Jack Foreman 1 | 24/11/2014 09:39:54 |
![]() 99 forum posts 17 photos | A bit of a shot in the dark. Can anyone, offhand, tell me the size of the internal drawbar thread in a Clarkson 30INT chuck please? I have to make the drawbar for the mill to secure the chuck. Thanks |
Robbo | 24/11/2014 10:59:31 |
1504 forum posts 142 photos | Probably 3/8" x 16 tpi BSW, but I have a 3MT one which is 1/2" x 12 tpi BSW.. I thought "I'll look in the Operators Handbook" - full of info, but just says "standard tapping" for the drawbar thread! No it doesn't say what a standard tapping is! |
Neil Wyatt | 24/11/2014 11:02:00 |
![]() 19226 forum posts 749 photos 86 articles | Hi Jack, it's probably M12 or 3/8 BSW - such chucks available with either thread. Try an M12 screw in it and see if it fits. Neil |
Bazyle | 24/11/2014 11:03:38 |
![]() 6956 forum posts 229 photos | It is either M12 or 1/2 inch x 13tpi (UNC as it is not a British invention) depending on age and nationality. So best to make it double ended. Int 40 is M16 or 5/8 Int 20 takes the same size as Int 30 though my sample might be INT 25. Edited By Bazyle on 24/11/2014 11:11:27 |
Bazyle | 24/11/2014 11:50:48 |
![]() 6956 forum posts 229 photos | Owing to the confilcting advice I should just clarify - I have double checked my drill chuck, Clarkson chuck copy, and MT2 adaptor are all M12. My original drawbar that I obviously don't use is 1/2x13 and is the machine's 40 yr old original. So I would go with the metric and if you turn up an American holder by mistake you might be able to offload it on me. Be aware that you might encounter some home made arbors that are smaller made by skinflints. Check out Arc Euro for INT30 & 40. His adaptors are cheaper than Ebay starting prices. |
Andrew Johnston | 24/11/2014 12:03:18 |
![]() 7061 forum posts 719 photos | My older INT40 tooling is definitely 5/8" BSW, not UNC, just to confuse this issue. Andrew |
Michael Gilligan | 24/11/2014 13:13:24 |
![]() 23121 forum posts 1360 photos | Jack, With so many choices offered ... I would suggest just screwing a piece of wooden dowel into the female thread; then unscrew it and measure the tpi or the metric pitch from the imprint. MichaelG. |
Gordon W | 24/11/2014 14:05:29 |
2011 forum posts | Just try a few likely looking screws, take it down to a bolt shop if you don't have any. |
David Clark 1 | 24/11/2014 14:26:03 |
![]() 3357 forum posts 112 photos 10 articles |
Some of the 40 international where unc or unf I think!,
Nick_G | 24/11/2014 16:02:17 |
![]() 1808 forum posts 744 photos | . I have a Int 30 fitting on my Boxford mill. It's a standard M12 course. Edit :- What mill have you got Jack Nick Edited By Nick_G on 24/11/2014 16:03:43 |
S.D.L. | 24/11/2014 18:31:49 |
236 forum posts 37 photos |
Posted by Jack Foreman 1 on 24/11/2014 09:39:54: A bit of a shot in the dark. Can anyone, offhand, tell me the size of the internal drawbar thread in a Clarkson 30INT chuck please? I have to make the drawbar for the mill to secure the chuck. Thanks I have seen M10, 3/8 BSW, 3/8 UNC, M12 and 1/2 BSW, and I expect there was 1/2 UNC as well. I brought some threaded rod back from the U.S. for the UNC one. Try some bolts or if very carful some Taps to try them. A lot of auto locks have the size in very feint writing on the side, if tarnished try cleaning up wit a bit of WD40 and fine scotchbrite.
Steve
Jack Foreman 1 | 24/11/2014 18:49:44 |
![]() 99 forum posts 17 photos | Posted by Nick_G on 24/11/2014 16:02:17: . I have a Int 30 fitting on my Boxford mill. It's a standard M12 course. Edit :- What mill have you got Jack Nick Edited By Nick_G on 24/11/2014 16:03:43
An AEW Viceroy Horizon, Nick Horizontal at 25 - 2039 revs, with lots of cutters The drawbar and vice handles are the first jobs to be done. Edited By Jack Foreman 1 on 24/11/2014 18:50:37 Edited By Jack Foreman 1 on 24/11/2014 18:50:54 |
Jack Foreman 1 | 24/11/2014 18:59:00 |
![]() 99 forum posts 17 photos | Wow. Thank you all for your input. Varied and interesting too. Much appreciated. By a process of elimination I have found it to be a 1/2" x 12tpi BSW thread. I found a 1/2" x 13tpi thread which bound up at 3.1/2 turns, so I tried a 12tpi thread gauge and it appeared to fit. Then I found a 1/2" x 12tpi BSW plug tap and it was perfect. And, miraculously, I also found the 1/2" x 12tpi BSW die, to go with it. So tomorrow, I will make the drawbar and the vice handle. Once again, many thanks. |
Ian S C | 25/11/2014 11:05:35 |
![]() 7468 forum posts 230 photos | I made my draw bar by getting two bolts from the junk box, cut the heads off, and weld them together. Ian S C |
Jack Foreman 1 | 25/11/2014 14:59:17 |
![]() 99 forum posts 17 photos | Drawbar is made. Complete with a brass compression washer Edited By Jack Foreman 1 on 25/11/2014 14:59:57 |
Nick_G | 25/11/2014 15:07:46 |
![]() 1808 forum posts 744 photos | Posted by Jack Foreman 1 on 25/11/2014 14:59:17:
So I may set up a heater tomorrow and do it then.
I plumbed in a radiator into mine. But it joins the house so was quite a simple job to put one 'back to back' with one inside the house. What I wish for though is a wood burning stove in mine. Just not got the space though.
Nick |
Jack Foreman 1 | 25/11/2014 19:03:15 |
![]() 99 forum posts 17 photos | I do have a couple of very old Baxi Brazillia gas heaters in my workshop. But it is three years since I last used them, And I'm reluctant to take the risk of blowing myself to kingdom come, before I've had a chance to really become familiar with the new mill. |
