Chris Denton | 04/12/2015 22:39:08 |
275 forum posts | The first time I used a lathe was at school, 20 years ago, the material I used I don't know what it was.
It was black rod and had a polished finish, it cut like plastic, but the outside finish was patchy grey and black, almost like carbon fibre. When cut the bar was black, so the grey was just on the outside? |
Bill Mull | 04/12/2015 23:19:06 |
33 forum posts | Glass impregnated Nylon perhaps? I used it once to make some panel stand offs,and looked and machined like you describe. |
Chris Denton | 04/12/2015 23:42:31 |
275 forum posts |
No, I've used GF nylon in injection moulding. The scarf was long and soft, GF Nylon swarf would be brittle and hard I imagine. The grey patches were around 10-20mm randomly but regularly spaced from memory
John McNamara | 05/12/2015 06:47:23 |
![]() 1377 forum posts 133 photos | Sounds Like Hard rubber? Often patchy grey black Regards |
John Haine | 05/12/2015 08:03:01 |
5563 forum posts 322 photos | Ebonite? |
Clive Hartland | 05/12/2015 08:12:18 |
![]() 2929 forum posts 41 photos | Sounds like Ebonite, often used for knobs on electrical instruments. Clive |
Chris Denton | 05/12/2015 09:55:12 |
275 forum posts | Is that quote a rigid material? The piece I used was 6 foot long x 1.25" diameter with not much flex along its length. |
Douglas Johnston | 05/12/2015 10:10:11 |
![]() 814 forum posts 36 photos | Could it have been black delrin. I have some bits that have a greyish mottled outer surface but are solid black when cut. Doug
Anna 1 | 05/12/2015 10:25:11 |
![]() 72 forum posts 3 photos | Nylatron, maybe? Anna
Clive Hartland | 05/12/2015 10:32:10 |
![]() 2929 forum posts 41 photos | Send me a couple of feet and i will confirm the item. Clive |
Vic | 05/12/2015 10:40:08 |
3453 forum posts 23 photos | Posted by Anna 1 on 05/12/2015 10:25:11:
Nylatron, maybe? Anna Yes, sounds like Nylatron to me as well, it's common enough. |
Chris Denton | 05/12/2015 11:59:58 |
275 forum posts | Posted by Douglas Johnston on 05/12/2015 10:10:11:
Could be, can you post a picture when you have a chance please. |
Chris Denton | 05/12/2015 12:00:43 |
275 forum posts | Posted by Clive Hartland on 05/12/2015 10:32:10:
Send me a couple of feet and i will confirm the item. Clive Unfortunately it was around 20 years ago and I no longer have it. |
Chris Denton | 05/12/2015 12:02:15 |
275 forum posts | Could be Nylatron, I'll have a better look later, thanks. |
Gary Wooding | 05/12/2015 12:31:27 |
1074 forum posts 290 photos | Here's a photo of a handle I made from a piece of Nylatron rod. As can be seen in the short upright piece, the mottling is not very deep. |
Douglas Johnston | 05/12/2015 15:23:59 |
![]() 814 forum posts 36 photos | Hi Chris- I would love to post a picture of the delrin but I have recently installed windows 10 and my old card reader has stopped working with the computer. Just had a good look at the delrin and the mottled surface appears to be extrusion marks on the surface and looks a bit similar to the nylatron picture but more banded. Doug |
martyn nutland | 05/12/2015 15:54:20 |
141 forum posts 10 photos | Dear Chris Did they really never tell you what it was you were machining? Bearing in mind schools don't normally have huge budgets for this sort of thing, it can't have been from a wide choice. Let's see now... black, maybe grey, cuts like plastic? Something 'ny-lony' it has been suggested? Sort of thing they are making troll suits from these days, I imagine. Best Martyn
Chris Denton | 05/12/2015 22:25:53 |
275 forum posts | I don't know what the troll suit means? Mr White didn't know what it was, I do remember him telling me that all the material they had was donated.
He seemed to trust me to do anything, I was the only student allowed to use his solder remover, also the only person allowed to use the Harrison lathe unsupervised, no idea why. Strangely I now have the same Harrison lathe in my workshop.
Robert Dodds | 05/12/2015 23:56:57 |
324 forum posts 63 photos | Chris, Could it have been a black grade of Tufnol? There were black grades a few years ago and one or two stockist still offer some but it appears to be becoming obsolete Bob D |
Chris Denton | 06/12/2015 10:09:02 |
275 forum posts | I don't think it was Tufnol. |
