Chris Denton | 30/01/2015 13:32:01 |
275 forum posts | I am looking to buy another few of these drill bits, they are self centering and have a very steep helix. Any ideas what they are called? |
Chris Denton | 30/01/2015 13:33:21 |
275 forum posts |
Edited By Chris Denton on 30/01/2015 13:33:42 Edited By Chris Denton on 30/01/2015 13:34:36 |
Martin Kyte | 30/01/2015 13:37:32 |
![]() 3445 forum posts 62 photos | Spotting Drills? Martin |
andrew winks | 30/01/2015 13:39:23 |
![]() 117 forum posts 1 photos | Who is selling and price? |
Roger Provins 2 | 30/01/2015 15:44:32 |
344 forum posts | I've always known them as slow spiral drills. Available here (and many other places I'm sure). http://www.drill-service.co.uk/Tools.asp?Tool=020240000000
JasonB | 30/01/2015 16:09:49 |
![]() 25215 forum posts 3105 photos 1 articles | I'd say a slow spiral as well, definately not a spotting drill. |
Neil Wyatt | 30/01/2015 16:28:13 |
![]() 19226 forum posts 749 photos 86 articles | The angle on the end is greater than 118 degrees, rather than less, looks like a stub drill meant for sheet metal to me. Neil |
Michael Gilligan | 30/01/2015 16:40:33 |
![]() 23121 forum posts 1360 photos | Posted by JasonB on 30/01/2015 16:09:49:
I'd say a slow spiral as well, . How strange ... I would have described something with a large "pitch" as having a fast spiral, not a slow one. Might be wrong though ... must check. MichaelG. |
Andrew Johnston | 30/01/2015 16:50:19 |
![]() 7061 forum posts 719 photos | Definitely slow spiral; intended for hard materials, as the cutting edges are stronger than standard helix drills, or for materials that tend to 'snatch', like brass. Presumably if it is self-centring it is 4-facet ground, although that is not clear from the picture. Andrew |
JasonB | 30/01/2015 16:53:05 |
![]() 25215 forum posts 3105 photos 1 articles | |
Harry Wilkes | 30/01/2015 17:06:45 |
![]() 1613 forum posts 72 photos | Talking of drills I was looking through the box of stuff that came with my lathe for a 12mm drill came across a Dormer drill still in it's red sleeve it was a 21/32 don't know why but opened it up and was surprised to find it contained a 3 flute drill never seen one before what would be it use / H |
Michael Gilligan | 30/01/2015 17:40:11 |
. Thanks Jason Happily corrected MichaelG. |
mick | 30/01/2015 17:42:46 |
421 forum posts 49 photos | Sounds like a core drill that's designed to follow a pilot hole and produce a nice true and size hole without the web snatching that would probably occur with a twin flute. |
Neil Wyatt | 30/01/2015 18:17:02 |
![]() 19226 forum posts 749 photos 86 articles | They aren't even slow spiral, they are slow helix. A spiral is only 2-dimensional Neil
Brian Rice 1 | 30/01/2015 18:32:21 |
82 forum posts 11 photos | I remember buy some years ago for drilling brass. |
Roger Provins 2 | 30/01/2015 18:46:36 |
344 forum posts | Posted by Neil Wyatt on 30/01/2015 18:17:02:
For the pendantic maybe (same as a helix staircase?) but for everyone else they are spiral
Roger |
Andrew Johnston | 30/01/2015 19:29:34 |
![]() 7061 forum posts 719 photos | It used to be possible to buy straight flute jobbers drills specifically for brass. Never mind pedantry, if we're being mathematically correct a helix is simply a special case of a three dimensional spiral. There's nothing that says a spiral has to be two dimensional, or indeed limited to Euclidian geometry. Andrew |
Muzzer | 30/01/2015 19:31:57 |
![]() 2904 forum posts 448 photos | Good for brass or possibly tough materials as Andrew says. Saves having to square off the leading edge of a normal steel cutting drill with a slip stone, which many people consider a clever trick. I also have some for drilling aluminium which have a "faster" helix than normal. They came in a mixed bag of drills from Tracy Tools back in the 70s. I was disappointed at the time, as I thought I'd paid for a "set" of drills. However, they are great when used for their intended purpose and they refunded my dosh when I complained which worked for me, being a Scottish-blooded Yorkshireman. Murray |
Neil Wyatt | 31/01/2015 09:10:59 |
![]() 19226 forum posts 749 photos 86 articles | I suppose that if you stretch a point a helix is a spiral on the surface of a cylinder. Isn't there a version of a spiral that links the two 'poles' of a sphere? Neil |
Russell Eberhardt | 31/01/2015 10:29:01 |
![]() 2785 forum posts 87 photos | Interesting link Neil but be careful, someone will be along soon complaining that the OP only asked what that drill is called Russell |
