Hacksaw | 14/10/2015 22:26:32 |
474 forum posts 202 photos | Evening gents, I need to cut a keyway in a pulley , just like Tubal Cain on youtube..
At 12.30 there's a critical bit about setting the correct height of the tool ... how do you do this ? By eye ? And once i've cut this keyway, do i tap a hole in the pulley to fit a grub screw ONTO the key ... or opposite the keyway ? ( Pulley is going on a Honda GX engine to drive a compressor ) Ta ! |
Neil Wyatt | 14/10/2015 22:58:07 |
![]() 19226 forum posts 749 photos 86 articles | Onto the key is best IMHO, less likely to burr the shaft and stops the key from dropping out. Neil |
Hacksaw | 14/10/2015 23:09:11 |
474 forum posts 202 photos | I've just remembered from karting days , you drilled a dimple in the back axle ,opposite the keyway and used a sharp pointed grub to keep the hubs in place ..And one on the key too ! And they still moved ! So how do i set the tool height any ideas , is it obvious and i'm i being thick ? Edited By Hacksaw on 14/10/2015 23:12:19 |
Ajohnw | 14/10/2015 23:37:45 |
3631 forum posts 160 photos | That method needs a warning - a great way of breaking a tooth or two off the rack feed wheel. tt's probably ok with light cuts and narrow keys on soft materials. I made something like this years ago and have even used it to gash silver steel. Not needed all that often but very useful when it is. The one I made went with a myford but the boxford came with one at the correct shaft height. It was based on a casting but not this one just similar with simpler lighter linkages and a flat lever. Too late to post a photo. The hole for the slotting head is drilled and reamed with the casting or block of metal etc fixed to the cross slide so that is always on centre. Some one on here made one that fitted onto the toolpost recently to produce some straight knurled knobs. Your right to wonder about setting the slotting tool height. If it's going on a commercially made spindle the key on that will be dead central. If you cut one on a pulley and go for a precise fit and it's off centre they wont fit together and out comes a file to correct it. The best bet is to turn up a bush, slot that and check that it fits on the spindle then do the pulley when your sure it's ok. That's probably what he did. Oh - it's also possible to slot a shaft but care has to be taken to make sure it doesn't get bent. John - Edited By John W1 on 14/10/2015 23:38:54 Edited By John W1 on 14/10/2015 23:41:24 |
JasonB | 15/10/2015 07:48:19 |
![]() 25215 forum posts 3105 photos 1 articles | I just use a height gauge resting on the cross slide, I know the ctr height of my lathe is 3.387" and just add half the width of the tool, set the gauge to the total and then set the top edge of the tool to tough the gauge. These 3/6" wide x 1" long keyways were just done by winding teh carrage back and forth, I'm not one for making tools if I don't have to |
David Clark 1 | 15/10/2015 09:23:42 |
![]() 3357 forum posts 112 photos 10 articles | Say it is a 1/4" slot, turn a bar in the chuck to 1/4" and set tool so it is in line withe the diameter. Should be in line when the slot is cut. I cut a load of key ways using a Colchester Triumph 2000 lathe. The rack was not powerful enough so I used the tailstock to force the carriage along. Knackered the tailstock which had to have a new nut and knackered me as each key way took at least 20 minutes to cut and I had about 20 of them to do. |
Ajohnw | 15/10/2015 09:25:29 |
3631 forum posts 160 photos | I broke a tooth of a Raglan doing it Jason. It can happen. Mild steel and cutting a key in one of the variable speed pulleys. When I bought the lathe I found one of them was cracked. Lathe still worked ok so made another. John - Edited By John W1 on 15/10/2015 09:27:36 |
John P | 15/10/2015 09:28:27 |
451 forum posts 268 photos | The photo in the album shows this keyway slotting tool
Ajohnw | 15/10/2015 10:22:42 |
3631 forum posts 160 photos | One mod I intended to make but haven't is to angle the tool bit holder, say about 15 degrees. Only problem is that if some one happens to have a drill pad for the tail stock it's more difficult to get the bit hole for the bit on centre in the holder. The holder could be set up in the tool post and drilled. Say in a qctp boring bar holder. The one I use now has a rod end as one bearing. Home made. May as well buy one less the usual spherical bearing John - |
Ady1 | 15/10/2015 10:37:08 |
![]() 6137 forum posts 893 photos | Alternatively, drill/cut a hole with a slot drill and finish off with a file of the correct size |
Hacksaw | 15/10/2015 10:49:03 |
474 forum posts 202 photos | David Clarke wins for simplicity .... Jeez fella, you're sooo mechanically sympathetic ! Just like me
The tool is great, but that'll take me too long to make for the one job . |
