Which wire to use
mick H06/01/2015 14:51:15
795 forum posts
34 photos
I have a resistance soldering unit which has the wires for the soldering (output) end of things attached to 4mm banana plugs. This allows for convenient selection of heat settings. Unfortunately the wires are a little short and could be usefully extended by 6 to 12 inches. The wires are 4mm measured over the insulation and inside the insulation are composed of many very fine copper strands which gives excellent flexibility. The nearest I have seen to it is speaker cable. The unit is rated at 240V and is fused at 1 amp on the mains side. There is no information regarding the output side. Before I start to search on-line, what is this sort of wire called, please?
Ed Duffner06/01/2015 15:03:05
863 forum posts
104 photos
Hi Mick,
I think what you need is multi stranded wire. It's a little difficult knowing the size from measuring the diameter as cable is measured using cross sectional area of the conductors. At a guess I'd say it was 2.5mm². Normally a unit like this would have some info printed on it, maybe on the base, detailing the output. A photo or model number might help.
Also, if you extend the wires you may change the resistance and affect the operating parameters.
Ed.
JasonB06/01/2015 15:08:01
I would have thought one of the silicon insulated wires of the type found on electrical test meters would do the job. Hard to say from your outside dimensions as to the wire size but as Ed says 2.5mm2 would seem about right.
J
EDIT, something like this 2.5mm" 32Amp
Edited By JasonB on 06/01/2015 15:17:23
Michael Gilligan06/01/2015 15:08:22
23121 forum posts
1360 photos
Mick,
The output should be very low voltage and high current ... If I recall correctly, mine switches from about 1.8 volts up to about 4 volts.
Have a look at American Beauty for useful info.
Edited By Michael Gilligan on 06/01/2015 15:09:44
Steambuff06/01/2015 15:12:57
544 forum posts
8 photos
Normal Speaker Cable is not suitable .. you need something that will carry 20-30 Amps at 0-5 or so volts.
Not at home at moment so cannot look up what to use ... some form of High Current Extra-Flexible cable I suspect.
john fletcher 106/01/2015 16:20:46
893 forum posts
I don't think 4mm banana plug will carry 20 amps for long, nor do I think they can accommodate thick wire either. Speak cable is very supple and comes in several sizes, so I think that's the route to go. The only reservation is will the insulation stand the heat. Its not costly for a small amount, so give it a try. I have some on my big battery charger, with an identification tape on the + lead both ends, its been on years. ted
OuBallie06/01/2015 16:26:22
1181 forum posts
669 photos
Darn you MichaelG wink
You are now responsible for me being side-tracked again! fist
That link to the American Beauty has given me an idea for my Graskop RSU, thanks.
Any thoughts on making the tweezer/pliers?
Geoff - I WILL try not to go off track, but...
mick H06/01/2015 16:33:05
795 forum posts
34 photos
That was going to be my next question. Is there a better form of 4mm plug?
Mick
Michael Gilligan06/01/2015 16:43:06
23121 forum posts
1360 photos
Posted by OuBallie on 06/01/2015 16:26:22:
... Any thoughts on making the tweezer/pliers?
Geoff,
Last time I browsed around the American Beauty site [and their YouTube videos], I was reminded how "Cottage Industry" the tweezers/pliers looked [i.e. very reproducible] ... I haven't tried making any yet; but some Phosphor Bronze strip, and some Tufnol, should get you off to a great start.
Edit: I'm pretty sure that most of use could make something along these lines [or these]
Edited By Michael Gilligan on 06/01/2015 17:01:28
Edited By Michael Gilligan on 06/01/2015 17:03:50
Neil Wyatt06/01/2015 16:47:03
19226 forum posts
749 photos
86 articles
CPC do 4mm banana plugs rated up to 50 amps...
The vast majority are rated about 24-30A so they should be fine.
Yes, I was surprised...
Michael Gilligan06/01/2015 16:48:57
23121 forum posts
1360 photos
Posted by mick H on 06/01/2015 16:33:05:
Mick
Mick,
Some of the 4mm sockets are also screw-down "binding posts" with a cross hole.
... use these with either bare wires or a ring or 'U' terminal on the wire.
Not the cheapest; but here is an example
Edited By Michael Gilligan on 06/01/2015 16:54:42
Michael Gilligan06/01/2015 16:56:41
23121 forum posts
1360 photos
Posted by Neil Wyatt on 06/01/2015 16:47:03:
Methinks the rating is improved by the large pinch of salt.
Neil Wyatt06/01/2015 17:21:43
19226 forum posts
749 photos
86 articles
Not really, over 12mm of 4mm diameter plug the potential total contact area is about 150 mm^2, Assume just 10% contact area and that's 15mm^2 compared to, say, 4mm^2 or less on a typical 240V 13A switch.
Michael Gilligan06/01/2015 17:43:43
23121 forum posts
1360 photos
Posted by Michael Gilligan on 06/01/2015 16:48:57:
Sorry, forget the ring terminal ... the tops don't come off blush
P.S. if you must use plugs, I suggest this multi-spring style.
Edited By Michael Gilligan on 06/01/2015 17:44:23
Edited By Michael Gilligan on 06/01/2015 17:57:10
Michael Gilligan06/01/2015 18:04:10
23121 forum posts
1360 photos
for Geoff:
14 swg Nichrome wire [for tweezer tips] is readily available on ebay
Edited By Michael Gilligan on 06/01/2015 18:09:10
Les Jones 106/01/2015 18:07:38
2292 forum posts
159 photos
Hi Mick,
This wire from Maplin code XR57M will probably be suitable.
Les.
mick H06/01/2015 21:15:28
795 forum posts
34 photos
Thank you gentlemen for your usual comprehensive assistance and pointers to where to get the stuff. Very much appreciated. Meanwhile I look forward to the development of those tweezers!
Mick
Michael Gilligan07/01/2015 10:44:38
23121 forum posts
1360 photos
Just dug my transformer out of the garden shed blush
... they both need a bit of cosmetic attention.
Note the current rating, and the 7/16" diameter output terminals.
Model Number is P.05 ... but I can't find a Manufacturer's name.
Michael Gilligan07/01/2015 15:21:33
23121 forum posts
1360 photos
Posted by mick H on 06/01/2015 21:15:28:
... Meanwhile I look forward to the development of those tweezers!
Mick,
I have just found this excellent DIY page
Neil Wyatt07/01/2015 15:54:21
19226 forum posts
749 photos
86 articles
Cripes Michael,
You could probably use that as an arc welder on 25V...
