Any ideas what these are?
Chris Denton02/06/2015 09:39:30
275 forum posts
These were in a box of stuff I got at a car boot sale yesterday.
They are marked Deloro Stellite and then an imperial size.
Thanks.
[img]http://s10.postimg.org/ebprw0lg9/image.jpg[/img]
[img]http://s10.postimg.org/s446rnc7t/image.jpg[/img]
Edited By Chris Denton on 02/06/2015 09:40:58
Chris Denton02/06/2015 09:42:29
275 forum posts
Chris Denton02/06/2015 09:43:20
275 forum posts
Muzzer02/06/2015 09:43:45
2904 forum posts
448 photos
First link
Second link
Ajohnw02/06/2015 10:00:45
3631 forum posts
160 photos
I suspect they are stellite drills. They can be used to drill hardened material and are said to work best when they get red hot. I've never used one hence said but it makes sense. I did see some stellite tool bits some time ago. Rather expensive.
Vic02/06/2015 10:00:47
3453 forum posts
23 photos
Reamers perhaps?
Ajohnw02/06/2015 10:04:21
3631 forum posts
160 photos
Buck and Hickman sell them
colin hawes02/06/2015 10:39:54
570 forum posts
18 photos
They are stellite drills used for drilling hardened steel even HSS steel.These drills are used in a drilling machine at a high speed and with considerable pressure and they rely on friction causing the job to get red hot locally so the drill can penetrate. I believe that stellite doesn't exist in a soft state so the heat has little effect on it Before tungsten carbide became available it was the most practicable way to get through a case hardened part to prepare the way for a drill. Now obsolete with modern tools. Colin
Ajohnw02/06/2015 12:17:01
3631 forum posts
160 photos
I'm not so sure about them being obsolete. There are variations on the same theme such as this one
I understand this one can only be ground with diamond. Its' fairly easy to buy Stellite tool bits and drills so I'd guess it still has it's applications. Trouble is that even a 5/16 tool bit works out expensive. I have no idea how expensive the tantung stuff is.
Rik Shaw02/06/2015 13:48:16
1494 forum posts
403 photos
You don't need diamond to grind stellite.
Rik
mark costello 102/06/2015 14:32:21
800 forum posts
16 photos
If anyone has some toolbits and wants to grind them on a surface grinder, they better remember they are non-magnetic. Almost found out the hard way.
Ajohnw02/06/2015 15:01:45
3631 forum posts
160 photos
I came across an amateur web site some time ago run by a person who loved stellite lathe tools. It was at the tail end of times when cheaper used machine tool and junk dealers had bins of used tool bits. He used to search through them with a magnet. The site was all good advice elsewhere so I have always had a hankering to try some. £27 for a 5/16 tool bit is a bit off putting though.
The comment about Tantung G and diamonds is just a comment off the web. True / False pass.
Edited By John W1 on 02/06/2015 15:02:14
Russell Eberhardt02/06/2015 15:14:06
2785 forum posts
87 photos
Didn't Stellite used to be used to hard face valves in old sports car engines?
Russell.
Oompa Lumpa02/06/2015 16:10:13
888 forum posts
36 photos
Posted by Russell Eberhardt on 02/06/2015 15:14:06:
Russell.
Yus. You are quite right, sodium filled valves too.
graham.
colin hawes02/06/2015 16:28:45
570 forum posts
18 photos
I don't think there is any advantage at all in using Stellite for lathe tools as HSS is more than adequate for most work and carbide is best for cast iron. I use silver steel for small boring bars. Colin
Chris Denton05/06/2015 14:52:52
275 forum posts
Thanks for that.
Interesting.
I may try them!
S.D.L.05/06/2015 15:52:25
236 forum posts
37 photos
Posted by colin hawes on 02/06/2015 16:28:45:
Eccentric Engineering the makers of the diamond tool holders seem to think that class of material has its merits in model engineering as they have just started selling a similar material. see link below
Steve
Bowber05/06/2015 17:24:34
169 forum posts
24 photos
Used them and it can be quite entertaining, don't have anything flammable near by if you do use them.
I also used to use Stellite to face steel shoes for speedway and grasstrack, goes on nicely once you get the knack.
Steve
