Matt C Beech | 12/02/2015 23:18:55 |
![]() 50 forum posts 24 photos | So it's taken almost a year, but I'm now taking the calibration cuts on the lathe, and getting some lovely results. Variations are very small, and aligns with what is expected in the ML7 inspection sheet.
I'll post up a full set of finished photos when I have had a chance to collate them.
Many thanks to all the people who helped with advice on these forums!
Matt |
Nick_G | 12/02/2015 23:21:49 |
![]() 1808 forum posts 744 photos | . That looks a grand job. I bet you are well chuffed with your efforts. ......... And with good reason.!
Nick |
DMB | 13/02/2015 00:50:34 |
1585 forum posts 1 photos | Hello Matt, Nice looking job.Well done. Can I suggest that you cover those motor vents to keep swarf out. I did it with a simple aluminium sheet with 2 slots, loosened 2 motor mounting bolts at chuck end slid plate under foot of motor tightened bolts. Slots in plate to clear the 2 bolts. John. |
"Bill Hancox" | 13/02/2015 05:48:32 |
![]() 257 forum posts 77 photos | Matt Well done. I like the brilliant blue. Whereas you have completed a total refit, you now know exactly what you have for a lathe. There should be no gremlins popping out to haunt you.. I agree that he motor vents should be shielded in some manner; preferably without restricting air flow too much.. Bill |
Peter Bond | 13/02/2015 06:54:14 |
65 forum posts 8 photos | Nice work. I'm still playing catchup, but I don't intend it to take a year (equally, I'm not repainting mine for now). That said, no plan survives contact. |
David Jupp | 13/02/2015 07:46:55 |
978 forum posts 26 photos | Since the motor is TEFC construction, I wouldn't worry too much about additional shielding - unlike some older styles of motor there is no easy route for swarf to get inside. |
Neil Wyatt | 13/02/2015 10:28:53 |
![]() 19226 forum posts 749 photos 86 articles | Lovely job , Matt. Neil |
mechman48 | 13/02/2015 10:47:18 |
![]() 2947 forum posts 468 photos | Super restoration Matt.. well done... George |
Ian S C | 13/02/2015 11:22:47 |
![]() 7468 forum posts 230 photos | David, I quite agree with you about the motor cooling, the fan just blows the air around the outside of the case, rather than through the motor. Ian S C |
Matt C Beech | 13/02/2015 20:02:49 |
![]() 50 forum posts 24 photos | Yep - the fan on the motor just blows air around the outside of the motor through the external heat sink fins. No chance of any swarf getting inside. I did take off the cowl and check though! Matt |
