Knurling in the vertical mill
RJKflyer20/07/2015 19:44:11
49 forum posts
Purists, please turn away now.
However, for the more adventurous/tolerant of you, it is possible to do some simple knurling using the vertical mill. I simply don't have space or resources to justify a lathe as well as a mill...
https://www.youtube.com/watch?v=rgon6wE9whs
Clickable link added.
Edited By RJKflyer on 20/07/2015 19:44:55
Edited By John Stevenson on 20/07/2015 19:58:47
Edited By JasonB on 20/07/2015 20:01:54
Brian Wood20/07/2015 19:53:49
2742 forum posts
39 photos
Only I think if you can fit and use a clamp type knurling tool on the item to be knurled.
That should work since there would be no undue side load on the quill bearings, they can handle cutter loadings but not the heavy side loading from a traditional lathe tool post held 2 wheel knurling tool that is forced into the work.
We'll see what reaction this new heresy provokes!!
JasonB20/07/2015 19:59:41
I don't think it will be the actual knurling that will provoke a reactionsecret
John Stevenson20/07/2015 20:03:53
5068 forum posts
Can't see a problem with that other than you need a pair of decent knurling wheels instead of the egg shaped ones fitted.
RJKflyer20/07/2015 20:05:50
49 forum posts
Posted by John Stevenson on 20/07/2015 20:03:53:
Yes John, I agree, but wanted to be confident it was at least doable, as the TiN wheels I have in mind will cost 4 times the tool... (but worth it as always for the right tools).
Neil Wyatt20/07/2015 21:09:52
19226 forum posts
749 photos
86 articles
I wouldn't feel comfortable wearing gloves that near to rotating machinery - my nephew is an ambulance driver and he's seen the results of a glove being pullked off a hand too many times already.
ChrisH20/07/2015 22:28:38
1023 forum posts
30 photos
I agree Neil, the sight of those not too well fitting gloves gave me the shudders. I work with gloves on in the garden, never in the workshop.
Otherwise, and interesting video.
Chris
Edited By ChrisH on 20/07/2015 22:29:52
Enough!21/07/2015 01:04:16
1719 forum posts
Yes, some food for thought there and a video I found useful. I didn't really understand the bit about machining the two surfaces of the clamping bar that were not used on the lathe (and were therefore rough, unfinished). The two surfaces indicated are exactly the two surfaces that are used in my lathe setup.
As for the gloves, I agree with Neil .... I wouldn't do it. And the gloves used don't even look as if they would give any real protection anyway against cuts/gashes (not like say, sheet-metal gloves). Perhaps there's another reason for them RJK?
Jim C21/07/2015 04:38:10
76 forum posts
4 photos
Very interesting method of knurling which is a new one for me !!! Please don't continue wearing gloves near rotating machinery.
mechman4821/07/2015 07:40:27
2947 forum posts
468 photos
Please dispense with the gloves... unless you like taking chances with your hands...
George
Emgee21/07/2015 08:31:17
2610 forum posts
312 photos
RJK If you have a fine downfeed on the quill you can also turn diameters with a lathe cutting tool set up in the vice, or perhaps you do this already.
Emgee
Brian Wood21/07/2015 10:25:44
2742 forum posts
39 photos
I have returned to the post today to see what kind of hornet's nest was stirred up. The U tube video had been added since my first response----neither that or the link work now having been blocked, so I am commenting 'blind' I fdidn't look at it the first time
I will add that mill spindle speed might be a limiting factor. I find clamp knurling on my Myford completely successful in the low back gear range roughly between 30 and 50 rpm. Tooling is all held mechanically.
I can't really see why any hand holding would be considered helpful, let alone wise, with or without gloves.
Brian Wood21/07/2015 15:34:37
2742 forum posts
39 photos
finished test piece.jpgsecond attempt.jpgfirst attempt.jpgTaking things a bit firther today I ran a test on a piece of 3/8 inch steel bar. The set up was on my Dore-Westbury mill, spindle speed 43 rpm using a Marlco knurling tool clamped in a big machine vice.
