Comments by users
paul gough | 12/06/2015 10:23:54 |
10 forum posts |
I cannot find any comments by users of these bar bed lathes and would like to hear from users about their experience with it and their opinion of them for model work up to small 5" gauge locos etc. I prefer simple manual machines that are also examples of quality engineering. I like the feel of a quality item in the hand but also the potential of accurate machining. The projects in mind when I set up my workshop range from; pre. 1850 steam locos to hopefully making a working example of an Alco diesel engine as fitted to locomotives. I was a diesel loco maintenance instructor and troubleshooter. I admit it is many decades since doing any machining, actually not since my apprenticeship, but I remember the sense of achievement in using really ancient and simple machines to get accurate results. Really hoping to hear something from an experienced user of these apparently uncommon lathes.
Michael Gilligan | 25/06/2015 06:38:44 |
![]() 23121 forum posts 1360 photos | ... ^^^ BUMP ^^^ ... . Paul, I can offer no comment on the Wabeco lathes; but I've just seen your post on the 'lathe design' thread and thought it worth bumping this one up. MichaelG. . P.S. ... Having just looked at their website: If the machines are as good as the documentation, they should be a delight. Edited By Michael Gilligan on 25/06/2015 06:52:12 |
Bikepete | 25/06/2015 08:27:01 |
250 forum posts 34 photos | This is the D3000: Must admit I'm curious as to why those bar bed lathes even exist. It just looks like a recipe for vibration - can just picture the saddle bouncing up and down like a trampoline in the middle of those slender, unsupported bars. How can that be better in any way than a properly supported lathe bed? I guess if you are DIYing a lathe with minimal resources, a bar bed lathe may be easyish to construct, but Wabeco can clearly make 'proper' lathes too... Suppose it might just be cheaper, but I for one would rather have the cheapest Chinese lathe with a proper bed (i.e. structurally sensible, and could be improved for fit and finish) than such a fatally noodle-like design... or am I missing something here? A bar bed is not intrinsically bad, but it needs an order of magnitude beefier bars! I always quite fancied one of these: Kneller lathe - clearly in a different weight/size league but my point is that the slenderness ratio of the bars is far less... Second edit - Wabeco want 3800 Euros for the D3000! £2700ish. Colour me gobsmacked. Edited By Bikepete on 25/06/2015 08:34:16 Edited By Bikepete on 25/06/2015 08:34:40 |
Clive Hartland | 25/06/2015 09:07:43 |
![]() 2929 forum posts 41 photos | Try the price of the milling machines and the variants available. Most of all the stuff they sell is high priced including tooling. The only thing is the quality is good. Clive |
Ady1 | 25/06/2015 10:02:34 |
![]() 6137 forum posts 893 photos | Must admit I'm curious as to why those bar bed lathes even exist. The Unimat SL market from the 1950s is still thriving and a lot of money flies around because even a clueless amateur can send an entire lathe/milling machine by post The machine can either be used for making little teeny bits or as a stepping stone to greater things It shows you "The Ropes" where lathing/milling is concerned, especially the dirty hands, limitations of your tooling and swarf in the flesh part If you can't handle lathing you pack it up and put it back onto a well known auction site They are perfect entry level units for anyone who has no clue about machining but wants to have a look at the hobby for themselves Edit: The bars on the SL are 12mm which is a bit weedy. Now if they had made a 16mm bar version the machine would be much improved Edited By Ady1 on 25/06/2015 10:09:27 |
Vic | 25/06/2015 10:07:53 |
3453 forum posts 23 photos | If you don't like it they also make a cast iron bed version: https://www.wabeco-remscheid.de/lathes/d4000-prismatic-cast-iron-bed.html |
Vic | 25/06/2015 10:40:41 |
3453 forum posts 23 photos | We had a small CNC milling machine where I used to work which had linear guides and ball screws. Why are these technologies not used on small Lathes and Mills? It obviously works and is surely better than grinding dovetails etc in cast iron beds. I say this because that Wabeco still has dovetails and gibs on the top slide and cross slide. |
paul gough | 25/06/2015 10:53:23 |
10 forum posts | Thanks for the replies so far. However as my initial request was for comments from experienced users I would have thought it obvious that I have researched these lathes as extensively as I can. This includes the manufacturers website and a couple of videos on youtube where a 3000 has been set up for CNC. As to lack of rigidity, I can only go by Wabeco's claim that 5mm cuts are possible. Again my initial post indicated the size of likely models, I am aiming at a compact quality workshop, i.e. small bench lathe, vertical mill, bench grinder and a high speed sensitive drill. I don't consider the price of Wabeco outlandish, if you want an accurate quality item that is meant to last a life time then there is always a premium to pay. If I was awash in funds I would probably go for a 102 Schaublin but I don't have tens of thousands to spend and in any case it would be absurd for my usage. Just to reiterate my usage, pre. 1850 steam locos, therefore small. If I ever want a large dia. item machined it is sensible to get someone with the appropriate equipment to undertake one off jobs. Most of the work on a steam loco can be done on near any quality lathe but this is not so true for the machining of a model diesel engines components. Also, as I said, I like the FEEL of a quality item, any tradesman would know what I mean. Hope there is someone out there in the English speaking world who is an experienced user of these bar bed lathes and is prepared to comment meaningfully on them. Paul Gough. |
