capnahab | 06/08/2015 22:52:18 |
194 forum posts 17 photos |
I am cleaning up various bits that came with my lathe. I have a drilling attachment. After a lot of penetrating oil and fiddling I have got the sleep out (see photo). It was stuck partly with rust. It is held in by pair of half nuts that are pulled together in the bore and lock the sleeve. They are in a blind hole. At some point someone has left this in the rain and the hole has filled with water and is a sump for an emulsion of water rust and oil. This is what subsequently causes the sleeve to get stuck. I want to remove the sleeve and clean out the sump. The bolt and external nut rotate freely through a sleeve and on the end is the inferior/bottom nut. The top nut seems to be part of the sleeve coming through the blind bored hole in the drilling attachment body.Its this sleeve that I would like to remove. Edited By capnahab on 06/08/2015 22:54:24 |
capnahab | 06/08/2015 23:47:57 |
194 forum posts 17 photos | Sorry , I was a bit unclear about the sleeves. The main drill sleeve is out. The one I can't get out is the one that locks the drill sleeve into the body of the attachment. Wondered about a gear puller but don't have one. Edited By capnahab on 06/08/2015 23:48:18 |
Ian Parkin | 07/08/2015 06:52:34 |
![]() 1174 forum posts 303 photos | That locking bolt with the half nuts on should just slide out remove the nut and put some more washers under it to pull it out or a pair of big screwdrivers under the washer thats there now to slide it out
Or is that not what you are wanting to remove? |
capnahab | 07/08/2015 07:19:35 |
194 forum posts 17 photos | Yes . I want the whole mechanism below the visible nut out. I agree the locking bolt should slide out but won't. Have tried all that. |
Michael Gilligan | 07/08/2015 07:28:23 |
![]() 23121 forum posts 1360 photos | Capn' [Assuming that it's the locking device that you are trying to remove ... Now confirmed] . I agree with Ian; it should just slide out [and, to do its job properly, it all needs to move quite freely]. The outer cotter is usually bored clearance, and the inner one carries the male thread ... when the nut is tightened, the whole assembly floats into alignment on the quill. I would suggest more penetrating oil [personal preference being PlusGas Formula A] .... Whilst you are waiting for that to work; make a little 'slide hammer' to fit in place of the existing nut. ... something about 250mm long, with a suitable lump sliding on it should do the trick. MichaelG. . Edit: Here is a nice sketch of something with the right proprtions. Edited By Michael Gilligan on 07/08/2015 07:48:42 Edited By Michael Gilligan on 07/08/2015 07:55:46 |
Brian Wood | 07/08/2015 09:01:27 |
2742 forum posts 39 photos | Capn' There is an old fitters trick for extracting sleeves from blind holes. First make a close fitting shaft for the bore of the sleeve, allow a thou or so of clearance. Pack the hole with grease, push in the newly made shaft and belt the end of it with a big hammer. The sleeve should start to emerge and will 'walk' up the shaft as you continue to drive it out. Regards Brian |
Michael Gilligan | 07/08/2015 09:09:23 |
![]() 23121 forum posts 1360 photos | Brian, I believe it's the split cotter assembly that he's actually wanting to remove. MichaelG. |
Brian Wood | 07/08/2015 09:20:50 |
2742 forum posts 39 photos | Michael, I was a bit confused about what he does want to shift, he might find the tip useful anyway. I have seen it work as well, it is uncanny to see the sleeve/bush make it's way out Brian |
Neil Wyatt | 07/08/2015 09:27:28 |
![]() 19226 forum posts 749 photos 86 articles | Surely just tighten the top nut until the bottom part of the clamp shifts? Neil |
Michael Gilligan | 07/08/2015 09:43:14 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 07/08/2015 09:27:28:
Surely just tighten the top nut until the bottom part of the clamp shifts? . Unless there happens to be an anti-rotation device on the distal part.
jason udall | 07/08/2015 09:46:06 |
2032 forum posts 41 photos | Before we get too brutal. Is there a pin riding in a keyway( to resist rotation )..inserted.from maybe under paint.. ..I have seen such that prevents sliding out of lower half... .. That said might just be crud gluing it in. |
jason udall | 07/08/2015 09:48:08 |
2032 forum posts 41 photos | Michael...Great minds think alike..and fools seldom differ |
capnahab | 07/08/2015 10:06:16 |
194 forum posts 17 photos | This is why I come to this forum, - split cotter , that's what it's called !. Re Neil's suggestion. If I tighten the nut up it pulls the distal half of the cotter up until it hits the proximal part , then the whole assembly reluctantly spins in the hole but will not come out. I think crud is a big issue. I like the slide hammer suggestion. or may make a couple of oversized washers that I can tighten the nut into that will pull up on the bolt.?. |
Michael Gilligan | 07/08/2015 10:14:07 |
![]() 23121 forum posts 1360 photos | Posted by Brian Wood on 07/08/2015 09:20:50:
... he might find the tip useful anyway. . Quite right, Brian MichaelG. |
Brian Wood | 07/08/2015 10:55:25 |
It's not quite the same thing but these photos show how it is set up on my New Progress drill |
Gray62 | 07/08/2015 11:09:46 |
1058 forum posts 16 photos | It's highly likely there is a burr on the top edge of the hole, had this on a few machines. If you remove the nut and washers, can you push the collet parts down the hole far enough to de-burr the top, this may allow the parts to be removed. If you pull the collets out past a burr you will likely gall the parts. |
Neil Wyatt | 07/08/2015 17:10:00 |
![]() 19226 forum posts 749 photos 86 articles | Posted by capnahab on 07/08/2015 10:06:16:
This is why I come to this forum, - split cotter , that's what it's called !. Re Neil's suggestion. If I tighten the nut up it pulls the distal half of the cotter up until it hits the proximal part , then the whole assembly reluctantly spins in the hole but will not come out. I think crud is a big issue. I like the slide hammer suggestion. or may make a couple of oversized washers that I can tighten the nut into that will pull up on the bolt.?. Or put something - a few M6 nuts, perhaps, between the flat parts of the two parts of the clamp and see it that lest you jack it a bit further. Neil |
Michael Gilligan | 07/08/2015 20:15:40 |
![]() 23121 forum posts 1360 photos | Posted by capnahab on 07/08/2015 10:06:16:
If I tighten the nut up it pulls the distal half of the cotter up until it hits the proximal part , then the whole assembly reluctantly spins in the hole but will not come out. I think crud is a big issue. . O.K. Chaps ... this confirms that the capn's cotter does not have any anti-rotation device [at least, not now]. I must, however, mention that they can be quite useful ... My Cowells rack feed tailstock unit [which was adapted to a non-Myford tailstock] has the scars to prove it. Yes, the cotter assembly should self-align, but in the real world they sometimes rotate enough to dig-in. MichaelG. [ I still recommend the slide-hammer ] |
Neil Wyatt | 07/08/2015 21:37:31 |
OuBallie | 08/08/2015 15:23:11 |
![]() 1181 forum posts 669 photos | Got those cotters on/in the stub axles on my Austin Seven and been told 'Easy to remove' except I'm having the Devil's own job in doing so. Geoff - One of those cases of 'Softly softly catchee the monkey' Edited By OuBallie on 08/08/2015 15:23:45 |
