How to cut a 73 tooth prime
Bazyle | 24/07/2015 21:01:56 |
![]() 6956 forum posts 229 photos | Ok, this is not question of how to divide by 73 but "what do you think of this guy's method" There is a home made 73 tooth drummond/myford gear (for metric threads with help of 46 tooth too) on ebay. Since the add will timeout and make the link meaningless in far future reading I will copy the maker's explanation of method: The "next mission" is 127 tooth if you don't realise. |
JasonB | 24/07/2015 21:10:15 |
![]() 25215 forum posts 3105 photos 1 articles | Using the head to give 72 divisions will give 72 divisions on any diameter blank so can't see how he did it |
Ed Duffner | 24/07/2015 21:30:37 |
863 forum posts 104 photos | It would be interesting to see the maths and formulae to see how the 72T and then the 73T were arrived at. One extra tooth might be ok, but could this be one of those situations where mathematically error could creep in as the process progresses? similar to that on some threading (not that it matters in the case of one extra tooth). |
Les Jones 1 | 24/07/2015 21:34:11 |
2292 forum posts 159 photos | I agree with the 72 tooth calculation. I counted the teeth on the gear in the picture and counted 72. I only did it once so I could have miss counted. Has anyone else counted the teeth in the picture. Les. |
Andrew Johnston | 24/07/2015 21:36:07 |
![]() 7061 forum posts 719 photos | Yes, I counted them 3 times, and each time I got 72. Andrew Edit: His OD result is wrong too, for both 72 and 73 teeth.............. Edited By Andrew Johnston on 24/07/2015 21:39:50 |
Les Jones 1 | 24/07/2015 22:22:42 |
2292 forum posts 159 photos | Hi Andrew, Les. |
John Haine | 24/07/2015 22:27:44 |
5563 forum posts 322 photos | The seller obviously read this thread as it now says listing ended because there was an error in the listing! |
Les Jones 1 | 24/07/2015 22:35:50 |
2292 forum posts 159 photos | Hi John, "Q: Have you, em, counted how many teeth there actually are? Specsavers?
Les |
John Stevenson | 24/07/2015 22:38:45 |
![]() 5068 forum posts 3 photos | Interesting though and going off at a tangent but some years ago I made a cock up in counting holes and finished up with 41 1/2 splines instead of possibly 42 ? Long while ago, can't remember but it was my fault, did the cooon trick of counting the first hole as 1
But the tables only give you results that are exact but what if you chose a wrong circle of holes and wrong spacing, how close can you get ?
As I say, interesting. |
Bazyle | 24/07/2015 23:17:23 |
![]() 6956 forum posts 229 photos | mmmm well if you've gone and made the 72 one you could use it as the index plate and do alternate 39 and 40 counts (72*40/73 = 39.45) But I think more likely the plate set has 49 as the highest so have to count 27 and every fifth hole back off to 26. not quite so good. But there again in this csse you have obviously got a Drummond so have a 65 and perhaps 100 tooth gear to use. If only somebody made nice add on plates and sold them on ebay ............................ Edited By Bazyle on 24/07/2015 23:24:11 Edited By Bazyle on 24/07/2015 23:27:52 |
Muzzer | 24/07/2015 23:34:41 |
![]() 2904 forum posts 448 photos | Believe me, I've made a much bigger 4rse of myself in the past and I'm sure I'm by no means alone. Not into casting the first stone or sniggering at honest mistakes... Interesting challenge how you'd do it though and I'm not about to argue with Bazyle. Although I possess a set of dividing plates for my rotary table I've never used them. Being a idle techno nerd, I'd obviously look for an opportunity to develop a CNC / stepper / rotary solution. Muzzer |
DMB | 24/07/2015 23:43:35 |
1585 forum posts 1 photos | I am puzzled about 72/73 ?40 when 63/64 ? 40 = 39.375 exactly. |
John Stevenson | 24/07/2015 23:49:47 |
![]() 5068 forum posts 3 photos | Posted by Bazyle on 24/07/2015 23:17:23:
If only somebody made nice add on plates and sold them on ebay ............................ .
