Harry Wilkes | 21/11/2014 15:21:46 |
![]() 1613 forum posts 72 photos | Hi knowing many forum members dabble in electronics so I know its maybe a long shot does anyone know where I can obtain a 3V Lilliput bulb ? I have obtained some 6v 50 mA ones but they need to be 3V . I need them for a old mini handheld torch with flex extiontion that uses 2x 1'5v AAA batteriess.
jason udall | 21/11/2014 15:36:41 |
2032 forum posts 41 photos | I would be tempted to use a white led....made up into the liliput screw base.. |
jason udall | 21/11/2014 15:37:48 |
Roger Provins 2 | 21/11/2014 16:19:35 |
344 forum posts | Have you tried BLT **LINK** Phone them. Edited By Roger Provins 2 on 21/11/2014 16:20:18 |
john fletcher 1 | 21/11/2014 16:31:17 |
893 forum posts | Try Squires 100 London Rd Bognor Regis West Sussex PO22 1 DD. 01243 842424, they also have leds.Ted |
JohnF | 21/11/2014 17:00:04 |
![]() 1243 forum posts 202 photos | Harry , not sure what a Lilliputbulb is but mini mag lite torches use a very small 3v bulb, about 1/8" dia with two prong contact. Easy to buy from many retailers of Maglite torches. |
magpie | 21/11/2014 17:15:38 |
![]() 508 forum posts 98 photos | Try www.hobby.uk.com Cheers Derek. |
Michael Gilligan | 21/11/2014 20:17:17 |
![]() 23121 forum posts 1360 photos | Posted by JohnF on 21/11/2014 17:00:04:
... not sure what a Lilliputbulb is ... . Although this not a suitable replacement, it does have a good sketch of the LES base. If I recall correctly, this is the base used on older Christmas Tree lights. Sorry, I don't know where to source 3v Lilliput bulbs these days ... but I agree that it would be an ideal thing to update to LED. MichaelG.
Neil Wyatt | 21/11/2014 20:49:46 |
![]() 19226 forum posts 749 photos 86 articles | Derek (Magpie) has got the answer . Neil |
Harry Wilkes | 21/11/2014 20:52:40 |
![]() 1613 forum posts 72 photos | Posted by jason udall on 21/11/2014 15:36:41:
I would be tempted to use a white led....made up into the liliput screw base.. Many thanks for all your reply it seem like the above is the way to go, so any advise on which led to purchase ? Cheers H
Ian P | 21/11/2014 21:08:23 |
![]() 2747 forum posts 123 photos | Harry If you only have 3 Volts available, forget the white LED! LEDs are generally current driven and in most applications are fed (with a voltage) via a resistor. The actual voltage across LEDs varies with the manufacturing technology and the colour, its less than 2 Volts for a red LED but about 4 Volts for white and blue ones. Another thing to bear in mind is that LED usually give out illumination in one direction whereas an incandescent filament emits light in all directions. I have seen (but not this Christmas) decorative lighting novelties that consist of a two cell battery holder with about 10 lengths of semi-stiff thin green wires each terminated in a tiny bulb. I think they are intended to be entwined in miniature trees as decoration. They would be a very cheap source of ready wired lighting for models. Ian P
Extra lines removed after posting Edited By Ian Phillips on 21/11/2014 21:09:09 |
Michael Gilligan | 21/11/2014 21:18:48 |
![]() 23121 forum posts 1360 photos | Posted by Ian Phillips on 21/11/2014 21:08:23:
Harry If you only have 3 Volts available, forget the white LED! . Ian, Sorry to disagree, but; the world is full of White LEDs running very adequately on [nominally 3volt] coin-cells, and pairs of AA or AAA Alkaline pen-cells. MichaelG. |
Ian P | 21/11/2014 21:34:45 |
![]() 2747 forum posts 123 photos | That was a real oops on my part! White LEDs do need a higher voltage than red but as you say it is not as high as 4 Volts. I too have seen lots of cheap devices where white LEDs are connected straight across a 3 Volt battery without any apparent component doing the current limiting so just relying on the batteries internal resistance. Without knowing more about the OPs project its hard to speculate whether white LEDs would be suitable. If the supply is 3 Volts and has (relatively) unlimited current capability then the resistor value would be very critical especially if the supply was unregulated. Ian P
magpie | 21/11/2014 22:21:54 |
![]() 508 forum posts 98 photos | If the torch has a reflector then a bulb is the way to go, as Ian said, LEDs only emit light in one direction making a reflector a waste of time as very little of the output hits it. I have tried many times to use reflectors with LEDs and never managed to improve beam width. Cheers Derek. |
Michael Gilligan | 21/11/2014 22:23:37 |
![]() 23121 forum posts 1360 photos | Posted by Harry Wilkes on 21/11/2014 20:52:40: ... any advise on which led to purchase ? . Harry, If the existing set-up is just a bare bulb on the end of a flexi, then 'most any 5mm White LED would probably be OK; but if it has a fancy reflector, we may need to think a little harder. Could you post a close-up photo of the business-end of the flexi torch ? Thanks MichaelG.
Edited By Michael Gilligan on 21/11/2014 22:24:12 Edited By Michael Gilligan on 21/11/2014 22:27:51 |
Les Jones 1 | 21/11/2014 22:31:39 |
2292 forum posts 159 photos | Hi Harry, Les. |
pgk pgk | 21/11/2014 23:00:36 |
2661 forum posts 294 photos | Not sure if this is helpful or not... You can file off the surface of leds to diffuse the light if you want to use the reflector.. but that seems a bit counter productive. More sensible perhaps to use more that one led or use a surface mounted type which are less focucussed. Also if after miniature bulbs then those sold for use in auriscopes and ophthalmascopes are tiny.. but you would need a different holder, Heine is one supplier.
pgk |
Michael Gilligan | 22/11/2014 06:22:31 |
![]() 23121 forum posts 1360 photos | Posted by Bogstandard2 on 22/11/2014 06:16:22:
Why ... . Maybe this is why. MichaelG. |
Nicholas Farr | 22/11/2014 08:04:06 |
![]() 3988 forum posts 1799 photos | Hi Michael, if you click on Derek's link and then in the left hand column on componets you wil find electrical and electronics and then click on bulbs & LEDs you wil find **LINK** Regards Nick. Edited By Nicholas Farr on 22/11/2014 08:05:34 |
Michael Gilligan | 22/11/2014 08:08:18 |
![]() 23121 forum posts 1360 photos | Thanks, Nick But I was simply answering Bogstandard2 MichaelG. Edited By Michael Gilligan on 22/11/2014 08:08:43 |
