Chris Denton | 29/09/2014 12:01:08 |
275 forum posts | Some sort of shear pin from my milling machine, anyone know it's name?
Thanks,
Edited By Chris Denton on 29/09/2014 12:02:59 |
John Rudd | 29/09/2014 12:47:55 |
1479 forum posts 1 photos | Looks to be a variation to a standard roll pin.... You could replace it with a piece of brass if the shear forces are not too great.....
Why has it broke? What did you do/what happened for it to break? |
Vic | 29/09/2014 13:27:51 |
3453 forum posts 23 photos | Never seen a pin like that, looks pretty neat! |
Clive Hartland | 29/09/2014 14:54:34 |
![]() 2929 forum posts 41 photos | A very common type of Roll Pin, often used in instruments to keep collars in place and also used where there are plastic parts. A bother to remove and I use a stepped punch specially made for each size I deal with. Clive |
Chris Denton | 29/09/2014 14:57:37 |
275 forum posts | It was on the drive shaft on a milling machine. The handle from the X axis hit a piece of wood that protects the Z axis DRO from splashes. Usually it just knocks it out of the way but this time it didn't! Yes it was a right pain to remove, I'll probably just use a standard roll pin, would this be ok? |
Neil Wyatt | 29/09/2014 15:04:14 |
![]() 19226 forum posts 749 photos 86 articles | > Yes it was a right pain to remove, I'll probably just use a standard roll pin, would this be ok? It did it's job, what would have broken if you had used a solid pin? Neil |
Chris Denton | 29/09/2014 15:15:13 |
275 forum posts | I'm meaning these: http://s689.photobucket.com/user/richardtomes/media/rollpin.jpg.html |
John McNamara | 29/09/2014 15:18:58 |
![]() 1377 forum posts 133 photos | Hi Chris Denton I recently acquired some tools that included a set of these: **LINK** they were used by a family relative now passed on. He was a skilled gunsmith. From the US Lyman roll Pin punches. Each one has a small pip on the end to engage the hole on the roll pin and keep it centred. They work very well. In the past I have used plain flat ended engineers punches, most of the time they work fine however the locating pip on these punches and the slightly recessed step on the end makes them far easier to use than plain punches, and they do not mar the roll pin as they are correctly centred. Other manufacturers make them as well. or make your own from silver steel. Regards
John Rudd | 29/09/2014 16:05:53 |
1479 forum posts 1 photos | Posted by Chris Denton on 29/09/2014 14:57:37:
It was on the drive shaft on a milling machine. Yes it was a right pain to remove, I'll probably just use a standard roll pin, would this be ok? My opinion? No! It is a sacrificial pin and is designed to shear ....I'd recommend you use brass....defo not Silver Steel.....
Look at it this way, if the pin doesnt break, something else will ! .....and it could be expensive and could contribute to you being injured....
Your call.... Edited By John Rudd on 29/09/2014 16:06:43 |
Clive Hartland | 29/09/2014 17:14:44 |
![]() 2929 forum posts 41 photos | Most shear pins I have come across were Aluminium and very soft! The end having been knurled with a straight knurl to make a tight fit. Emco Lathes use an Aluminium pin on the leadscrew on the Maximat 11.I would not use a steel or brass roll pin on any drive shaft as a safety device. Clive |
John Rudd | 29/09/2014 17:56:11 |
1479 forum posts 1 photos | Ok, rather than turning this into a pissing contest as to who's advice is best, I'll leave it to the op to make his own mind up..... Having 40 years experience in heavy engineering doesnt seem to count for much these, as there are too many arm chair experts... This one of the reasons I dont post much....
