Rik Shaw | 30/04/2015 18:49:31 |
![]() 1494 forum posts 403 photos | I have to admit to being a little confused when it comes to understanding the "fit for purpose" of any one of hundreds of different types of tip that one comes across when browsing the subject generally. So if I look at say - DNMG - I see that the N indicates zero rake. Is this type of tip intended to be used on a holder with a canted / angled seat which in itself may provide the necessary "attack" -------- or what? Rik |
JasonB | 30/04/2015 18:54:00 |
![]() 25215 forum posts 3105 photos 1 articles | N is the clearance angle not the rake on the top of the tool so it could still have positive rake and be able to fit a flat topped holder though often used on one with a 5deg or so slope on the seat.
Edited By JasonB on 30/04/2015 19:03:29 |
Oompa Lumpa | 30/04/2015 19:29:15 |
888 forum posts 36 photos | Well, I am also having a bit of an adventure, but with Indexable Milling cutters. It's given me a headache to be honest. I am also building a couple of toolholders as I have found a couple of boxes of "Valenite" brand turning tips and if I didn't know better, I would say they are Imperial. The tips are from Canada so could well be. Anyway, I will never get a toolholder for them and I have sufficient to make it worthwhile making tooling. graham. |
Oompa Lumpa | 30/04/2015 19:48:43 |
888 forum posts 36 photos | The Milling tips are SNMM 090308 EL and the Turning tips are TNEG 2521 so if anyone can proffer any clues as to what they are or the breakdown of the nomenclature I would be extremely grateful. I blame bloody Rik anyway because his post about making tooling for the tips started the brain worm going - I knew I had a good couple of boxes stashed somewhere graham. |
Capstan Speaking | 30/04/2015 20:14:29 |
![]() 177 forum posts 14 photos | How's this? |
JasonB | 30/04/2015 20:26:11 |
![]() 25215 forum posts 3105 photos 1 articles | I tend to use the charts on page 452 & 453 in this catalogue as they are the ISO codes rather than the American codes found in the Carbide dept charts |
Enough! | 30/04/2015 22:41:08 |
1719 forum posts 1 photos | I have all the same questions. Hopefully the mooted Workshop Practice Series book discussed here will address all these issues and more. |
Boiler Bri | 30/04/2015 22:42:57 |
![]() 856 forum posts 212 photos | Just sharpen a peice of HSS and forget tips, after all this is model engineering. Old curly would turn in his grave at thoughts of this kind😀 |
Andrew Johnston | 30/04/2015 23:11:05 |
![]() 7061 forum posts 719 photos | Posted by Boiler Bri on 30/04/2015 22:42:57:
Just sharpen a peice of HSS and forget tips, after all this is model engineering. Old curly would turn in his grave at thoughts of this kind Let him spin; although I suspect it would be at a speed more appropriate to carbon steel tooling rather than HSS given that he started before WW1. So to stay true you shouldn't really be using HSS. Andrew |
Ian S C | 01/05/2015 16:19:40 |
![]() 7468 forum posts 230 photos | The tip next to the tool holder is one o the 16 mm tips that I use in the face cutter on the milling machine, I usually use these tips on the lathe after they have been used on the mill. Sorry it's a bit fuzzy |
Jesse Hancock 1 | 01/05/2015 18:02:27 |
314 forum posts | So looking at the(site data) rake angles given you need a heavier rake on the tip the smaller the diameter of the job in hand? Edited By Jesse Hancock 1 on 01/05/2015 18:03:45 |
