Michael Cox 1 | 02/12/2015 11:17:58 |
555 forum posts 27 photos | I have just finished making an extended micrometer, see: http://mikesworkshop.weebly.com/extended-micrometer.html This is based on a design by mklotz. It is fine "as is" for relative measurements but in order to make absolute measurement I need some standard precision blocks that are 25, 50 and 75 mm long to provide calibration standards. I have some imperial 123 blocks that are certified to 0.0005" but what I really require is the metric equivalent of a 123 block i.e a 25 x 50 x 75 mm block. This would make a good calibration standard for the micrometer. Do precision 25 x 50 x 75 mm block exist? If they do who supplies them? Any ideas? Mike |
John Stevenson | 02/12/2015 11:23:33 |
![]() 5068 forum posts 3 photos | Mike, You would be better off with slip gauges. |
Robbo | 02/12/2015 12:31:05 |
1504 forum posts 142 photos | How about Stevensons 10-20-40 or 20 -40-80 mm blocks from ArcEuroTrade? Not what you asked for I know,but needs must sometimes
Martin Connelly | 02/12/2015 12:46:17 |
![]() 2549 forum posts 235 photos | I bought some individual Mitutoyo gauge blocks in May. 611675-131 50mm £33.67 +vat 611635-131 25mm £25.12 +vat Just letting you know the cost if you go this route.
Martin
pgk pgk | 02/12/2015 12:54:43 |
2661 forum posts 294 photos | A bit of 'googling' found this (scroll down for the metric ones) **LINK** And on aliexpress **LINK**
pgk |
steve de24 | 02/12/2015 14:50:37 |
71 forum posts | Would the outer diameter of ball bearing races serve your purpose? Anyone know what typical tolerances they are ground to? Steve
Chris Evans 6 | 02/12/2015 15:52:59 |
![]() 2156 forum posts | I would just use the Imperial ones you have and a calculator. Job done for no cost. |
Neil Wyatt | 02/12/2015 16:32:15 |
![]() 19226 forum posts 749 photos 86 articles | Hi Mike: Google 'micrometer standards' and you will find sources of the little bars with plastic insulating handles that are used to, well, set micrometers. Cheaper than gauge blocks. Neil
steve de24 | 02/12/2015 16:55:12 |
71 forum posts | I think Chris has made the most sensible suggestion. Just use 1", 2" & 3" instead of 25, 50 & 75 mm and calibrate the micrometer at the 0.4mm, 0.8 and 1.2mm points on the micrometer scale instead of calibrating using the 0.0 point. |
Tony Pratt 1 | 02/12/2015 17:19:47 |
2319 forum posts 13 photos | I would go with slip gauges every time. Tony |
Vic | 02/12/2015 18:59:34 |
3453 forum posts 23 photos | Looking at that tool I wouldn't bother, I'd just use a digital caliper or buy a large Mic. |
Michael Cox 1 | 02/12/2015 19:55:38 |
555 forum posts 27 photos | Vic, would you care to elaborate why you think the tool is so bad. Mike |
KWIL | 02/12/2015 21:21:58 |
3681 forum posts 70 photos | The extending bar is probably too flexible for "precise" measurement? Micrometer frames are usually very stiff. |
John Haine | 02/12/2015 21:57:37 |
5563 forum posts 322 photos | Since 1959 the inch has been defined as exactly 2.54 cm so your imperial 123 blocks if made to standard since that date should have precise metric equivalents. Even if before the difference will be so small that you wouldn't be able to measure it.
Michael Cox 1 | 03/12/2015 14:24:55 |
555 forum posts 27 photos | Thanks for all the responses. They have provided some interesting things to follow up on. Mike |
Vic | 03/12/2015 14:49:26 |
3453 forum posts 23 photos | Posted by Michael Cox 1 on 02/12/2015 19:55:38:
Vic, would you care to elaborate why you think the tool is so bad. Mike Too many ways for errors to creep in. I can't help thinking if it was such a good idea it would have been done 60 years ago. I've also seen lots of cheap second hand Mics available over the years. |
Vic | 03/12/2015 14:50:01 |
3453 forum posts 23 photos | Posted by KWIL on 02/12/2015 21:21:58:
The extending bar is probably too flexible for "precise" measurement? Micrometer frames are usually very stiff. Exactly. |