Just done a bit of checking on dividing heads and this is not a complete list. Most heads that follow the B&S standards won't do 73 divisions.
However the Ellis head with plate no 5 [ that have three extra plates 4 to 6 for such as these primes ] wll do 73.
The Cincinnati head with the high count plates, Side E will also do 73.
And the Myford head with plate no 3 will also do 73. On the No 3 Myford COMPATIBLE plate I sell and at the moment it's by direct selling as well as the nornal row of 6 holes, my plate also has a 127 hole ring on the No 3 plate.
I will not be using Ebay as my wife did but later this year Debs and myself will be opening the old website to sell goods made by both of us.
Sorry for the dig. |
Andrew Johnston | 24/07/2015 23:54:15 |
![]() 7061 forum posts 719 photos | Given that 73 is a prime number if you don't have a plate with 73 holes you'll need to use compound/differential indexing. I'd make a plate with 73 holes since I already have a custom plate I made for some other numbers. Andrew |
Bazyle | 25/07/2015 00:06:46 |
![]() 6956 forum posts 229 photos | 72/73 was to use the 72 tooth gear as an index on the advertiser's declared 40:1 dividing head. Just a dig at the fact that now he's made it he could use it for something. Good find on the ratio but 63/64 would need a 64 tooth circle or gear. Most standard plate sets don't go above 50 and, again referring back to the advert being for a drummond/myford (early one) the gear set mostly go in multiples of 5 (though I have a 32 that would do it's not standard as it's not on the original lathe charts) John, I was working along the line of approximations which benefit from a high hole count and as I have a set of your plates was making the oblique reference to the 127 circle you squeeze onto them which I figured many of the regulars on here would pick up on as my post directly followed yours. Edited By Bazyle on 25/07/2015 00:17:29 |
John Olsen | 26/07/2015 02:36:02 |
1294 forum posts 108 photos 1 articles | I made myself a differential dividing attachment to go with my Vertex BS0 dividing head and used it to make a 71 tooth and a 113 tooth gear, mostly just for the interest of it. Used with a 5 to 1 ratio, this pair can give a good approximation for Pi (113/355) although so far I haven't actually found an application for this fact. However it was interesting to do, and it is nice to know that I can know cut pretty much any number of teeth on a gear that I might happen to want. The same attachment could with a little modification be used to cut helices on the mill, although again, that is something I have not actually found an excuse to do yet. But there are ways to divide awkward numbers without the differential setup. The simplest is probably if you have CAD and a printer. Just draw a dividing wheel with the required number of holes, print it out, glue it on a suitable piece of plate, and centre pop and drill all the holes. Now use it as a dividing plate and make another one, which will have all the errors you made with the popping and drilling divided by the ratio of the worm in your dividing head. John |
Andrew Johnston | 26/07/2015 11:26:27 |
![]() 7061 forum posts 719 photos | Even easier if a DRO is available, only one go round the loop is required, like this: Andrew |
Bazyle | 26/07/2015 12:17:06 |
![]() 6956 forum posts 229 photos | John, can you do 106? You may already know why this number is special. |
Neil Wyatt | 26/07/2015 14:55:09 |
![]() 19226 forum posts 749 photos 86 articles | You lot think you're clever cutting prime numbers of teeth! That's nothing,. I can cut gears with non-integer numbers of teeth I'll fetch my coat... Neil |
Michael Gilligan | 26/07/2015 15:45:19 |
![]() 23121 forum posts 1360 photos | Posted by Neil Wyatt on 26/07/2015 14:55:09:
That's nothing,. I can cut gears with non-integer numbers of teeth . Just keep indexing and cutting, Neil You should eventually reach zero teeth. MichaelG. |
