Drilling holes in round objects
Drill collars
AndyNC25/09/2014 12:35:28
2 forum posts
Hi Guys, (and Gals)
I want to make some drill depth stop collars. I have no issues making them to the correct size internal, external and length using a lathe.
I can't work out how to drill a hole in the outside exactly in line with the axis for the clamp screw.
I can mount it a drill vice and centre punch the OD but how can I be sure that it is at the top so the drill is vertically above the axis.
There is an argument that says it doesn't have to be precise for this application but I'd rather have a method to get it the best I can.
Many thanks
Andy
JasonB25/09/2014 13:22:35
The ruler trick would be the easiest.
Don't punch the mark. Put the work in your vice slightly proud of the top and a centre or spotting drill in your drill chuck. Balance a 6" rule on the work and without the motor running bring the drill bit down so it pinches the rule which will likely tip one way or the other, move the vice until the rule is sitting level and clamp the vice to the mill table when it is.
Now you can centre/spot drill followed by your tapping drill and finally the tap which can be guided in a loosly tightened chuck to keep it true to teh hole.
Easier done than said
Michael Gilligan25/09/2014 13:32:44
23121 forum posts
1360 photos
Andy,
If you plan to do much of this sort of work; it might be worth making-up a drill unit that mounts in the toolpost [or direct to the cross-slide, according to taste]
With a drill at centre height, it's easy to do the cross-drilling whilst the job is in the lathe.
John McNamara25/09/2014 14:07:21
1377 forum posts
133 photos
For a quick and dirty centre within a couple of thou I sometimes use the edge of a 12" file to file a small flat say 2mm wide on the top of the work mounted in the vice. The file must be kept parallel to the table or you will be off, the longer file makes it easier to judge. Once marked I centre punch in the centre of the flat and drill.
I guess if the file was mounted in a jig that keeps it parallel it would be more accurate
You can also mount an endmill in the chuck and mill the small flat with that by just skimming the top surface of the work as with the file. If the end mill is smaller than your drill there will be no tell tale mark after the hole is drilled.
I know the above methods will raise a few eyebrows among the purists, they do get the job done quickly... it depends on the job you are doing and knowing the limits you need to work to.
jason udall25/09/2014 15:21:20
2032 forum posts
41 photos
Chose drill or rod of same diameter as stop...
Manoeuvre vice until " drill" just touches fixed jaw..
Drill center now in line with stop centerline when clamped in vice..
Now drill as desired...
I.M. OUTAHERE25/09/2014 15:37:45
1468 forum posts
Another quick way if the diameter of the item you are drilling is small enough to fit into the drill chuck is to mount up a piece of it in the chuck and then clamp the vise onto the other end of it then clamp the vise down to the table . The centre of the spindle is now on the centre line of the piece you want to drill, if your vise has those vee grooves (usually one horizontal and one vertical) in the fixed jaw and you are going to use it to hold the job make sure you use the vertical one to do the set up otherwise the piece will end up being indexed to one side by the same depth of the vee groove , if the vise only has the grooves in the moving jaw then it won't matter . I have seen somewhere a tool that goes in the chuck and has a vee piece in the end that is meant to locate on the piece of bar you are drilling but it would be useless for very small diameters as the vee had a radius in the guts of it .
Ian
AndyNC26/09/2014 12:30:13
2 forum posts
Wow, more replies than I expected. Many thanks for them.
In practical terms for me the ruler trick or the end mill seems the easiest solution and would give me the accuracy I desire.
I only need to make about 4 units for the regularly used drills so a jig is probably over doing it.
Thinking about it last night another way would be to use a narrow v-block in a vice. The use a small drill/pin to line up with the centre/bottom of the V. When a round object is dropped in, it would automatically line up. BUT I don't have a narrow V-block so I'll stick with the ruler/endmill method.
Many thanks
Andy
Ian S C27/09/2014 10:47:50
7468 forum posts
230 photos
Andy, I use a V block, and to centre it I use a rod that fits in the drill chuck with a face about 1" diameter, this pressed down in the V then the V block is squared to the table(vertical mill).
Ian S C
chris stephens27/09/2014 12:51:50
1049 forum posts
The easiest way is surely to have a vee block on a morse taper in the tailstock and a drill in the lathe chuck. At least Myford and Southbend thought it so as the sold them for that purpose. The old ideas are often the best, what.
jason udall27/09/2014 15:26:56
2032 forum posts
41 photos
Yes Chris...unless the part isn't parallel over the holding section
chris stephens28/09/2014 01:09:29
1049 forum posts
True enough Jason but does that apply in this instance?
Howard Lewis30/09/2014 18:11:48
7227 forum posts
21 photos
Apart from what has already been suggested.
In the Mill/Drill, I use one of the centering devices, (a 90 degree V, with a small pointer, pivoted on a spindle held in a drill chuck) followed by a Centre Driil.
Also, I have the redundant centre square from a scrap combination set, which has been drilled/reamed and carrying a hardened silver steel centre punch, which is used to dot the centre of the round bar.
If you are dubious about using a centre drill straight away on the round surface, after centering, mill a small flat, and then centre the work piece, as above.
If all else fails MEASURE, either using cigarette papers, held on with oil/grease on each side with a drill/end mill/slot drill ; or use a wobbler or edge finder, or zero a clock on the fixed vice jaw, and move the table half the diameter of the bar.
DON'T forget to take out/allow for, the backlash when noting the scale readings and to allow for the diameter of the cutter/wobbler/edgefinder probe!
