What size DRO on SPG 2217 - BF20 Mill
Neil Bradshaw12/05/2015 20:20:34
22 forum posts
Hi
Can anybody help me solve a bit of a mystery.
I want to fit DROs to my X and Y axis on my SPG 2217 mill
From what I have found out in the manual the maximum X axis is 565 mm on the Y axis it is 220mm.
From what I have worked out I need a 600mm linear scale for the X axis
and a 250mm for the Y axis./
Is this correct or has anybody else got any suggestions or advice
Thanks
http://www.southshields-weather.co.uk
Stuart Bridger12/05/2015 21:03:30
566 forum posts
31 photos
Neil,
Machine DRO have a measuring guide on their website.
Stuart
Enough!12/05/2015 21:45:55
1719 forum posts
You need the measurement length (not the overall length) of the scale to be at least equal to the maximum travel of the table in that axis. In practice, if they are exactly equal, mounting the scale will be a bit finicky since you'll have to exactly match the scale/table travel at each end.
In practice you need a bit more scale travel than table travel .... the more the better up to a point but that will be limited by considerations of how you will mount the scale (remembering that the overall scale length may be quite a bit longer than its measurement length). The other part of the trade off is, of course, cost. Longer scales cost more. Scales also usually come in discrete length increments.
The lengths you have suggested (assuming they are scale measurement lengths and not overall lengths) sound about right. However, don't take the manual's word for the table travel - measure it yourself.
Neil Wyatt12/05/2015 21:50:29
19226 forum posts
749 photos
86 articles
That sounds a bit tight to me. on the X axis you would only have 35mm and just 30mm on the Y axis to fit the read head and two fixing points without any allowance for the scale not being perfectly placed to use all the available travel.
For my chinese scales the read head is about 40mm long, and allow a good 20-30mm for each fixing point, so up to 100mm extra scale length needed.
Enough!12/05/2015 23:06:48
1719 forum posts
Posted by Neil Wyatt on 12/05/2015 21:50:29:
You can often accommodate that by building a "jog" into the bracket that attaches the slider .... effectively centralising the scale. But I agree, if those lengths have to include the end fixing points, they are too small. That's not clear to me in the OP.
Paul Lousick12/05/2015 23:30:48
2276 forum posts
801 photos
The working length of the scales should be longer than the maximum travel of the mill. If the scales bottom out they could be damaged.
Paul.
Redpiperbob04/06/2015 07:26:23
92 forum posts
41 photos
Hi Neil
I have only just seen this thread.
I have just DRO'd my SPG 2217 III
These are the sizes I fitted to mine
100-060-10200 2 Axis Digital Display Unit - USB   £69.05 1 £69.05
100-040-10300 Horizontal Digital Readout Bar 200mm/8" Large Display   £22.39 1 £22.39
100-040-10600 Horizontal Digital Readout Bar 500mm/20" Large Display   £61.20 1
£61.20
I got them from Arc Euro Trade ( No link To them I am just a satisfied customer )
Bob
<edited to stop table going off to the right>
Edited By Neil Wyatt on 04/06/2015 20:49:30
mechman4804/06/2015 10:07:05
2947 forum posts
468 photos
Hi Neil
I have fitted similar dro's to my VM 16 as Bob; but I have the scales that have remote readouts as opposed to having the 2 axis display unit... in the similar lengths... ArcEuro #.... 8" & 24"
100-061-00200... 8"
100-061-00500... 24"
http://www.arceurotrade.co.uk/Catalogue/Measurement/Digital-Readouts-with-Dedicated-Remote-Display
So far both have served well for my needs & the cost is reasonable... See my pics in my album... 'DRO' ...for fixings.
George.
Edited By mechman48 on 04/06/2015 10:13:31
