts
11 photos
Hi Bob,
If you are content to use a 2D package you might like to look at Solid Edge 2D which is free so long as you register with Siemens. See **LINK**
There's a bit of a learning curve but there are plenty of tutorial videos and other resources online.
Good luck.
Trevor
John Hinkley12/12/2015 20:01:30
1545 forum posts
484 photos
I use QCAD from ribbonsoft.com. It's free, open source software, unless you want to upgrade to the professional package (around £20). Suits me fine. Try it - after all it won't cost you anything. You'll doubtless get everybody suggesting their own favourite flavour of program, so I thought I'd get in first!
Or, more accurately, second!  Trevor beat me to it.
Edited By John Hinkley on 12/12/2015 20:02:18
Edited By John Hinkley on 12/12/2015 20:03:27
Bazyle12/12/2015 20:45:56
6956 forum posts
229 photos
Draftsight is free and popular.
The way to search the forum is to go to the home page of the whole site not the forum and a little way down you will see a box called 'google search' which works much better than the forum search. enter "drawing" and see what comes up.
JasonB12/12/2015 20:52:20
Have a look at the threads within the "CAD- Technical drawing and design" topic here
SillyOldDuffer12/12/2015 21:12:28
10668 forum posts
2415 photos
For 2D drawings my vote is for QCad too. Although the free version is sufficient for most purposes I paid for the Pro version because it has extras that simplify some common drawing functions. QCad is relatively straightforward to use.
A disadvantage of full featured packages like Autocad is the learning curve. They include functionality you may not ever need.
I use FreeCAD to experiment with parametric modelling. It's a development project and a bit prone to crashing. Nonetheless I've found it very useful for learning about 3D design and, in the real world, for visualising complex objects. There are some good tutorials on the web.
Edited By SillyOldDuffer on 12/12/2015 21:12:58
John Baron12/12/2015 21:26:44
520 forum posts
194 photos
Qcad gets my vote too ! Though Draftsight is good. Both are candidates for replacing expensive Autocad, but like any piece of software it takes time to learn how to use it effectively .
Another JohnS12/12/2015 22:34:56
842 forum posts
56 photos
Another QCAD user here. Does not need an Internet connection to run, which is an issue for me with some other tools.
I did purchase the "professional version" - not much, and I do believe in supporting people who develop software. (I'm in the same boat...) It's not much to purchase.
3D-wise, for the little I do - SCAD, and FreeCAD.
But, really, for the majority of what I seem to do, 2D CAD - QCAD - is the go-to tool. It runs on Linux, OSX, and - most probably - Windows.
John.
John Haine12/12/2015 23:32:02
5563 forum posts
322 photos
http://www.rs-online.com/designspark/electronics/eng/page/mechanical
Swarf Maker12/12/2015 23:52:27
132 forum posts
7 photos
QCAD is brilliant. It can be used in much the same way as conventional drafting. It does not 'time expire' so you can use any version as long as you wish. It operates on just about any operating system, windows, linux, MAC, and does not 'embed' itself with lots of calls to the operating system. If you purchase a copy you get free updates throughout the following year and you can run different versions alongside each other if you are worried about any of the update versions. If you choose to subscribe for a further year you can do so with a loyalty discount. If you find a problem with it (there is continuous development) then the response is (in my experience) rapid and exemplary.
The dxf files seem to work correctly with the needs of laser, etc cutting programmes but I don't have CNC to check it with.
For 3D stuff the files import OK into TurboCAD v21 Pro, Onshape and Fusion 360.
Peter Krogh13/12/2015 00:49:17
228 forum posts
20 photos
Swarf Maker,
Do you find that QCAD will import from AutoCAD without too many problems? I've tried to use TurboCAD on my MAC but it won't import AutoCAD very well. Leaves out layers, colors, etc.. I'm almost desperate to find a 2D that will run on my MacBook Air 'cause it's just so convenient to sit here in my easy chair compared to at my desk with a PC!
Thanks,
Pete
John McNamara13/12/2015 02:47:45
1377 forum posts
133 photos
Hi Bob MC
Have a look at fusion 360. It is free for Hobby use.
There is plenty of Youtube videos that will get you started.
It can create Gcode for mills and routers (Laser is under development)
Or create files for 3D Printing
Yes you can make 2d paper drawings too.
Link to thread in this site
Swarf Maker13/12/2015 09:46:39
132 forum posts
7 photos
Peter Krogh,
I don't normally require to import files but I have just checked an import of an AutoCAD file from the net. It seems to have imported perfectly OK with all of the layers and attributes as one would expect them to be. Also, I am PC based so I suggest that you give QCAD a try on your MacBook. The latest version (3.12.4) is around $36.
Michael Gilligan13/12/2015 10:15:54
23121 forum posts
1360 photos
Posted by John Alexander Stewart on 12/12/2015 22:34:56:
Another QCAD user here. ...
John,
I have been trying QCAD on the Mac, and am impressed
Agreed ... the 'pro' upgrade appears very reasonably priced
Do you have any opinion regarding the CAM extension question
Thanks
Edit: added links
Edited By Michael Gilligan on 13/12/2015 10:20:51
Peter Krogh13/12/2015 11:56:26
228 forum posts
20 photos
Swarf Maker, MichaelG, this QCAD information is very good, thank you. I will be investigating this program today!
Pete
Ady113/12/2015 11:59:05
6137 forum posts
893 photos
Designspark has been good for me, if you can get it running on your pooter
John Haine13/12/2015 12:05:09
5563 forum posts
322 photos
Just downloaded and installed QCAD, it looks very interesting!
Michael Gilligan13/12/2015 12:12:10
23121 forum posts
1360 photos
In ecumenical spirit ... I recommend the first video in this series:
She uses QCAD for 'pattern-making' ... but not as we know it.
It's one of the best 'introduction' tutorials I have seen for any software.
Neil Wyatt13/12/2015 12:17:53
19226 forum posts
749 photos
86 articles
I use Turbocad. Older versions are very affordable.
Bob Mc13/12/2015 12:39:33
231 forum posts
50 photos
Thanks everyone for the responses...
its great to know that once you are a member of this forum there is a wealth of information from people that understand the situation and have the experience to provide a solution...
Thanks .. will be spending some time looking at your suggestions.
..Bob..
