Why on earth did I do that...
Brian Abbott17/07/2015 22:33:23
523 forum posts
95 photos
Drawing reads drill #29 x 1 1/8 dp
So I check on the chart and a #29 drill is 3.45' so why on earth do I then drill a 4.2 hole...
need to wake up a bit me thinks...
Muzzer17/07/2015 22:42:58
2904 forum posts
448 photos
Was that the final finishing touch on a years long project? I get more nervous the more work I put into something! Fill it up and redrill?
David Colwill18/07/2015 08:52:26
782 forum posts
40 photos
Known in the trade as a brain fart!
(not that I've ever done one) crying 2
Robbo18/07/2015 09:40:22
1504 forum posts
142 photos
If it were me ( and it has been) it would be down to old age, eg too much activity asked of a diminishing number of brain cells.frown
jason udall18/07/2015 09:52:40
2032 forum posts
41 photos
Shit happens. No claret or fingers on floor. .no harm Try to not repeat the experiment
Edited By jason udall on 18/07/2015 09:54:50
mark costello 118/07/2015 17:23:01
800 forum posts
16 photos
Worse than a brain fart, it messed up the mental diaper in the bed wink.
Dave Halford21/07/2015 10:42:58
2536 forum posts
24 photos
Might make an interesting thread.
Whyoh why did I use a random cast iron welding rod that I'd had for 20 years to try a tooth repair on my rockwell 10" back gear. And why did I then compound the issue by using my rare as hens teeth new 16dp 20pa gear cutter on said welding.
What i ended up with is weld that will just about file and very nearly as hard as witches what'its and a Very, Very blunt cutter that i need to grind 2mm off to get right.
Sob !!!
Jesse Hancock 121/07/2015 12:20:58
314 forum posts
I've got a lot of tee shirts with Oooops written on them.
Using a few barbell weight's as stock for some sprockets. Got to the point where the tool hit the lettering and knocked the tip off! Resharpen and next onto the Vertex in junction with a Laser to mark out.... Last mark ugh ohh too narrow and I don't have a dividing head. Mmmm
Edited By Jesse Hancock 1 on 21/07/2015 12:25:16
OuBallie21/07/2015 16:35:26
1181 forum posts
669 photos
Use the pein (peen) end of a ball pein hammer to knock off filler used on my 1935 Austin Seven, and now have a few perfectly round projections to knock back later, all on a visible rear quarter panel.
Geoff - Stupid or what?
