Raymond Sanderson 2 | 13/12/2014 09:33:25 |
![]() 450 forum posts 127 photos |
The drawing and plan was for 24tpi but a mate rang to say his boss offered me use of 16tpi tap and die so I jumped at it. I have not cut threads on a lathe for over 40 yrs. I got to dry fit stage today and turned the Pole to suit they are not true round one being very oval indeed. Not sure why photos and text stuffed up order. Maybe me and my stuffy head sinus worst this year. Edited By Raymond Sanderson 2 on 13/12/2014 09:40:00 |
Neil Wyatt | 13/12/2014 15:17:27 |
![]() 19226 forum posts 749 photos 86 articles | Hi Ray, Looks a nice job. > they have a coin in the top of the handle. If you're caught short out in the hills you can spend a penny without causing a scene. Neil |
Circlip | 13/12/2014 17:55:14 |
1723 forum posts | ES might have been a better choice
Regards Ian. |
Raymond Sanderson 2 | 14/12/2014 07:18:27 |
Circlip/Ian not sure what you mean ES??? |
Gordon W | 14/12/2014 09:35:53 |
2011 forum posts | ES edison screw? Looks like a drain rod joint to me. |
Ian S C | 14/12/2014 10:06:11 |
![]() 7468 forum posts 230 photos | Or a rod for sweeping chimneys. Saw some thing today that reminded me of this thread, a two piece Pool Cue in the local second hand shop. I had a look at it, and it has a 8 mm thread in the brass fitting. I think one of my nephews has a three part pool cue he bought in Brisbane. Ian S C |
Bazyle | 14/12/2014 11:20:23 |
![]() 6956 forum posts 229 photos | Don't worry. Drain rods have a far courser thread, more like 6 tpi. You might want to thnk of a way to stiffen the thread so it doesn't undo from the jarring of hitting the ground in use, yet not jamming up. I suggest graphite lubrication from a smokey candle flame as it isn't slippery like vaseline (you wouldn't use oil on a domestic product I hope) yet prevents cold welding. You might consider putting (metric for long term availability) spanner flats on the joint or they will be tempted to get the mole grips out. Show then the old trick of patiently tapping a brass joint to loosen it if jammed. |
Raymond Sanderson 2 | 14/12/2014 12:02:13 |
![]() 450 forum posts 127 photos | Posted by Gordon W on 14/12/2014 09:35:53:
ES edison screw? Looks like a drain rod joint to me. Well now all it needs is loo roll I guess. |
Raymond Sanderson 2 | 14/12/2014 12:12:26 |
![]() 450 forum posts 127 photos | Posted by Ian S C on 14/12/2014 10:06:11:
Or a rod for sweeping chimneys. Saw some thing today that reminded me of this thread, a two piece Pool Cue in the local second hand shop. I had a look at it, and it has a 8 mm thread in the brass fitting. I think one of my nephews has a three part pool cue he bought in Brisbane. Ian S C Ian pool cue joiner Link Had been considered by the owner and other willing to do the job but as I pointed out the stress after boring and weakening the strength of the wood centre it would split, shatter break. The use of an outer sheath strengthens even tho I have removed 1/8th to allow reasonable mating of timber and brass. I had a similar joiner as an example to show the owner,
Raymond Sanderson 2 | 14/12/2014 12:20:43 |
![]() 450 forum posts 127 photos | Posted by Bazyle on 14/12/2014 11:20:23:
Bazyle having used the 16tpiUNF its tight and all that would be required once it wears is thread tape or a locking screw through to the relief area above the thread. Even that could undo. I had considered a Bayonet type fitting with a lock screw but for my level of expertise in machining my limited machines and as job is a FREEBIE I opted for the quickest, stable option that the owner was more than happy with. |
Michael Gilligan | 14/12/2014 12:31:10 |
![]() 23121 forum posts 1360 photos | Posted by Circlip on 13/12/2014 17:55:14:
ES might have been a better choice . Raymond, In the absence of any clarification from Ian ... I guess this was probably an oblique reference to John Stevenson's recent discussion of lampholders. MichaelG. |
Circlip | 14/12/2014 14:11:23 |
1723 forum posts | Sorry guys, my feeble attempt at jocularity. Brownie points to MichealG for deciphering. Beauty of ES is that even the Ya- er Americans find that hard to cross thread. Cold hands may find it difficult to locate and screw the bits together so a "sleeved" thread may help.
Regards Ian. |
Circlip | 14/12/2014 16:48:00 |
1723 forum posts | Sorry MichAelG .
Regards Ian. |
Raymond Sanderson 2 | 14/12/2014 20:34:50 |
![]() 450 forum posts 127 photos | Thanks Michael and Ian for the link and the laugh. Cold weather in Australia ???? Today is going to reach 34C here in Sydney. Yes we do0 have snow yes it does get down to -10C in some regions unless the owners head back to NZ or maybe Tassie mountain walks where the wind chill cuts through you like an ice princess curse it should all be ok. If my feeble hands can screw them together the younger owners should be able to.........I hope. |
Ian S C | 15/12/2014 11:06:07 |
![]() 7468 forum posts 230 photos | The pool cue I saw had a joint very similar to the one you have on the walking stick. Ray you better steer clear of parts of town for a while, bit of a worry. Ian S C |
Raymond Sanderson 2 | 15/12/2014 22:49:01 |
![]() 450 forum posts 127 photos | Posted by Ian S C on 15/12/2014 11:06:07:
Not seen one like that Ian on a pool cue City only head in there now days on special occasions ok so was in thee last month and not far from the excitement of the last 24 hrs. All done and dusted at 2am besides with the area we live in since the 50's its been a league of Nations/Nationalities and has increase so with such as Indian, Afgans, Lebs, Turks, Kiwi's and Fijian all sorts of religions why even the bikies have to squeeze in with us all.