JasonB | 25/06/2015 11:36:23 |
![]() 25215 forum posts 3105 photos 1 articles | Go onto some of the German forums and ask there as they are far more commonly used. Magazines like "Maschinen im Modellbau" regularly carry articles about teh Wabeco stuff and accesories/mods in much the way the UK mags always seem to have something for a Myford. Here the mills tend to be more abundant than the lathes |
Vic | 26/06/2015 12:06:47 |
3453 forum posts 23 photos | Once you've finished your "learn to speak German" course Paul let us know what you find out! |
Michael Gilligan | 26/06/2015 12:24:32 |
![]() 23121 forum posts 1360 photos | Posted by Vic on 26/06/2015 12:06:47:
Once you've finished your "learn to speak German" course Paul let us know what you find out! . Vic, Google Translate works very well ... just paste in the URL MichaelG. . Edit: ferinstance Edited By Michael Gilligan on 26/06/2015 12:31:37 |
steamdave | 26/06/2015 13:11:08 |
526 forum posts 45 photos | Posted by Clive Hartland on 25/06/2015 09:07:43:
Try the price of the milling machines and the variants available. Most of all the stuff they sell is high priced including tooling. The only thing is the quality is good. Clive You are right about the high price, but not so sure on the quality. I won't say any more in public, but if you want to know my opinion, send me a pm! Dave |
paul gough | 26/06/2015 13:20:26 |
10 forum posts | Thanks for the German mag. tip Jason. I had a look but I could not find anything. I have used Google translate in German before and found it wanting particularly with technical stuff, however using it and other web translators gets you by in a round about way. The old story, stuff that's free often has limitations. I wonder if Pro Machine Tools has ever sold any of these bar beds in the UK. Paul Gough |
JasonB | 26/06/2015 13:31:57 |
![]() 25215 forum posts 3105 photos 1 articles | I think I would soon tire of having to traverse the carrage using the little geared handwheel at the R/H end of the bed, far better to have a proper handwheel on the apron so you can quickly move the carrage. Have it on the Unimat 3 that wa smy first late and you spend all your time twiddling the handwheel. I had a quick look through a few of the German hobbiests homepages that I have bookmarked to see if any of them had Wabeco machines, all these guys produce very good models and all bar one seem to be using Optimum/Quantum machines which are just the Warco machines in a different colour. |
paul gough | 26/06/2015 14:32:45 |
10 forum posts | Thanks Jason for your effort looking up some German model engineers sites. I have seen a couple where they show their workshops and there seems to be a liking for Optimum lathes and mills and I agree there are some very nice stationary steam models as examples of their work. I considered the issue regarding the saddle drive and yes I agree for most users rack and pinion saddle would be less tedious, however, I for the most part, would be making quite small components on this lathe and don't think it an issue for me. With regard to machine acquisition I would not buy one without at least laying my hands on it and manipulating it, my enquiries are part of my research into a short list of machines and an appeal to users opinions can help guide the process. Paul Gough. |
JasonB | 26/06/2015 15:37:58 |
![]() 25215 forum posts 3105 photos 1 articles | May be worth joining the Yahoo user group to see what they have to say |
Michael Gilligan | 26/06/2015 16:16:20 |
![]() 23121 forum posts 1360 photos | Posted by paul gough on 26/06/2015 13:20:26:
I have used Google translate in German before and found it wanting particularly with technical stuff . Paul, I don't plan to interfere any further, but I must just mention that most of the 'difficult' technical words in German are simple concatenations of several shorter/simpler words. MichaelG. |
Clive Hartland | 26/06/2015 16:18:41 |
![]() 2929 forum posts 41 photos | Such as, ' Crankshaft' is, 'Krankenwelle'. Clive |
Neil Wyatt | 26/06/2015 16:53:01 |
![]() 19226 forum posts 749 photos 86 articles | And 'Hochdruckdampfmotor' is high pressure steam engine - the difficult bit is that google can struggle with taking the spaces out, although it can be a lifesaver.
Getting back to the OP's original topic - I would be interested if the owner of a Wabeco lathe would be willing to write a submission for 'One Man and His Lathe'. Neil |
JasonB | 27/06/2015 20:25:19 |
![]() 25215 forum posts 3105 photos 1 articles | Paul (and Neil) I have found the elusive UK rod bed Wabeco owner. I knew he had one of their mills and then reading a post today spotted the bar bed. Drop Simon (SCO) a PM over on MEM and I'm sure he will be of help. This is his current build.
J |