Admin, feel free to delete my account and posts...... Edited By John Rudd on 29/09/2014 17:56:41 |
Ian P | 29/09/2014 18:19:32 |
![]() 2747 forum posts 123 photos | I may as well throw my oar in. If the function of the OPs pin in his picture was as a shear pin then it not a well made/designed machine. The pin shown is quite hard steel, possibly spring steel or maybe stainless. Unless both parts of the drive that the pin passes through are hardened the odds are they will be damaged when the pin shears. On reflection since the pin shown has not sheared then maybe it is NOT a shear pin after all. Aluminium or copper are probably far more suitable, brass might be ok too. Clive, do you have a punch for those pins that are 1mm diameter? I struggled to remove one last week. At least the good thing is that they are 'sprung' so reusable and self locking. Ian P. |
magpie | 29/09/2014 19:07:00 |
![]() 508 forum posts 98 photos | Well Mr. Rudd, that is as good an example of someone spitting out their dummy as I have seen in a long time. I have no doubt that the chap WILL make up his own mind anyway, and what has HEAVY engineering got to do with hobby engineering ??? Cheers Derek. |
Neil Wyatt | 29/09/2014 19:48:55 |
![]() 19226 forum posts 749 photos 86 articles | There only seem to be two opinions here:
I can't see any one-upmanship of major disagreement going on? Neil FWIW experience with car doors has shown me that roll pins can shear for reasons not to do with excessive torque, but fretting corrosion and wear at the joint line. |
Clive Hartland | 29/09/2014 21:21:06 |
![]() 2929 forum posts 41 photos | Neil, regards the car door roll pins, when I look at the failure it seems to me that they have, 'Twisted' and broken. Ian P, I make up a punch by drilling a bit of bar and putting a short hard pin the same diameter in the hole and punch it through. Always fit a new one, never replace the old one. Starting them in the hole can also be a pain. Clive |
jason udall | 29/09/2014 21:26:46 |
2032 forum posts 41 photos | Just to futher stoke the fires.. I often see shear pins in outboard motors...as sacrificial between prop..and gearbox shaft. These use a ccopper alloy..which I think is brass..it matches workshop properties of brass.. I say maybe brass since brass is not a material I would choose for salt water... But the shear strength is comparable so..and colour isn't bronze..but still. . To the point .. brass is used as a sacrificial component between ss and the plastic of the prop...
I have seen steel.. ( notched)..bronze and brass shear components... I have not seen ali but thats my loss.. Still keen to learn. Btw..looks like a roll pin to me..I hope those two funtions weren't combined but it might be..again still keen to learn. ..
Ian P | 29/09/2014 22:23:55 |
![]() 2747 forum posts 123 photos | Clive Our experiences of these pins differs. I find them easy install than parallel pins mainly because they have a slight taper lead and hold themselves in the sleeve, also they stay in place if one part needs moving to align the holes. Whenever I have made a drift to press them out I have turned a spigot on the end of a bar, drilling up the end especially if the drift is hard steel sounds like hard work. The picture shows some 1.4mm diameter pins (shafts are 4mm). I have also seen some a bit smaller. maybe 1.2mm (I must have imagined the the 1mm ones), These are in some Japanese camera equipment and are not magnetic. I see no reason not to re-use this springy roll pins and I would not like to try and source small quantities in the UK.
Ian P |
Mike Poole | 29/09/2014 22:42:17 |
![]() 3676 forum posts 82 photos | If the roll pin is definitely an original fitment I would be surprised if it was intended to shear, as previously mentioned a hardened roll pin can make a mess when it shears. As it has sheared I think I would replace with a soft material and if nuisance shearing occurs work up to tougher materials or larger size. Some shear pins are steel but waisted so a weak point is defined. The waisted section can be increased in diameter until nuisance breakage does not occur but it is still the weak point that we want to break first. Mike |
Mark C | 29/09/2014 22:44:50 |
707 forum posts 1 photos | As for shear pins, I used to have to work on big stuff (snow ploughs etc.) and these had shear pins in the plough drive shafts. These pins are solid steel with a head at one end looking like a clevis pin on steroids with a machined annular groove at the shear point to provide a weak point in the pin. Try google for the term "shear pin" and look at the pictures! Brass, copper, steel - it matters little what you use as long as it will shear before deforming the associated parts and at the correct shear load. i suppose you also want it to shear clean rather than have a brittle fracture leaving debris all over the place! Mark Just tried typing "spring pin" in and looking at the pictures - there are lots of the type you have and they seem to be distinguished as "spring" pins rather than roll pins or selloc pins. I always think of spring pins as having a parallel slit and a roll pin as being a rolled up strip but everyone seems to have their own ideas on naming them! I think what you have is a "skew proof" spring pin Edited By Mark C on 29/09/2014 22:53:40 |
Chris Denton | 29/09/2014 22:55:22 |
275 forum posts | The pin had broken, it was originally 29mm long. As the shaft it is in has two universal joints there as a further three of these pins in the same shaft. I didn't explain this at the beginning.
Where can I buy these pins, has anyone seen them for sale in the UK? |
